Standalone Mega2560 boot time
Hello everyone. I'm new to this forum and I hope you'll be able to help me.
I built a standalone Mega2560 board with the Atmega16U2 to be able to use my system as closest as possible to a real Arduino.
Everything in my setup is working perfectly, except 1 small detail. Since I don't own a real Arduino Mega2560, I want to check with other users if it's something wrong or not.
When I power up the unit, the program on the Mega2560 starts right away. If I program it using the Arduino software, again, the program starts right at the end of the process. But, when I open the serial monitor, the chip resets and the program starts 9.5 seconds later. Is this delay normal ? On my Uno, this same delay is near nothing.
Of course, I've made some research on the net, on the forum, etc. I used my oscilloscope and found the reset is working normally (same behavior as on my Uno). The only other connection to the Mega2560 is the serial connection. Again, the TX of the Atmega16U2 goes low (for 39 us) when the chips resets the Mega2560 and this is the same with my Uno.
I tried to use the exact same settings of the real Mega2560. I'm using an AVR MkII clone and AtmelStudio 6. For the PCB, I simply followed the Eagle schematics of the real one. Here is the details of my bootloaders and initial chip settings (programs found in Arduino 1.0.3 directory) :
Atmega16U2
Arduino-usbserial-atmega16u2-Mega2560-Rev3.hex
Extended : 0xF4
High : 0xD9
Low f : 0xEF
Lock bits : 0xEC
Mega2560
stk500boot_v2_mega2560.hex
Extended : 0xFD
High : 0xD8
Low f : 0xFF
Lock bits : 0x0F
Thank you for your help !
No it's not normal. Try the bootloader (for the 2560) from here:
Are they the actual fuse settings? Or what is in board.txt?
Use avrdude to read back the signatures fuses and show us that.
The fuses settings are from boards.txt and they are the actual fuses settings.
I tried the firmware, no change.
I'm not using avrdude, but AtmelStudio 6. Can this be an issue ?
Can you read the fuses with avrdude and copy and paste the results here please?
A 9 second delay sounds suspiciously like you have the "divide by 8" fuse set (for the clock).
Here is what I got from avrdude. The results where in a bin file.
Command : avrdude -c avrispmkII -p m2560 -P usb -U efuse:r:ext:r
Result : 0xFD
Command : avrdude -c avrispmkII -p m2560 -P usb -U hfuse:r:high:r
Result : 0xD8
Command : avrdude -c avrispmkII -p m2560 -P usb -U lfuse:r:low:r
Result : 0xFF
Any hint ?
I don't know avrdude a lot, but I think this information may be more useful. Using the command : avrdude -c avrispmkII -p m2560 -P usb -v
I got :
-----------------Begin-----------------
avrdude: Version 5.11, compiled on Sep 2 2011 at 19:38:36
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "C:\WinAVR-20100110\bin\avrdude.conf"
Using Port : usb
Using Programmer : avrispmkII
avrdude: usbdev_open(): Found AVRISP mkII, serno: 000200012345
AVR Part : ATMEGA2560
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page
Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 10 8 0 no 4096 8 0 9000 90 00 0x00 0x00
flash 65 10 256 0 yes 262144 256 1024 4500 45 00 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 90 00 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 90 00 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 90 00 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 90 00 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : STK500V2
Description : Atmel AVR ISP mkII
Programmer Model: AVRISP mkII
Hardware Version: 0
Firmware Version Master : 1.17
Vtarget : 3.3 V
SCK period : 8.00 us
Reading | ################################################## | 100% 0.05s
avrdude: Device signature = 0x1e9801
avrdude: safemode: lfuse reads as FF
avrdude: safemode: hfuse reads as D8
avrdude: safemode: efuse reads as FD
avrdude: safemode: Fuses OK
avrdude done. Thank you.
-----------------End-----------------
Hopping this may be helpful !
The fuses look OK.
I just tried my Mega2560 with the ASCII table example. Re-opening the serial monitor resets the program, but it seems to start instantly.
There is something wrong with your hardware, I suggest. Noise (or lack of pull-up resistors) between the Atmega16U2 and the Atmega2560, or maybe the wrong crystal, or it isn't oscillating correctly. Also make sure you have decoupling capacitors.
I checked both crystal using my oscilloscope, everything appears to be normal. I used the same crystal with the same resistor as the Arduino board (CSTCE16M0V53-R0 16MHZ (built-in capacitor) with 1M ohm resistor). The blink program makes the LED blink at the exact timing (1000 ms on, 1000 ms off).
I tried to program the 16U2 using the hex file on my Uno and its fuses settings, no improvement. Always exactly 9,5 seconds (within the precision of me using a chronograph !).
I may have missed something... If someone has an idea, I'm listening :slight_smile:
I would try two things in your shoes.
  1. Change the fuse to enable clock output. Then put a scope or logic analyzer on the clock output pin.
  2. Put a scope or logic analyzer on the main Tx/Rx pins and see if there is activity on them during those 9 seconds.
Thank Nick for your help, it's greatly appreciated.
  1. I tried the CKOUT Fuse and watch the CLKO with my oscilloscope. Everything is normal, the clock is constant and always working. No problem there.
  2. There is absolutely no activity on either Rx/Tx pins except what I described before (which is happening in the firsts 15 ms).
gabidanpremier:
At 16 MHz?
Yes, 16,03 MHz (62.4 ns period).
Can you run my sketch here please, and copy and paste the output? (in code tags)
I can do that !
130128-Output-Atmega_Board_Detector.txt (29.8 KB)
You seem to have this bootloader, based on the MD5 sum:
stk500v2
23d339e0ba55f179dd02e0e29d736991 *stk500boot_v2_mega2560.hex
Loader start: 3E000, length: 8192
MD5 sum = 1E 35 14 08 1F 65 7F 8C 96 50 69 9F 19 1E 3D F0
Board name in IDE: Arduino Mega 2560 or Mega ADK
Could you install this newer one?
// File =  stk500boot_v2_mega2560_fixes_watchdog_problem.hex
// Loader start: 3E000, length: 8192
// MD5 sum = 8A F4 7A 29 43 A0 D8 7C DB ED 09 A3 8F 40 24 1E
// https://github.com/arduino/Arduino-stk500v2-bootloader/blob/master/goodHexFiles/stk500boot_v2_mega2560.hex
How do you know this anyway? Can you post the code for the sketch you are running?
You're right, I didn't install the one you asked me before sending the text file. For now, I installed this one :
The result is attached with this post.
For the 9,5 seconds, I first remarked it using « SerialCallResponse ». There was a 9,5 seconds between the opening of the serial monitor and the start of the program (and the reception of the first character). Now, I'm just using « Blink » since I can just watch the L LED (pin 13). If I plug the USB cable (or any other power source), the LED starts blinking right away, but when I start the serial monitor there's this 9,5 seconds delay.
130128v2-Output-Atmega_Board_Detector.txt (29.8 KB)
What if you upload something like the ASCII code chart sketch. Test it. Then hit reset on the board and see if the sketch does its stuff again instantly.
gabidanpremier:
Can you describe or draw exactly what you have connected to the reset pin, in particular in the way it connects to the USB chip (and indeed any wiring to it at all)?
I'm sending a part of my circuit schematic. It's almost exactly the same as of the Arduino Mega2560.
I tried something. I used SerialCallResponseASCII. I programmed it and opened the serial monitor. Within the delay (9,5 seconds), I've reset the chip by pulling the reset pin on my 3x2 headers to ground. The programmed started right away and the serial monitor began to show me data, as expected.
So I think there's a link between the request for a reset from the 16U2 and the 9,5 seconds delay.
