xbee.h will not compile with MICRO
I am trying to use the MICRO with Xbee but I get the error
error: cannot convert 'Serial_' to 'HardwareSerial' in assignment
I read the post about a fix for the LEONARDO as shown in:
But I still get the error. Is there another code for the MICRO that is different from the LEONARDO or am I missing something else that I have to put in the code. This is the code I added to the beginning of xbee.cpp
#if defined(USBCON)
   _serial = &Serial1;
#else
   _serial = &Serial;
#endif
What is "USBCON", where is it defined/used??
Appreciate the help.
Bill
The url for the LEONARDO post is
http://arduino.cc/forum/index.php/topic,111354.0.html
Bill
"I'm trying to compile a sketch, but I won't show you what sketch, for the MICRO, and I'm having problems. Can you help?"
Did I summarize your post correctly?
Sorry about that; I was assuming the problem was in the xbee.h or xbee.cpp library files; anyway heres the core of the code.
Appreciate quick response and the help.
#include <Keypad.h>
#include <Button.h>
#include <XBee.h>
#include <AltSoftSerial.h>
#include <SoftwareSerial.h>
uint8_t LCDTxPin = 13;
SoftwareSerial mySerial = SoftwareSerial(255, LCDTxPin);
const int launch_A = 10;
const int launch_B = 11;
int buttonstate_A = 0;
int buttonstate_B = 0;
uint8_t count = 0;
uint8_t ncount = 0;
// Define AltSoftSerial TX/RX pins
// Connect Arduino pin 8 to TX of usb-serial device
uint8_t ssRX;
// Connect Arduino pin 9 to RX of usb-serial device
uint8_t ssTX = 9;
// Remember to connect all devices to a common Ground: XBee, Arduino and USB-Serial device
AltSoftSerial nss(ssRX, ssTX);
XBee xbee = XBee();
unsigned long start = millis();
uint8_t hset = 0x01;
	// set payload to launcher ID;i.e hand station 1 and Station 1 and launcher 1
        // set payload to launcher ID;i.e hand station 8 and Station 15 and launcher 5
uint8_t payload []= {hset,0x01,0x01};
// Set DIO0 (pin 20) to Analog Input
uint8_t d0Cmd[] = { 'D', '0' };
uint8_t d0Value[] = { 0x4 };
uint32_t xbee_SH = 0x0013a200;
uint32_t xbee_SL = 0x40923f1f;
const byte ROWS = 4; //four rows
const byte COLS = 3; //three columns
  //MEMBRAIN KEYPAD
char keys[ROWS][COLS] =
  {1,2,3},
  {4,5,6},
  {7,8,9},
  {'*',0,'#'}
byte rowPins[ROWS] = {8, 7, 6, 5}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {4, 3, 2}; //connect to the column pinouts of the keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
int attempt[2]={0,0}; // used for comparison for statioID
char P_PIN[6]={1,2,3,4,5,6}; // our secret (!) number
char P_attempt[6]={0,0,0,0,0,0}; // used for password comparison
int z=0;
uint8_t key1;
uint8_t key2;
uint8_t StationID = 0;
uint8_t nStationID = 0;
char gotolauncher;
  pinMode(LCDTxPin, OUTPUT);
  digitalWrite(LCDTxPin, HIGH);
  pinMode(launch_A, INPUT);
  pinMode(launch_B, INPUT);
  digitalWrite(launch_A, HIGH);
  digitalWrite(launch_B, HIGH);
  Serial.begin(9600);          //MICRO USB serial
  //Serial1.begin(57600);        //xbee serialon pins 1,2
  xbee.setSerial(Serial1);
  // start soft serial for debugging
  nss.begin(9600);
  // start LCD serial
  mySerial.begin(9600); //start LCD serial
  mySerial.write(0x7c);
  mySerial.write(130);
void sendPacket()
     // SH + SL of your remote radio
  XBeeAddress64 remoteAddress = XBeeAddress64(xbee_SH, xbee_SL);
    // Create a remote AT request with the IR command
  RemoteAtCommandRequest remoteAtRequest = RemoteAtCommandRequest(remoteAddress, d0Cmd, d0Value, sizeof(d0Value));
    // Create a Remote AT response object
  RemoteAtCommandResponse remoteAtResponse = RemoteAtCommandResponse();
  sendRemoteAtCommand();
  nss.println("First Command");
 delay(100);
void sendRemoteAtCommand() {
  nss.println("Sending command to the XBee");
  // send the command
  xbee.send(remoteAtRequest);
  // wait up to 5 seconds for the status response
  if (xbee.readPacket(5000)) {
    // got a response!
