I'm trying to update the firmware from Router AT to Coordinator API using X-CTU Next Gen. I work with arduino One and the Xbee Shield for Xbee module series2.
The module programmation is OK but after applying the new configuration X-CTU needs to add again the module. Then I re-add the module but here is the problem (device not found). X-CTU does not recognize the module. I tried also to reset the module when the action is required.
However, if I use the old version X-CTU legacy, the module is recognized with the new firmware (Coordinator API). I think X-CTU legacy is not allowed on iOS and i usually work with a mac.
