Thanks for the prompt response! The rate is 115200. I am using the USB port of a Dell Optiplex 755 which is the same hardware I was using previously with the Duemilanove. Here is the source code:
#include <Spi.h>
// Melexis definitions
#define MLX_START_BIT 0x80
#define MLX_RESET_PIN 8
#define MLX_ERRB_PIN 9
#define SER_READ_DELAY 10 // in microseconds
#define GAUGE_LOOKUP { 0x00, 0x10, 0x30, 0x40, 0x60, 0x50 }
#define OP_ZERO_GAUGE 0x0
#define OP_R_U_THERE 0x1
#define OP_SET_GAUGE 0x2
#define OP_DEBUG 0x7
#define ACK_CODE_BIT 0x80
#define RC_OK 0X00
#define RC_ERR_UOP 0x01 // Unknown op code received
#define RC_ERR_MDATA 0x02 // Missing expected data packets
#define RC_ERR_OP_WDATA 0x03 // Wrong number of data packets for op
#define RC_ERR_INV_METR 0x04 // Invalid meter or gauge specified
const byte gauge_lookup_tbl[6] = GAUGE_LOOKUP;
int data = 2;
int clock = 3;
int latch = 4;
int debug = 0;
int var = 0;
byte spi_config = 0;
pinMode(MLX_RESET_PIN, OUTPUT);
pinMode(MLX_ERRB_PIN, INPUT);
pinMode(data, OUTPUT);
pinMode(clock, OUTPUT);
pinMode(latch, OUTPUT);
var = digitalRead(MLX_ERRB_PIN);
digitalWrite(MLX_RESET_PIN, HIGH);
delayMicroseconds(8000);
SPSR &= B11111110; // 0th bit is SPIX2
spi_config |= (1 << SPE) | (1 << MSTR) | (1 << SPR0);
Spi.mode(spi_config);
byte cmd = 0, dataPackets = 0, data[3];
int rc = RC_OK, val = 0, gaugeNum = 0;
data[0] = 0; data[1] = 0; data[2] = 0;
if (Serial.available()) {
cmd = Serial.read();
updateLEDs(cmd);
if (cmd == -1) return; // If nothing read no need to continue
dataPackets = (cmd >> 3) & 0x3;
switch(cmd >> 5) {
case OP_SET_GAUGE:
gaugeNum = cmd & 0x3;
if (dataPackets != 2)
rc = RC_ERR_OP_WDATA;
else if (gaugeNum < 1 || gaugeNum > 5)
rc = RC_ERR_INV_METR;
else {
rc = readDataBytes(data, dataPackets);
if (rc == RC_OK) {
val = data[0] << 8 | data[1];
setGauge(gaugeNum, val);
// TODO: Check pin ERRB on melexis to detect errors and return them
//sendAck(RC_OK);
break;
case OP_ZERO_GAUGE:
if (dataPackets != 0)
initMainLogometers();
break;
case OP_R_U_THERE:
break;
case OP_DEBUG:
debug = 1;
break;
default:
rc = RC_ERR_UOP;
break;
sendAck(rc);
int readDataBytes(byte *data, int count) {
int i = 0, readCount = 0;
byte cmd;
for (i = 0; i < count; i++) {
do {
data = Serial.read();
- readCount++;*
_ if (data == -1)_
* delayMicroseconds(SER_READ_DELAY);
_ else*_
* break;*
* } while (readCount < 10);*
_ if (data == -1)
* return RC_ERR_MDATA;*
* }_
return RC_OK;
_}
void sendAck(int errCode) {
byte cmd = 0;*_
* cmd = ACK_CODE_BIT | (errCode & 0x7f);
_ Serial.write(cmd);
void setGauge(int gauge, int val) {
int quad = 0, offset = 0;*_
* quad = 0x3 & (3 + (val/512));*
* offset = val % 512;*
* sendByComp(gauge, quad, offset);*
void initMainLogometers () {
* int i = 0, calDelay = 1000, quad = 0, offset = 0;*
* for (i = 200; i < 1500; i += 4) {*
* delayMicroseconds(calDelay);*
* quad = 0x3 & (3 + (i/512));*
* offset = i % 512;*
* sendByComp(1, quad, offset);*
* sendByComp(2, quad, offset);*
* for (i = 1500; i >= 200; i -= 4) {*
void sweepMainLogometers () {
* int i = 0, j = 0, calDelay = 2000;*
* for (j = 3; j < 7; j++) {*
* for (i = 0; i < 512; i++) {*
* sendByComp(1, 0x3&j, i);*
* sendByComp(2, 0x3&j, i);*
* for (j = 6; j >= 3; j--) {*
* for (i = 511; i >= 0; i--) {*
void sendByComp(int gauge, int quad, int val) {
* byte b1;*
* byte b2;*
* if (val < 0 || val > 511) {*
* pDataValidationError("Error valid quadrant table lookups are 0 to 511, received ", val);*
* return;*
* if (quad < 0 || quad > 3) {*
* pDataValidationError("Error valid quadrants are 0 to 3, received ", quad);*
* return;*
* b1 = MLX_START_BIT | gauge_lookup_tbl[gauge] | (val >> 5);
_ b2 = 0x00 | val << 3 | quad;*_
* digitalWrite(SS_PIN, HIGH);
_ Spi.transfer(b1);
Spi.transfer(b2);_
digitalWrite(SS_PIN, LOW);
_}
void pDataValidationError(char *msg, int val) {
Serial.print(msg);
Serial.print(val);
Serial.println();
void updateLEDs(int value){
digitalWrite(latch, LOW); //Pulls the chips latch low*
* shiftOut(data, clock, MSBFIRST, value); //Shifts out the 8 bits to the shift register*
* digitalWrite(latch, HIGH); //Pulls the latch high displaying the data*
}_
