Some compilers can use multicore PC processors when the make calls them with the -j option. This makes compilation much faster. Can the Arduino IDE be made to insert this option?
Thanks!
Thanks!
-j is a make flag, not a compiler flag. make will run multiple compilers, if it can.
Given how small embedded files are and how optimized avr-gcc is, I'm not sure you'd see a significant difference with multiple files being compiled simultaneously. You aren't compiling a linux kernel.
The linker (and everything after it) only runs once anyway and the "compile/upload" time is almost entirely dominated by the upload time anyway.
mbeach:
There isn't any code in Arduino to do this, but of course the entire IDE code is open source, so in theory anyone could add the code.
I have actually considered doing this....
One tough problem is how to detect the number of simultaneous compiler jobs that should be run. Even if a computer has a dual or quad core processor doesn't necessarily mean it has enough non-vitual RAM (after Arduino/Java's considerable memory use) or a fast enough disk. On underpowered PC, running 2 or more at the same time could be much, much slower.
