Topic: SD card with Nodemcu 1.0 (Read 2456 times) previous topic - next topic
Sayed
Good day,
Any body successfully use sd card with nodemcu 1.0 (ESP8266-12E)? I have tried to connect sd card with arduino uno and it work fine but when i try with nodemcu through pins 12,13,14 and 15 as ss it dose not work,
Any body got experience in this?
IamFof
Firstly.  The Uno doesn't have pins 14 & 15.  So where are they actually connected?
Post a sketch or schematic showing exactly how you have it wired up.
Also post your complete code (using code tags)
Fof
Sayed
Dear Fof,
These pins is Nodemcu pin, that is why i said on arduino uno working fine but i face the problem with Nodemcu 1.0 (ESP8266-12E)
Where i map it as the following
Sayed
the problem solved,
for who is facing similar issue, they can use pins 12,13,14 and pin 4 instead of 15
and the sd card will work fine on NodeMCU
Nick_Pyner
Well, I soon will, as I have just bought an MCU. I am still utterly confused about the pins and their names, but I was going to use the green group of pins on the other side.
What did you do about powering the SD module? I have just found that neither of mine have 3.3v input, and I am looking at splitting a 5v supply to each board.
niktrychill
did anyone find a solution to this? I tried cs on pin 4. But it still doesn't work. Works on UNO but not on NodeMCU. Any suggestion?
Nick_Pyner
https://www.youtube.com/watch?v=yOffiDks4sY
