serial connectivity
\hello i have a vb code and im trying to make arduino so stuff when recives "camera" or "lights"
my code:
char input;
void setup(){
  pinMode(2, OUTPUT);
void loop(){
  if (Serial.available() > 0) {
      input = Serial.read();
      if(input = "camera"){
        digitalWrite(2, HIGH);
        delay(50)
        digitalWrite(2, LOW);
gives
error: invalid conversion from 'char' to 'char*' :cry:
Serial.read() reads one byte only.
Note that something like
xx == "string"
is not a C concept. C ist not very much aware of strings and you have to do all string handling in the non-BASIC way :wink:
so i need to make it send 1 or 2 instead of camera or lights?
Thanks
--edit
int input;
void setup(){
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
void loop(){
      if(input = 1){
        delay(50);
        if(input = 2){
        digitalWrite(3, HIGH);
        delay(50);
        digitalWrite(3, LOW);
no matter what i send to arduino it blinks both ???
if(input = 1){
This is an assignment, not a comparison and its result will always be true.
i knew it :wink:
i knew somthing wass smelly :stuck_out_tongue:
----edit===
void loop(){
      if(input = 3){
        delay(50);
        if(input = 2){
        delay(50);
still doesnt work triggers all of them :S
if(input = 3){
This is an assignment (=), not a comparison (==) and its result will always be true.
Hint: = - Arduino Reference versus http://arduino.cc/en/Reference/If
Andrew
