Topic: Help with error messages when uploading (Read 155 times) previous topic - next topic
nickevasion
Hi I've been having trouble uploading sketches to my Leonardo. It was working fine about a week ago, but now whenever I upload a sketch, I get this error message
Code: [Select]
Global variables use 149 bytes (5%) of dynamic memory, leaving 2411 bytes for local variables. Maximum is 2560 bytes.
Forcing reset using 1200bps open/close on port COM11
PORTS {COM11, } / {} => {}
PORTS {} / {COM11, } => {COM11, }
Found upload port: COM11
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega32u4 -cavr109 -PCOM11 -b57600 -D -Uflash:w:C:\Users\Nick\AppData\Local\Temp\arduino_build_735511/Blink.ino.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM11
         Using Programmer              : avr109
         Overriding Baud Rate          : 57600
         AVR Part                      : ATmega32U4
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  9000  9000 0x00 0x00
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : butterfly
         Description     : Atmel AppNote AVR109 Boot Loader
Connecting to programmer: .avrdude: butterfly_recv(): programmer is not responding
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
The troubleshooting guide didn't really help at all.
As I've been using arduino for maybeeee 2 weeks now, this is very confusing and frustrating. What is a
.avrdude? Why is it mad at the butterflies?
Now when i upload code to my UNO, i get a similar error message, but the code is uploaded. The IDE will noT let me copy this code, because it ends up uploading onto the arduino. I have included the error (not error?) messages for the UNO as screenshots in the attachments.
(please do not spam "THIS IS THE WRONG POSTING PROCEDURE READ THIS POST LOSER DURRRRRRRRRRRRRFJSDKHFJKSDGNKJ" if i should include this in another way.)
I would really appreciate some help on this. should I reinstall the IDE? Buy a new Leonardo? Get a new cable?
Please & Thank you
-Nick
spycatcher2k
Quote
If you did follow the rules then OK - But you don't (And make yourself look like a self entitled moron doing so)
You  are in the wrong section
You posted error messages as images
When you see : Forcing reset using 1200bps open/close on port COM11
Tap the RESET button.
http://www.uk-pcb.co.uk - UK Based PCB Fab Company
I will code for you, but I will also charge you (PM me)
If you don't like my answers, realize : I'm not being cheeky, I'm Just trying to prompt you to use your own brain/google etc.
nickevasion
Damn haha i'll get it right next time sorry guys
Ok so i hit reset, and got this error message
Code: [Select]
Arduino: 1.8.5 (Windows 10), Board: "Arduino Leonardo"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Nick\Documents\Arduino\libraries -fqbn=arduino:avr:leonardo -vid-pid=0X2341_0X8036 -ide-version=10805 -build-path C:\Users\Nick\AppData\Local\Temp\arduino_build_735511 -warnings=none -build-cache C:\Users\Nick\AppData\Local\Temp\arduino_cache_831242 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Program Files (x86)\Arduino\examples\01.Basics\Blink\Blink.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Nick\Documents\Arduino\libraries -fqbn=arduino:avr:leonardo -vid-pid=0X2341_0X8036 -ide-version=10805 -build-path C:\Users\Nick\AppData\Local\Temp\arduino_build_735511 -warnings=none -build-cache C:\Users\Nick\AppData\Local\Temp\arduino_cache_831242 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Program Files (x86)\Arduino\examples\01.Basics\Blink\Blink.ino
Using board 'leonardo' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_LEONARDO -DARDUINO_ARCH_AVR  -DUSB_VID=0x2341 -DUSB_PID=0x8036 '-DUSB_MANUFACTURER="Unknown"' '-DUSB_PRODUCT="Arduino Leonardo"' "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\leonardo" "C:\Users\Nick\AppData\Local\Temp\arduino_build_735511\sketch\Blink.ino.cpp" -o "nul"
Generating function prototypes...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_LEONARDO -DARDUINO_ARCH_AVR  -DUSB_VID=0x2341 -DUSB_PID=0x8036 '-DUSB_MANUFACTURER="Unknown"' '-DUSB_PRODUCT="Arduino Leonardo"' "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\leonardo" "C:\Users\Nick\AppData\Local\Temp\arduino_build_735511\sketch\Blink.ino.cpp" -o "C:\Users\Nick\AppData\Local\Temp\arduino_build_735511\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\Nick\AppData\Local\Temp\arduino_build_735511\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega32u4 -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_LEONARDO -DARDUINO_ARCH_AVR  -DUSB_VID=0x2341 -DUSB_PID=0x8036 '-DUSB_MANUFACTURER="Unknown"' '-DUSB_PRODUCT="Arduino Leonardo"' "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\leonardo" "C:\Users\Nick\AppData\Local\Temp\arduino_build_735511\sketch\Blink.ino.cpp" -o "C:\Users\Nick\AppData\Local\Temp\arduino_build_735511\sketch\Blink.ino.cpp.o"
Compiling libraries...
Compiling core...
Using precompiled core
Linking everything together...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega32u4  -o "C:\Users\Nick\AppData\Local\Temp\arduino_build_735511/Blink.ino.elf" "C:\Users\Nick\AppData\Local\Temp\arduino_build_735511\sketch\Blink.ino.cpp.o" "C:\Users\Nick\AppData\Local\Temp\arduino_build_735511/..\arduino_cache_831242\core\core_arduino_avr_leonardo_0c812875ac70eb4a9b385d8fb077f54c.a" "-LC:\Users\Nick\AppData\Local\Temp\arduino_build_735511" -lm
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0  "C:\Users\Nick\AppData\Local\Temp\arduino_build_735511/Blink.ino.elf" "C:\Users\Nick\AppData\Local\Temp\arduino_build_735511/Blink.ino.eep"
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-objcopy" -O ihex -R .eeprom  "C:\Users\Nick\AppData\Local\Temp\arduino_build_735511/Blink.ino.elf" "C:\Users\Nick\AppData\Local\Temp\arduino_build_735511/Blink.ino.hex"
Sketch uses 4128 bytes (14%) of program storage space. Maximum is 28672 bytes.
         Using Port                    : COM11
avrdude: ser_open(): can't open device "\\.\COM11": The system cannot find the file specified.
avrdude done.  Thank you.
spycatcher2k
Cool -
Quote
I'm not a Guy!  :o
double tap the reset button (Bootload LED should pulse) and hit upload, see if that helps.
Next : Try a reboot of your computer.
nickevasion
Code: [Select]
PORTS {COM12, } / {COM12, } => {}
PORTS {COM12, } / {} => {}
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega32u4 -cavr109 -PCOM11 -b57600 -D -Uflash:w:C:\Users\Nick\AppData\Local\Temp\arduino_build_235042/Blink.ino.hex:i
         Using Port                    : COM11
         PAGEL                         : PD7
         BS2                           : PA0
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
Connecting to programmer: .avrdude: ser_recv(): read error: The I/O operation has been aborted because of either a thread exit or an application request.
avrdude: ser_recv(): read error: The device does not recognize the command.
avrdude: ser_drain(): read error: The device does not recognize the command.
avrdude: ser_send(): write error: sorry no info avail
Found programmer: Id = "&"; type = @
    Software Version = ˆ.u; Hardware Version = ".ð
avrdude: error: buffered memory access not supported. Maybe it isn't
a butterfly/AVR109 but a AVR910 device?
avrdude: initialization failed, rc=-1
         Double check connections and try again, or use -F to override
         this check.
the selected serial port avrdude: butterfly_recv(): programmer is not responding
 does not exist or your board is not connected
avrdude: error: programmer did not respond to command: leave prog mode
avrdude: error: programmer did not respond to command: exit bootloader
