Which is the latest embedXcode release 59 or 101?
Latest version is 101. A new one numbered 102 is to be released later today.
Thanks avenue33 for the quick reply.
It would be great if you could add links for the old releases.
I wanted to install release 059 again, but I wasn't able to find it.
Thank you for your effort, I like embedXcode.
Please find a new release of embedXcode.
embedXcode • Jul 27, 2013 release 101 • Stability enhancements
embedXcode • Jul 29, 2013 release 102 • Improved utilities
Interim release 101 initiates the simplification process, as the template has grown in complexity, making it difficult to maintain. The idea is to focus on the main features.
Release 102 improves the utilities for checking the availability of new releases and preparing the project with all the references.
The User Manual is also being reviewed and is under approval.
As always,
• Website: http://embedxcode.weebly.com
• Download: http://embedxcode.weebly.com/download
• User guide: http://embedxcode.weebly.com/tutorial
Enjoy
avenue33:
Enjoy
I've installed Release 102 and did a quick test (Build and Upload to Arduino Mega2560 r3). So far Okay. Thanks for the new Release.
Can I have two or more Arduinos plugged into my Mac and then try to upload to one of them with Xcode? If so, how to I pick the port? I just tried a little test: I plugged my Mega into my Mac and nothing else. I uploaded my sketch successfully to it. Then I plugged in a Leonardo and tried to upload my sketch again. The first time I tried the upload build failed. The second the upload build just hung and did nothing until I cancelled it after a few minutes.
embedXcode uses the first serial port found.
You need to unplug and plug the boards it you want to upload to a specific board.
avenue33:
embedXcode uses the first serial port found.You need to unplug and plug the boards it you want to upload to a specific board.
Thanks. Do you have any plans to add some user control to picking USB ports?
Thank you for your feed-back. I'll consider adding this feature.
I am getting errors with the OneWire Library in the OneWire.h and OneWire.cpp it says oneWire was not defined. If you have any progress please let me know yagoax at gmail dot com.
By default, OneWire is excluded as it raises issues with different boards.
To include it again, edit the makefile and the line
EXCLUDE_LIBS = Firmata WiFi Esplora OneWire Robot_Control Robot_Control/utility Robot_Motor
For more information, please refer to Chapter 4 Build and Upload the Project, Section 2 Manage the Libraries for Compilation, Sub-section Exclude Libraries of the User Manual.
Hi:
I followed the instructions on the You-Tube video and created a new project (Quite Nice Actually). Then per the instructions I ran the build and the build failed with the following error:
Error, No Application Found Stop
What did I do wrong?
Thanks,
freddie
Is Arduino installed in the /Applications folder?
See chapter 1 Install the Template section 2 Install the IDEs of the boards of the User Manual.
Hi:
I Cannot read the Users Manual because I do not possess an iPad or any other iXxx device, and iTunes will not download to my Mac. And Yes Arduino is installed (In the usual place: Applications folder)and I have been using the Arduino IDE for about 6 months with no problems.
Unfortunately the Arduino IDE is not very useful for larger projects.
Thanks,
Freddie
Please open a Terminal window and launch
ls /Applications/Arduino.app
The main sections of the User Manual are available at http://embedxcode.weebly.com/tutorial
My Arduino.app was not installed in the Applications Folder, it was inside another folder that is why Xcode could not find it.
So I just moved it to the Application Folder and its working alright for now, its time to try to make it do something now.
I did not find the tutorial on your Website to be very useful at all, it is confusing because it does not just come out and tell you the steps you need to take to get it working.
Perhaps putting in FAQ (Frequently Asked Questions) section would be helpful.
Thanks,
Freddie
Hi Again:
Now I have started to build a Project I get 42 errors related to the following file inclusions:
#include <OneWire.h> //These are the libs for the One-Wire interface
#include <UTFT.h> // We are going to use the Display instead of the monitor
#include <SD.h> // We also need the SD card libraries for storing the data on the disk.
#include <Wire.h>
#include <SPI.h> // not used here, but needed to prevent a RTClib compile error
#include <RTClib.h>
Xcode does not seem to have a problem finding these files, however whenever I try to use any of the features of these files I get an error. These work fine in the Arduino IDE with no errors.
What is wrong now?
Thanks,
Freddie
sbfreddie:
Hi Again:
Now I have started to build a Project I get 42 errors related to the following file inclusions:#include <OneWire.h> //These are the libs for the One-Wire interface
#include <Wire.h>
#include <RTClib.h>Xcode does not seem to have a problem finding these files, however whenever I try to use any of the features of these files I get an error. These work fine in the Arduino IDE with no errors.
What is wrong now?
Thanks,
Freddie
Go up a few posts (Arduino on Xcode Project — Official Thread - #426 by avenue33 - Libraries - Arduino Forum) and it tells you how to take care of the onewire issue. Not sure about the rest. One issue I discovered for the user libraries (not app libraries) was that the directory name had to be the same as the library name; Arduino IDE didn't care but xcode does.
embedXcode • Aug 10, 2013 release 103 • First release of embedXcode+
I'm introducing a second and more elaborate version of embedXcode, embedXcode+, available soon.
A new release of the User Manual as e-book is also available.
I take this opportunity to announce that embedXcode is joining forces with Visual Micro, to share experience and release exciting new features.
As always,
Enjoy
embedXcode • Sep 01, 2013 release 104 • Improved utilities
embedXcode+ • Sep 01, 2013 release 104 • Improved utilities and select among two connected boards
Release 104 inaugurates the new embedXcode+ edition with extended features.
In case two similar boards are connected, for example two Arduino boards, a windows lists the connections and ask to select one:
• To select the first port, press Enter, click on the button 1 or wait 10 seconds.
• To select the second port, click on the button 2.
This feature works with the Arduino boards and similar boards using a serial through USB connection.
As always,
Enjoy
