Hey all.
Just got my first Arduino today, which was working fine until I decided to mess around with it
I set up the Arduino IDE which worked fine. Then I decided to try flashing it with an STK500 which I've used to flash other AVR's, this also worked fine. I connected the 6-pin ISP of the STK500 to the Uno and it flashed as expected. But when I wanted to reburn the bootloader I ran into problems...
I'm using Ubuntu, avr-gcc and avr-dude to play with my AVR's. Basically my problem is that I'm having trouble finding information about the correct lock bits and fuse settings for the atmega328p-pu that is plugged in my Uno board. As I've understood the correct bootloader to use is the file optiboot_atmega328.hex that exists in the $ARDUINO_HOME/hardware/arduino/bootloaders/optiboot directory.
I've read http://arduino.cc/en/Hacking/Bootloader?from=Main.Bootloader but the page doesn't list the 328-specific details. I tested with different settings, but something is wrong and I can't get the Uno programmed through the arduino IDE again. Presumably this is because the bootloader or some settings aren't as they should.
Here's what things look like at the moment:
- Fuse and lock bits:
$ avrdude -p m328p -P /dev/ttyS0 -c stk500 -U efuse:r:-:h -U hfuse:r:-:h -U lfuse:r:-:h -U lock:r:-:h
Reading | ################################################## | 100% 0.04s
avrdude: Device signature = 0x1e950f
avrdude: reading efuse memory:
Reading | ################################################## | 100% 0.01s
avrdude: writing output file "<stdout>"
0x5
avrdude: reading hfuse memory:
0xcc
avrdude: reading lfuse memory:
0xdf
avrdude: reading lock memory:
0x3f
avrdude: safemode: Fuses OK
avrdude done. Thank you.
- parms and part info:
$ avrdude -p m328p -P /dev/ttyS0 -c stk500 -t
avrdude> parms
>>> parms
Vtarget : 5.1 V
SCK period : 10.9 us
Varef : 5.0 V
Oscillator : 3.686 MHz
avrdude> part
>>> part
AVR Part : ATMEGA328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 5 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
- I use the following command to try burning the bootloader on the 328:
$ avrdude -p m328p -P /dev/ttyS0 -c stk500 -U flash:w:optiboot_atmega328.hex
avrdude: NOTE: FLASH memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "optiboot_atmega328.hex"
avrdude: input file optiboot_atmega328.hex auto detected as Intel Hex
avrdude: writing flash (32748 bytes):
Writing | ################################################## | 100% 0.73s
avrdude: 32748 bytes of flash written
avrdude: verifying flash memory against optiboot_atmega328.hex:
avrdude: load data flash data from input file optiboot_atmega328.hex:
avrdude: input file optiboot_atmega328.hex contains 32748 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 42.38s
avrdude: verifying ...
avrdude: 32748 bytes of flash verified
Flashing 32748 bytes for the bootloader seems a bit odd as I thought it was supposed to be 512 bytes, but the filesize is 1,4K:
$ ls -lh optiboot_atmega328.hex
-rw-r--r-- 1 erichax erichax 1.4K 2011-04-06 22:46 optiboot_atmega328.hex
Can anyone please help me understand what I'm doing wrong here? For starters, info about correct fuse and lockbit settings and what bootloader file to use would be very helpful. I'm assuming that using the ISP on the STK500 with avrdude to flash the Uno with a bootloader is actually possible, am I correct about this?
