Hello
Sorry for my English.
I need advice.
What used to Arduino.
I need to set it up so that when power on, it starts to send this:
00
delay: 10
F403213BED
delay: 100
F403213BED
delay: 100
F403213BED
delay: 100
F403213BED
delay: 100
F403213BED
delay: 100
F403213BED
delay: 100
F403213BED
delay: 100
F403213BED
delay: 100
F403213BED
delay: 100
F403213BED
delay: 100
and when the supply is to be sent
34021026
sending one wire
baud rate 2400
parity: EVEN
data bits: 8
stop bit: 1
I think your question is not clear and ambiguous at best. So here is a sketch that does exactly what you ask but is probably not what you need. On the other hand it is easy to adjust to one of the variations you might have meant.
Spending time on a properly phrased question which includes context of the project saves in the end time for everyone, google translate can help with translating the language to English.
Google translator use
but I'll try to write more specifically.
I need to send in a single device command to start and it should be in a binary system
Now it works with your PC via com port smear and where you're sending data
but I need an external data source to which one to bring the power sends the sequence
Although the timing has changed quite a bit (10,100 milliseconds -> 2, 8 seconds), and the amount of messages (10->5), you are telling more now, thank you.
The code below is not ready yet, you need to fix the last issues...
Serial.begin(2400);
Serial.write(0x00); // NOTE THE PRINTLN HAS BECOME A WRITE - READ DOCUMENTATION WHY
delay(????); // NOTE DELAY USES MILLISECONDS
for (int i=0; i<10; i++) // CHANGE THE COUNTER UPPER VALUE TO YOUR NEED
Serial.write(0xF4);
Serial.write(0x03);
Serial.write(0x21);
Serial.write(0x3B);
Serial.write(0xED);
delay(????);
Serial.println("34021026"); // LEFT AS AN EXERCISE TO REWRITE
// does nothing
This thread is so strange I did a google for "F403213BED" and only got one page. It's in Russian and a google translation of the advice given there is:
Re: Timer 1533 Webasto analysis work.
[quote = [G] Smit; 699625 ] It is impossible to put together a package similar to this if we start from the assembly as listed above is a small package is obtained . [/ quote]
... not really small, but wrong .
The heading "hx34" Webasto " will not lead " checked . Should be sent "F4", and when you expect an answer from her - "4F" should come in the header. And nothing else !!!
Popobuy send Hercules H "f403213bed", only the port settings correctly set ... I start; )