    // should be an AT command response
    if (xbee.getResponse().getApiId() == REMOTE_AT_COMMAND_RESPONSE) {
      xbee.getResponse().getRemoteAtCommandResponse(remoteAtResponse);
      if (remoteAtResponse.isOk()) {
        nss.print("Command [");
        nss.print(remoteAtResponse.getCommand()[0]);
        nss.print(remoteAtResponse.getCommand()[1]);
        nss.println("] was successful!");
        if (remoteAtResponse.getValueLength() > 0) {
          nss.print("Command value length is ");
          nss.println(remoteAtResponse.getValueLength(), DEC);
          nss.print("Command value: ");
          for (int i = 0; i < remoteAtResponse.getValueLength(); i++) {
            nss.print(remoteAtResponse.getValue()[i], HEX);
            nss.print(" ");
          nss.println("");
        nss.print("Command returned error code: ");
        nss.println(remoteAtResponse.getStatus(), HEX);
      nss.print("Expected Remote AT response but got ");
      nss.print(xbee.getResponse().getApiId(), HEX);
  } else if (xbee.getResponse().isError()) {
    nss.print("Error reading packet.  Error code: ");
    nss.println(xbee.getResponse().getErrorCode());
    nss.print("No response from radio");
    return ;
void getlauncher()
  //nss.println("I'm Here");
  switch(StationID)
    case 1:                              //Station #1
      buttonstate_A = digitalRead(launch_A);  //A launcher button pushed
      buttonstate_B = digitalRead(launch_B);  //B launcher button pushed
      if (buttonstate_A == LOW)
        nss.println("launch_A pressed");
        ncount = count + 1;
        d0Value[0] =  0x5 ;
        xbee_SL = 0x40923f25;
        sendPacket();
        delay(10);
        payload[1] = 0x01;
        payload[2] = 0x01;
      if (buttonstate_B == LOW)
        nss.println("launch_B pressed");
        ncount = count + 1;
        d0Value[0] =  0x5 ;
        xbee_SL = 0x40923f3d;
        sendPacket();
        delay(10);
        payload[1] = 0x01;
        payload[2] = 0x02;
      break;
    case 2:                              //Station #2
        ncount = count + 1;
        d0Value[0] =  0x5 ;
        sendPacket();
        delay(10);
        payload[1] = 0x02;
        payload[2] = 0x01;
        ncount = count + 1;
        d0Value[0] =  0x5 ;
        sendPacket();
        delay(10);
        payload[1] = 0x02;
        payload[2] = 0x02;
      break;
void readcounts()
  mySerial.write(254);  //cursor to beginning of first line
  mySerial.write(128);
  mySerial.write("StationID=     ");
  mySerial.write(254);  //cursor to position 12 of first line
  mySerial.write(139);
  mySerial.print(nStationID);
  mySerial.write(254);  //cursor to beginning of second line
  mySerial.write(192);
  mySerial.write("#launches=     ");
  mySerial.write(254);  //cursor to position 12 of second line
  mySerial.write(203);
  mySerial.print(ncount);
if (nStationID != StationID)
    readcounts();
    StationID = nStationID;
if (StationID == 0)
if (gotolauncher = '#')
    getlauncher();
if (StationID != 0 && StationID != 18 && StationID != 21)
if (StationID == 21)
if(StationID == 18)
if (ncount != count)
   readcounts();
   count = ncount;
uint8_t ssRX;
uint8_t ssTX = 9;
You don't think the compiler is going to read your comment, do you?
Why isn't ssRX assigned a value?
Complete error messages are a good thing,
I am not using pin 8 for serial; I am only using Pin 9 for debugging.
This code works fine on PRO MICRO and FIO. It will not compile when MICRO is selected.
The error code I get when connected to MICRO is:
RemoteAtCommand_DIGIMESH_MICRO_xbee.ino: In function 'void setup()':
RemoteAtCommand_DIGIMESH_MICRO_xbee:79: error: no matching function for call to 'XBee::setSerial(Serial_&)'
C:\Documents and Settings\BILL\My Documents\ARDUINO_1_16_2013\arduino-1.0.3\libraries\XBee/XBee.h:779: note: candidates are: void XBee::setSerial(HardwareSerial&)
Bill
I don't understand this. You should still assign a non-zero value to the ssRX pin.
Where did you get the XBee library you are using?
The Xbee library is xbee-arduino-0.4-softwareserial-beta.zip downloaded from here;
The program runs fine with nothing assigned to the ssRX pin.
Bill
When I compile your code, for the Micro, using 1.0.3, I get a number of errors about AltSoftSerial not being configured for the Micro, but I get no errors about the XBee library. What version of the IDE are you using? How did you configure AltSoftSerial to recognize the Micro?
I let you to the wrong xbee.h file ; the one I am using I got from:
I am using the one from the March 9, 2012 post. This included the support for DIGIMESH.
Sorry.
I am using Arduino 1.0.3
Bill
Paul:
Hold off spending any more time at the moment; I have screwed up my files and I have to straighten them out before I ask for more assistance.
I will repost when I can figure out what changes I made to xbee.h
Bill
Paul
OK, back on track.
Attached are the xbee.h, xbee.cpp and error message., xbee.h and xbee.cpp were downloaded from
Mega Rx from Xbee causing high voltage 1023 on all analog input pins · Issue #20 · andrewrapp/xbee-arduino · GitHub March 9 post.
The sketch runs OK with FIO or PRO MINI but gives the error message when using a MICRO.
Bill
XBee.h (30.5 KB)
XBee.cpp (37.8 KB)
MICRO_XBEE.docx (9.93 KB)
In those files, the _serial member is a HardwareSerial pointer. In the XBee library at GitHub - andrewrapp/xbee-arduino: Arduino library for communicating with XBee radios in API mode, the _serial member is a Stream.
Both HardwareSerial and Serial_ derive from Stream, but are not interchangeable. The XBee library does not rely on the parts of HardwareSerial or Serial_ that distinguish them from Stream. So, just use the library from the google link.
I cannot use this solution since I am using a Xbee DIGIMESH and it will not work with the beta XBee library downloaded from here
This library works with Xbee series 1 and 2 but not all API packets for DIGIMESH
The Xbee library downloaded from here
works with DIGIMESH but not with ARDUINO MICRO.
I fixed my sketch by combining the two zbee libraries into a third which I call XBeeDM32u4 and this is now working with the MICRO and a Zbee DIGIMESH 2.4Mhz.
Attached is the new library; I do not know iof this will work for everyone but it fixed my sketch.
Bill
readme32u4.txt (1000 Bytes)
XBeeDM32u4.cpp (39.7 KB)
Here is the XBeeDM32u4.h file
Bill
XBeeDM32u4.h (31.7 KB)
