Topic: Arduino Leonardo Only Recognizes One Button Out of Thirty Buttons. Please Help (Read 103 times) previous topic - next topic
coolengineer
I trying to figure this out but I'm still new to this whole thing.  Here is the Sketch that I am using.
Quote
#include <Keypad.h>
#include <Joystick.h>
#define ENABLE_PULLUPS
#define NUMROTARIES 5
#define NUMBUTTONS 30
#define NUMROWS 7
#define NUMCOLS 5
byte buttons[NUMROWS][NUMCOLS] = {
  {0,1,2,3,4},
  {5,6,7,8,9},
  {10,11,12,13,14},
  {15,16,17,18,19},
  {20,21,22,23,24},
  {25,26,27,28,29},
  {30,31,32,33,34}
struct rotariesdef {
  byte pin1;
  byte pin2;
  int ccwchar;
  int cwchar;
  volatile unsigned char state;
rotariesdef rotaries[NUMROTARIES] {
  {12,13,35,36,0},
  {14,15,37,38,0},
  {16,17,39,40,0},
  {18,19,41,42,0},
#define DIR_CCW 0x10
#define DIR_CW 0x20
#define R_START 0x0
#ifdef HALF_STEP
#define R_CCW_BEGIN 0x1
#define R_CW_BEGIN 0x2
#define R_START_M 0x3
#define R_CW_BEGIN_M 0x4
#define R_CCW_BEGIN_M 0x5
const unsigned char ttable[6][4] = {
  // R_START (00)
  {R_START_M,            R_CW_BEGIN,     R_CCW_BEGIN,  R_START},
  // R_CCW_BEGIN
  {R_START_M | DIR_CCW, R_START,        R_CCW_BEGIN,  R_START},
  // R_CW_BEGIN
  {R_START_M | DIR_CW,  R_CW_BEGIN,     R_START,      R_START},
  // R_START_M (11)
  {R_START_M,            R_CCW_BEGIN_M,  R_CW_BEGIN_M, R_START},
  // R_CW_BEGIN_M
  {R_START_M,            R_START_M,      R_CW_BEGIN_M, R_START | DIR_CW},
  // R_CCW_BEGIN_M
  {R_START_M,            R_CCW_BEGIN_M,  R_START_M,    R_START | DIR_CCW},
#else
#define R_CW_FINAL 0x1
#define R_CW_NEXT 0x3
#define R_CCW_BEGIN 0x4
#define R_CCW_FINAL 0x5
#define R_CCW_NEXT 0x6
const unsigned char ttable[7][4] = {
  // R_START
  {R_START,    R_CW_BEGIN,  R_CCW_BEGIN, R_START},
  // R_CW_FINAL
  {R_CW_NEXT,  R_START,     R_CW_FINAL,  R_START | DIR_CW},
  // R_CW_BEGIN
  {R_CW_NEXT,  R_CW_BEGIN,  R_START,     R_START},
  // R_CW_NEXT
  {R_CW_NEXT,  R_CW_BEGIN,  R_CW_FINAL,  R_START},
  // R_CCW_BEGIN
  {R_CCW_NEXT, R_START,     R_CCW_BEGIN, R_START},
  // R_CCW_FINAL
  {R_CCW_NEXT, R_CCW_FINAL, R_START,     R_START | DIR_CCW},
  // R_CCW_NEXT
  {R_CCW_NEXT, R_CCW_FINAL, R_CCW_BEGIN, R_START},
#endif
byte rowPins[NUMROWS] = {0,1,2,3,4};
byte colPins[NUMCOLS] = {5,6,7,8,9};
Keypad buttbx = Keypad( makeKeymap(buttons), rowPins, colPins, NUMROWS, NUMCOLS);
Joystick_ Joystick(JOYSTICK_DEFAULT_REPORT_ID,
  JOYSTICK_TYPE_JOYSTICK, 44, 0,
  false, false, false, false, false, false,
  false, false, false, false, false);
  Joystick.begin();
  rotary_init();}
  CheckAllEncoders();
  CheckAllButtons();
void CheckAllButtons(void) {
      if (buttbx.getKeys())
       for (int i=0; i<LIST_MAX; i++)
           if ( buttbx.key.stateChanged )
            switch (buttbx.key.kstate) {
                    case PRESSED:
                    case HOLD:
                              Joystick.setButton(buttbx.key.kchar, 1);
                    case RELEASED:
                    case IDLE:
                              Joystick.setButton(buttbx.key.kchar, 0);
void rotary_init() {
  for (int i=0;i<NUMROTARIES;i++) {
    pinMode(rotaries.pin1, INPUT);
    pinMode(rotaries.pin2, INPUT);
    #ifdef ENABLE_PULLUPS
      digitalWrite(rotaries.pin1, HIGH);
      digitalWrite(rotaries.pin2, HIGH);
    #endif
unsigned char rotary_process(int _i) {
   unsigned char pinstate = (digitalRead(rotaries[_i].pin2) << 1) | digitalRead(rotaries[_i].pin1);
  rotaries[_i].state = ttable[rotaries[_i].state & 0xf][pinstate];
  return (rotaries[_i].state & 0x30);
void CheckAllEncoders(void) {
    unsigned char result = rotary_process(i);
    if (result == DIR_CCW) {
      Joystick.setButton(rotaries.ccwchar, 1); delay(50); Joystick.setButton(rotaries.ccwchar, 0);
    if (result == DIR_CW) {
      Joystick.setButton(rotaries.cwchar, 1); delay(50); Joystick.setButton(rotaries.cwchar, 0);
coolengineer
I have everything else all wired up in a 7x5 matrix pattern, if that helps.  I also put in one diode per switch to prevent ghosting.  Hope this helps.
DrAzzy
How are the diodes wired? Did you get them the wrong way by any chance?
ATtiny core for 841+1634+828 and x313/x4/x5/x61/x7/x8 series Board Manager:
http://drazzy.com/package_drazzy.com_index.json
ATtiny breakouts (some assembled), mosfets and awesome prototyping board in my store http://tindie.com/stores/DrAzzy
coolengineer
Ya, that was the first thing that I checked.  All of the diodes are facing the correct way.  And the diode are soldered directory to the switches, then I snipped off any extra length so that way I don't have any bare wires touching other wires.
coolengineer
Never Mind I figured it out.  It turned out it was a coding issue.  (Facepalm)
