Looking at just a PCB is difficult to diagnose. PCB and Schematic would be better.
Have you already built this circuit up on a breadboard (with the coin cell battery)? I'm not seeing a current limiting resistors on the LEDs. With a coin cell, that can only provide a few mA of current, you will probably only get a few minutes of life.
There is a drop-in Cmos replacement for the NE/SE555 it's the ICM7555 radio shack sells them last I looked. I''ve attached the data sheet, It will work @ 3V according to the little I looked... I used them as clock generators for precision timers in the early 90's. National Semiconductor made a similar part at about the same time but for the life of me I can't remember the part #... Look for CMOS Timers and the 555 and that one, I think works to 2V. AT 2V operation your choices for led's are simple only the red will work at that low voltage and make very certain that you use the high output/high efficiency LED's because as I remember there isn't a 100 mA source sink current like the 555. IHTH
This PCB will not work as is. For example the battery + is shorted to -
Your circuit will not work, the schematic is wrong.
Before proceeding, always check your circuit out on a Prototyping board before you finalize you circuit/board.
Do not parallel your LEDs.
Use a TLC555 CMOS timer, should work at 3 Volts
As James C4S suggests, you need resistors in series with the LEDS.
In this case one resistor for each LED (3Volt battery and 2V(led) at 10mA, 100 ohms should work).
After everything is said and done... Your board is a good first try. Whether it works or not depends on how important it is for it to work for you One thing I used to do was to draw a schematic from the board and then compare them... Mainly because sometimes netlisting software sometimes interprets symbols differently than we expect... And sometimes WE make errors. Sometimes it's useful to extract the netlist from the board to verify that autorouting did in fact go to 100% completion by comparing the two netlists. Sometimes the autorouter is a little optimistic... But that's because there are too many parts for the number of routing layers and ground-plane restrictions. Ground-planes are wonderful, Use them on both sides of the board. By making a ground plane you establish first the most difficult routing on the board and that is the ground.
You really should have a fixed series resistor of at least 1k with the 10k potentiometer. Otherwise, you run the risk, nearly a certainty, that you'll turn the resistance down to the lowest setting and short pin 7 to V+.
