Arduino Forum
Forum 2005-2010 (read only) => Software => Syntax & Programs => Topic started by: tamberg on Jan 14, 2010, 01:54 pm
Title: Declaring Class Variables / Calling Constructors
Post by: tamberg on Jan 14, 2010, 01:54 pm
(coming from Java, no C/C++ experience)
there seems to be a difference between Processing and Arduino when it comes to calling a constructor to instantiate an object of a class.
E.g. Processing
   C c; // declare variable c
   c = new C(); // create object of class C
   c.M(); // call method M of c
vs. Arduino
   C c(); // declare & create
   c.M(); call method M of c
Now my questions:
1) Is there a way in Arduino to declare a variable of a class and *later* assign an instance to it?
2) Does Arduino really have classes, objects and constructors?
Regards,
tamberg
Title: Re: Declaring Class Variables / Calling Constructors
Post by: PaulS on Jan 14, 2010, 01:58 pm
No. What you have to do is move the logic that you would put into a constructor into an initialization method, instead (usually called begin).
Yes. It has objects, but not instances.
Post by: tamberg on Jan 14, 2010, 02:01 pm
Thanks for your quick answer. What do you mean by "objects but not instances"? Isn't an object just an instance of a class? Or are Arduino objects rather like structs in C?
Regards,
tamberg
Post by: Spinlock on Jan 14, 2010, 02:09 pm
I have to disagree with PaulS.  It does have objects and instances - just not dynamic instances.
that is to say you can't create and delete objects on the fly using C++'s new and delete.
Post by: PaulS on Jan 14, 2010, 02:55 pm
To me, that's what distinguishes objects from instances. Objects are statically defined, while instances are dynamically defined.
Perhaps not technically accurate (certainly not with using the word static there), but that's the way I think of objects and instances.
Post by: AlphaBeta on Jan 14, 2010, 03:11 pm
An object is an instance of a class.  :)
Post by: PaulS on Jan 14, 2010, 03:16 pm
Yes, I know that. I'm struggling to come up with the right terminology to define the difference between object1 and object2 in this scenario:
MyClass object1;
MyClass *object2 = new MyClass();
Since the Arduino can't do the latter, I think of it as not being able to have instances. I guess that's not the right term, but I don't know what the right term to describe object2 is.
Post by: mfm9 on Jan 14, 2010, 05:28 pm
You could say that the Arduino has instances, but not instantiation ;)
-Mike
Post by: AlphaBeta on Jan 14, 2010, 05:35 pm
My (well, not only mine) ideas on the matter:
MyClass object1; //this is in fact instantiation of the class MyClass
MyClass *myObjectReference = &object1; //could use myObjectPointer
Generally one speaks of the latter example as 'A pointer to an instance of class MyClass' or simply 'A pointer' or 'A reference'.  :)
Post by: jgrepps on Jan 15, 2010, 07:13 pm
tamberg, can you elaborate on this question?  Are you trying to create an instance of an object1 within another class (say...MyClass2).  Then set variables of object1 via a method of object1?
