Eccola aggiornata (però non iniziamo ad andare sul difficile), dovrebbe essere una lista per principianti !!!! (75176 - per implementare il bus RS485)
CD4017 - CMOS COUNTER/DIVIDERS
CD4021 - 8-Stage Static Shift Register
CD4066 - CMOS QUAD BILATERAL SWITCH
CD4051 - CMOS Analog Multiplexers/Demultiplexers with Logic Level Conversion
CD4067 - CMOS Analog Multiplexers/Demultiplexers
74HC595 - 8 BIT SHIFT REGISTER WITH OUTPUT LATCHES 3 STATE
MAX7219/21 - Serially Interfaced, 8-Digit LED Display Driver
MAX232 - +5V-Powered, Multichannel RS-232 Drivers/Receivers
ULN2803 - EIGHT DARLINGTON ARRAYS
SN754410NE - Quadruple Half-H Drivers
24LC256 - CMOS Serial EEPRO
4N35 - FOTOTRANSISTORE OPTOCOULERS
LM317 - Voltage Regulator
LM358 - Single Supply Dual Operational Amplifier
LM386 - Low Voltage Audio Power Amplifier
LM3914/15 - Dot/Bar Display Drive (0-5V - 0-10V)
DS1307 - Serial Real-Time Clock
PCF8574P - Remote 8-bit I/O expander for I2C-bus
TLC5941 - 16-CHANNEL LED DRIVER WITH DOT CORRECTION AND GRAYSCALE PWM CONTROL
NE555 - SINGLE BIPOLAR TIMERS
L293 - PUSH-PULL FOUR CHANNEL DRIVER WITH DIODES
74LS165 PISO - (Parallel In - Serial Out) - legge 8 ingressi e restituisce 1 byte
PCF8563 - altro RTC
MCP1700-330 - regolatore di tensione 3V3
LM7805/LM7809/LM7812 - regolatori 5/9/12V
LM324N - amplificatore operazionale
74HC125 - buffer 3-state
