Please open a Terminal window and launch
ls /Applications/Arduino.app
The main sections of the User Manual are available at http://embedxcode.weebly.com/tutorial
My Arduino.app was not installed in the Applications Folder, it was inside another folder that is why Xcode could not find it.
So I just moved it to the Application Folder and its working alright for now, its time to try to make it do something now.
I did not find the tutorial on your Website to be very useful at all, it is confusing because it does not just come out and tell you the steps you need to take to get it working.
Perhaps putting in FAQ (Frequently Asked Questions) section would be helpful.
Thanks,
Freddie
Hi Again:
Now I have started to build a Project I get 42 errors related to the following file inclusions:
#include <OneWire.h> //These are the libs for the One-Wire interface
#include <UTFT.h> // We are going to use the Display instead of the monitor
#include <SD.h> // We also need the SD card libraries for storing the data on the disk.
#include <Wire.h>
#include <SPI.h> // not used here, but needed to prevent a RTClib compile error
#include <RTClib.h>
Xcode does not seem to have a problem finding these files, however whenever I try to use any of the features of these files I get an error. These work fine in the Arduino IDE with no errors.
What is wrong now?
Thanks,
Freddie
sbfreddie:
Hi Again:
Now I have started to build a Project I get 42 errors related to the following file inclusions:#include <OneWire.h> //These are the libs for the One-Wire interface
#include <Wire.h>
#include <RTClib.h>Xcode does not seem to have a problem finding these files, however whenever I try to use any of the features of these files I get an error. These work fine in the Arduino IDE with no errors.
What is wrong now?
Thanks,
Freddie
Go up a few posts (Arduino on Xcode Project — Official Thread - #426 by avenue33 - Libraries - Arduino Forum) and it tells you how to take care of the onewire issue. Not sure about the rest. One issue I discovered for the user libraries (not app libraries) was that the directory name had to be the same as the library name; Arduino IDE didn't care but xcode does.
Please find a new release of embedXcode
embedXcode • Aug 10, 2013 release 103 • First release of embedXcode+
I'm introducing a second and more elaborate version of embedXcode, embedXcode+, available soon.
A new release of the User Manual as e-book is also available.
I take this opportunity to announce that embedXcode is joining forces with Visual Micro, to share experience and release exciting new features.
As always,
• Website: http://embedxcode.weebly.com
• Download: http://embedxcode.weebly.com/download
• User guide: http://embedxcode.weebly.com/tutorial
Enjoy
Please find a new release of embedXcode.
embedXcode • Sep 01, 2013 release 104 • Improved utilities
embedXcode+ • Sep 01, 2013 release 104 • Improved utilities and select among two connected boards
Release 104 inaugurates the new embedXcode+ edition with extended features.
In case two similar boards are connected, for example two Arduino boards, a windows lists the connections and ask to select one:
• To select the first port, press Enter, click on the button 1 or wait 10 seconds.
• To select the second port, click on the button 2.
This feature works with the Arduino boards and similar boards using a serial through USB connection.
As always,
Enjoy
Hi. Is just me that is having this problem? I just install the last Xcode and embedXcode. Than start one simple project, don't make ANY change, config to Build and press run. Than I have this error:
In poliserial.cpp
void pollserial::write(uint8_t c) {
pollserial.cpp:131: Prototype for 'void pollserial::write(uint8_t)' does not match any in class 'pollserial'
In Print.h
virtual size_t write(uint8_t) = 0;
Print.h:48: Candidates are: virtual size_t Print::write(uint8_t)
size_t write(const char str) {
Print.h:49: size_t Print::write(const char)
virtual size_t write(const uint8_t buffer, size_t size);
Print.h:53: virtual size_t Print::write(const uint8_t, size_t)
Is this a bug? All the problem is with this write function. This is just a compilation problem but I am very weak in C++ to solve it
Can someone help this?
In order to help, I need more information.
Hi. Thanks for the fast answer.
I am using the last of everything:
I don't make ANY change from original script from your embedXcode. I just start a project and try to compile it. So I really think this is a small bug and it is not in sketch, but in "core" program.
Where can I download an old version to see if this is the problem? This look like a problem with virtual function... I tried a lot of things and none work until now...
I did a quick search on the Arduino forum to find solutions related to this PollSerial library.
It seems it raises problems.
See for example Arduino to Stand-alone ATMEGA328 Communication Problem, among the many threads about this very library.
I guess you have installed this library in your sketchbook.
You need to exclude it. Please proceed as follow:
avenue33:
EXCLUDE_LIBS = pollserial OneWire Firmata WiFi Esplora OneWire Robot_Control Robot_Control/utility Robot_Motor
For more information, please refer to Chapter 4 Build and Upload the Project, Section 2 Manage the Libraries for Compilation, Sub-section Exclude Libraries of the User Manual.
Have you downloaded the User Manual?
Hum... This is not library from your project? My bad... Because I am starting with Arduino and in my first try with your program I get this error, I thought this problem come from your program...
I will try it now and see if it work
And yes, I tried to read your (good) user manual. I only have to understand that this is a library from arduino
Sh*t... This poliserial is a sub-library from a library that I installed other day.. Because this I have no idea from were this come from (now I discovery the build log from Xcode and see the it compile every library I have, even if I not call then)..
Only one day to discovery this small problem... =(
If I not did this mistake, It will be "plug and play"!!
One advice, in Solutions to Most Common Issues
Symptom: Compilation fails.
Solution: Create an empty library folder and try again. Than put the libraries you want and test what cause problem.
Solution: Read the f*cking compilation log! It will show that the problem come from one of your library!
Already in the Solutions to Most Common Issues
Symptom Compilation fails.
Solution What are the messages in the Log navigator?
Reference See Error Messages
Old and new icons for embedXcode!
Hi again! the embedXcode is working very well. But, I am having problem with git and XCode. I can use a external program and it work well.
But with Xcode, I can't do anything. It commit with out problem, but it don't make any difference and I can't see the history in the Xcode. No matter how many times I do the commit, the "A" status never change.
This only happens with embedXCode project, if I create a "normal" project I don't see any of this problems.
Did you know the problem or what I can do to solve it?
This is the image:
rodrigozanatta:
Hi again! the embedXcode is working very well. But, I am having problem with git and XCode. I can use a external program and it work well.Did you know the problem or what I can do to solve it?
I haven't been able to replicate the issue.
Now, Xcode is performing many things under the hood, especially indexing all the libraries.
This may have an impact on the commit process.
avenue33:
I haven't been able to replicate the issue.Now, Xcode is performing many things under the hood, especially indexing all the libraries.
Do you know how can your program affect the git? The git itself is working perfectly outside, but something between Xcode and Git are not working. I was the first to report this?
The template doesn't affect the Git, except Xcode has a lot of work to perform just after the project is prepared, as references to all the libraries are added to the project.
Yes, you're the first to report this. Congratulations!
Something very strange is happing with my Xcode... I will try to reinstall it.
Anyway, one last thing that I can't do is send a message to serial for debug. How can I print a single "Hello World"?
This classic way don't work:
Serial.println("Hello world!");
Neither the
printf("Hello World");
Is this the way to do it? Or I can't send this message with your program? I try to read all your docs, but didn't find this answer. Is this one (more) problem of my Xcode, or am I missing a library?
The serial console appears on a separate Terminal window.
