Hi all. Fist let me say I am very new to all this so If I am asking a dumb question forgive me.
I have been trying all day to program an atTiny84 with a 3x3 LED cube sketch i found, an I am having no luck. I have a post in the forum and some one was kind enough to send me a link to this post.
This is the sketch I am trying to use:
ledcube.pde - Example sketch for controlling an LED cube.
Created by Gamaiel Zavala (gzip), 2009-2012
MIT License. See accompanying LICENSE file for terms.
#include <LedCube.h>
#define SIZE 3
#define COLS (SIZE*SIZE)
byte levelPins[SIZE] = {2,3,4};
byte colPins[COLS] = {0,1,5,6,7,8,9,10};
LedCube cube(SIZE, levelPins, colPins);
void setup ()
void loop ()
delay(10);
// light each light one at a time
for(byte level=0; level<cube.getLevels(); level++)
for(byte col=0; col<cube.getCols(); col++)
cube.lightPulse(level, col, 100);
// light one level at a time, increasing speed each time
for(byte d=25; d>2; d-=2)
for(byte l=1; l <= cube.getLevels(); l++)
cube.lightLevel(l, d);
// light each row on each level
for(byte level=1; level<=cube.getLevels(); level++)
for(byte row=1; row<=cube.getLevels()*2; row++)
cube.lightRow(row, level);
// light each plane
for(byte i=3; i; i--)
cube.lightPlane(row, 10*i);
// single random light at a time
cube.randomLight(random(25,100),100);
// random column drop
for(byte x=0; x<=15; x++)
cube.lightDrop(random(0,cube.getCols()), random(50,150));
// circle around cube at a random level
for(byte x=0; x<=5; x++)
cube.lightPerimeter(random(0,cube.getLevels()), random(1,5), random(25,100));
// light each face
byte planes[] = {cube.getLevels()+1,cube.getLevels(),cube.getLevels()*2,1};
for(byte i=5; i; i--)
for(byte p=0; p<sizeof(planes); p++)
cube.lightPlane(planes[p], 5*i);
// random columns
cube.randomColumn(25);
// turn off a single column randomly
cube.enableBuffer();
for(byte c=0; c<30; c++)
cube.fillBuffer();
cube.invertBuffer();
cube.randomColumn();
cube.drawBuffer(7);
cube.enableBuffer(false);
// cols in and out
for(byte c=1, d=0; c<=10; c++)
if(c%2 == 0)
for(d=0; d<20; d++)
cube.lightColumn(2,1);
cube.lightColumn(4,1);
cube.lightColumn(6,1);
cube.lightColumn(8,1);
else if(c%4 == 1)
for(d=0; d<30; d++)
cube.lightColumn(1,1);
cube.lightColumn(3,1);
cube.lightColumn(7,1);
cube.lightColumn(9,1);
for(d=0; d<70; d++)
cube.lightColumn(5,1);
// diamond and box
byte diamond[] = {0,4, 1,1, 1,3, 1,4, 1,5, 1,7, 2,4};
byte box[] = {
2,0, 2,1, 2,2, 2,3, 2,5, 2,6, 2,7, 2,8,
1,0, 1,2, 1,6, 1,8,
0,0, 0,1, 0,2, 0,3, 0,5, 0,6, 0,7, 0,8
cube.lightSequence(box, sizeof(box), 200);
cube.lightSequence(diamond, sizeof(diamond), 400);
// helicopter effect
byte topSeq[8] = {0,3,6,7,8,5,2,1};
byte botSeq[8] = {8,5,2,1,0,3,6,7};
for(byte loops = 0, delay = 50; loops<=8; loops++)
for(byte s=0; s<8; s++)
byte seq[] = {2,topSeq[s], 1,4, 0,botSeq[s]};
cube.lightSequence(seq, sizeof(seq), delay);
if(loops < 5) delay-=10; else delay += 10;
// turn off one light at a time
cube.fillBuffer();
cube.drawBuffer(25);
for(byte w=0, l, c, max = cube.getNumLights(); w<max; )
// lower bound is inclusive, upper is exclusive
l = random(0, cube.getLevels());
c = random(0, cube.getCols());
if(cube.getBufferAt(l,c) == HIGH)
cube.lightOff(l,c);
cube.drawBuffer(5);
w++;
And this is the Error I get.
c:/arduino-1.0.1/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/../../../../avr/lib/avr25/crttn84.o: In function `__vector_default':
(.vectors+0x16): relocation truncated to fit: R_AVR_13_PCREL against symbol `__vector_11' defined in .text.__vector_11 section in core.a(wiring.c.o)
c:/arduino-1.0.1/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/../../../../avr/lib/avr25/crttn84.o:(.init9+0x0): relocation truncated to fit: R_AVR_13_PCREL against symbol `main' defined in .text.main section in core.a(main.cpp.o)
c:/arduino-1.0.1/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/../../../../avr/lib/avr25/crttn84.o:(.init9+0x2): relocation truncated to fit: R_AVR_13_PCREL against symbol `exit' defined in .fini9 section in c:/arduino-1.0.1/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/avr25\libgcc.a(_exit.o)
core.a(WMath.cpp.o): In function `randomSeed(unsigned int)':
C:\Users\techsupport\Documents\Arduino\hardware\tiny\cores\tiny/WMath.cpp:33: relocation truncated to fit: R_AVR_13_PCREL against symbol `srandom' defined in .text section in c:/arduino-1.0.1/hardware/tools/avr/bin/../lib/gcc/avr/4.3.2/../../../../avr/lib/avr25\libc.a(random.o)
I downloaded the zip file form this post and copied it to my hardware folder but still no luck.
Help. It's driving me mad.
Thanks
