Any web page that makes this statement should be regarded as suspect.
Typical input capacitor value is about 100uH,
Capacitors are not measured in uH, that is inductors.
I made an estimation for Vripple, about 100mV, is this realistic for two AA batteries as Vin?
The batteries have nothing to do with it, the ripple depends on current load.
I have no idea what I should enter for Fmin, some say 50kHz, some 100kHz
Again nothing to do with batteries. The higher the frequency the easier it is to smooth but the more demand is placed on the quality (ESR) of the capacitors.
Rsc is calculated to be 0.682ohms. How do I put this into practice?
Recalculate at a standard resistor value and see where that gets you.
Does "min" mean I could also use a 100uH or so inductor?
I assume it just uses the formulas available in the datasheet, no magic there.
Grumpy_Mike:
coule be just a typo?
Grumpy_Mike:
I know, but (I think) wont a battery have a higher Vripple than a lab power supply? But I realise this has also to do with the load, I'm going to experiment (and measure).
Grumpy_Mike:
Ok, here I understood something wrong. But how is this determinded? "Where" does it come from and what should I use for calculation?
Grumpy_Mike:
The nearest value would be 0.68ohms. But the cheapest resistor I found in this size-area is a 10W resistor with heat-sink which is $5 per part. Or do I search wrong?
I need a 470pF and a 100uF capacitor, low-ESR. for the 100uF, I just look for a radial low-ESR electrolytic capacitor, but for the 470pF, will it a ceramic capacitor do?
It is not determined. It is a design decision that you make. What frequency do you want to run the converter at?
Normally it is the highest possible but sometimes other considerations come into play.
No there is no ripple in a battery. However the ripple arises as a result of the up conversion.
Is the boost converter going to be permantly connected to the batteries?
The MC34063A has a minimum idle current of 4 ma so will flatten 2 AA batteries
in about 3 weeks , even with no load on the output.
mauried:
Yes, I know, thanks. The powerswitch will be in front of the chip.
