Topic: Need help dividing analog voltage (Read 336 times) previous topic - next topic
anjaleen
I am using a pulse sensor (https://pulsesensor.com) connected to an Adafruit Feather Huzzah esp8266 board. It draws power from a 3V pin ("the output from the 3.3V regulator that can supply 500mA peak"), and sends the sensor values to the ADC pin. However, this pin has "a 1.0V maximum voltage." I am trying to create a voltage divider but don't know how to go about it. Any help/a diagram showing how to wire this voltage divider on a breadboard, would be greatly appreciated.  :smiley:
MarkDerbyshire
Search Google for Voltage Divider.  There are loads of examples and calculators available
MarkT
edgemoron
3.3V----/\/\/\/----/\/\/\/---+----/\/\/\/----GND
                   1k              22k         |          10k
                                                 1.0V
newuser
http://www.ohmslawcalculator.com/voltage-divider-calculator
Enter R1 to have 30 kOhms and R2 to have 13kOhms to get 0.998 V
RIN67630
Forget the voltage divider.
Use analogReference(INTERNAL) and you will get a range of 0..1.1V at the analog inputs. By the way that will be more independen from Vcc as well.
Wawa
None of that on an ESP8266.
It only has one analogue input with a range of ~0-1volt.
Leo..
RIN67630
Leo..
Then, where is the problem?
The sensor delivers 0..1V the ESP needs 0..1V.
jremington
Quote
The sensor delivers about 3.3V.
RIN67630
OK, then 27KΩ and 10KΩ according to the common E12 values will provide 0..3,7V range.
