I was wondering if someone could tell me what I'm doing wrong here. I'm still a noob thats in need of a lot of help.
here is my code that I modded:
* Code for cross-fading 3 LEDs, red, green and blue, or one tri-color LED, using PWM
* The program cross-fades slowly from red to green, green to blue, and blue to red
* The debugging code assumes Arduino 0004, as it uses the new Serial.begin()-style functions
* Clay Shirky <clay.shirky@nyu.edu>
// ??? int wait = 0; // variable to store the reading from the potentiometer
int potPin = 3; // analog pin where to plug the potentiometer at
int wait = analogRead(potPin); // ???
int redPin = 9; // Red LED, connected to digital pin 9
int greenPin = 10; // Green LED, connected to digital pin 10
int bluePin = 11; // Blue LED, connected to digital pin 11
// Program variables
int redVal = 255; // Variables to store the values to send to the pins
int greenVal = 1; // Initial values are Red full, Green and Blue off
int blueVal = 1;
int i = 0; // Loop counter
// int wait = 50; // 50ms (.05 second) delay; shorten for faster fades
int DEBUG = 0; // DEBUG counter; if set to 1, will write values back via serial
wait = analogRead(potPin); // read the potentiometer
pinMode(redPin, OUTPUT); // sets the pins as output
pinMode(greenPin, OUTPUT);
pinMode(bluePin, OUTPUT);
if (DEBUG) { // If we want to see the pin values for debugging...
Serial.begin(9600); // ...set up the serial ouput on 0004 style
// Main program
i += 1; // Increment counter
if (i < 255) // First phase of fades
redVal -= 1; // Red down
greenVal += 1; // Green up
blueVal = 1; // Blue low
else if (i < 509) // Second phase of fades
redVal = 1; // Red low
greenVal -= 1; // Green down
blueVal += 1; // Blue up
else if (i < 763) // Third phase of fades
redVal += 1; // Red up
greenVal = 1; // Green low
blueVal -= 1; // Blue down
else // Re-set the counter, and start the fades again
i = 1;
analogWrite(redPin, redVal); // Write current values to LED pins
analogWrite(greenPin, greenVal);
analogWrite(bluePin, blueVal);
if (DEBUG) { // If we want to read the output
DEBUG += 1; // Increment the DEBUG counter
if (DEBUG > 10) // Print every 10 loops
DEBUG = 1; // Reset the counter
Serial.print(i); // Serial commands in 0004 style
Serial.print("\t"); // Print a tab
Serial.print("R:"); // Indicate that output is red value
Serial.print(redVal); // Print red value
Serial.print("G:"); // Repeat for green and blue...
Serial.print(greenVal);
Serial.print("\t");
Serial.print("B:");
Serial.println(blueVal); // println, to end with a carriage return
delay(wait); // Pause for 'wait' milliseconds before resuming the loop
Thanx
