I am trying to make a remote control fan and so far it works fine. But my problem is I want my cases to run constantly until the next case is called. I am using an IR sensor to take the input from the remote. The problem I have now is once I touch the button on the remote the case only runs once I want it to run continuously until the next case is called. My code is at the bottom does anyone have any suggestions?
#include <Servo.h>
#include <IRremote.h>
Servo myservo;
int pos = 0;
int RECV_PIN = 11;
IRrecv irrecv(RECV_PIN);
decode_results results;
myservo.attach(9); // attaches the servo on pin 9 to the servo object
irrecv.enableIRIn(); // Start the receiver
if (irrecv.decode(&results)) {
Serial.println(results.value, HEX);
switch(results.value)
case 0x800F8401: //Case 1
// while (results.value == 0x800F8401)
for(pos = 0; pos < 180; pos += 1) // goes from 0 degrees to 180 degrees
{ // in steps of 1 degree
myservo.write(pos); // tell servo to go to position in variable 'pos'
delay(0); // waits 15ms for the servo to reach the position
for(pos = 180; pos>=1; pos-=1) // goes from 180 degrees to 0 degrees
//if (results.value = 0x800F8401){
break;
case 0x800F8402: //Case 2
//if (results.value == 0x800F8402)
//while(1)
//{if (results.value != 0x800F8402)
delay(20); // waits 15ms for the servo to reach the position
(irrecv.decode(&results));
break;
} irrecv.resume();
break;
case 0x800F8403: //Case 3
delay(15); // waits 15ms for the servo to reach the position
break;
case 0x800F8404: //Case 4
delay(10); // waits 15ms for the servo to reach the position
break;
irrecv.resume();
Save yourself some keystrokes - factor all these into a single function.
You're currently only executing your switch statement when something is detected from the remote. Run it unconditionally; you may need to save the response from the remote when you do get it in another variable that drives the switch.
It really isn't all that far from being C.
Why don't you make a start, and get back to us when you get stuck?
Don't forget to use tags when you post it.
Some clues:
These numbers int stateDelay[] = {0, 20, 15, 10}; are found in places like this
I do not understnd the Psuedo code. Are there any other methods to get what i want done. i dont understand why i cant use a while 1 loops in each case. could some one give me some explanations please
do I have to make if statements for every possible case. I saw youu used delay(stateDelay[currentState]);. is it possible to use something like that in if statements.
I'm sorry, I don't understand your question.
There is now very little now for you to write, and most of it could be done by hacking away completely big chunks of your original code.
Edit: The sketch you posted above is about 100 lines long. My guess is that the rewritten one will be no more than about 70 lines. If you get rid of the switch/case and do a table lookup instead, probably fewer than 60 lines.
myservo.write(currentPosition)
i dont understand what that part of the code does can u explain it. I know i am asking for alot but i am just tring to understand
What we're trying to do is to make the system look like it is doing more than one thing at a time, by breaking down what it is doing into tiny steps that individually take a very short time to execute.
So in your original code, the two big for loops could take a maximum of 180 x 2 x 20 milliseconds to execute, or about 7 seconds.
During this time, the system would appear unresponsive, because it would have to complete a movement before it checked the IR input again.
Now, we're going to check the IR input every time through "loop()", but nothing inside "loop()" is going to take more than 20 milliseconds (give-or-take) to execute.
So, we're going to:
check IR,
move a little bit,
check IR,
move a litle bit,
check IR - got something! set a new state (that's is ALL you have to do),
move a little bit.
and so on.
myservo.write(currentPosition);
You know what that does, I'm not going to explain.
"currentState" has a value of 0..4 (or however many you want), so we pick a corresponding value from the array "stateDelay" to use as our delay.
For bonus marks later, we're going to get rid of "delay" altogether.
