Thanks for the detailed post! I will let you know how I get along. Really appreciate it hopefully solves the problem I was encountering
@Lauszus, thank you very much. I've a new questions. I've an Arduino 1, and i would to buy a usb shield to add on this shield a BT dongle to use this with a PS3 controller. I noticed that apart from the shield you can mount imu, motors and encoders on arduino1, in case the shield would I need a new arduino? thanks
#batista1987
I'm not totally sure what you mean?
But yes use the USB Host shield (http://www.circuitsathome.com/products-page/arduino-shields/usb-host-shield-2-0-for-arduino) for Arduino Uno. All official Arduino are supported by the version 2 of the shield.
But the shield have to use two pins despite MISO, MOSI and SCK - 11,12, and 13 on a small Arduino (Uno, Duemilanove etc.). These are SS and INT. Normally they are located at pin 9 and 10, but can be rerouted to any I/O, see http://www.circuitsathome.com/usb-host-shield-hardware-manual at "Interface modifications".
Regards
Lauszus
@Lauszus, ok so USBSHIED use pin 9 and 10 of digital out (is true?).
Excuse me but is the first approach to arduino, and i've a problem to understand, so i've a new questions. The pin thah you use (apart IMU) on (Arduino1 for example) are:
PDO=pin0 leftA (is INA left out of driver motor?)
PD1=pin1 (is INB left out of driver motor?)
PB1= A4 (is INA right out of driver motor?)
PC5=A5 (is INB right out of driver motor?)
pin2= leftEcoder1
pin4=leftEncoder2
pin3=rightEncoder1
pin5=rightEncoder2
So apart the imu are these, right? Why you connect the right motor to a analog input?
I use a different imu (SparkFun IMU Fusion Board - ADXL345 & IMU3000 - SEN-10252 - SparkFun Electronics) that use a i2c protocol, and this imu is connected to a4,a5. Can i change
#define rightA PINC4 // PC4 - pin A4
#define rightB PINC5 // PC5 - pin A5
to
#define rightA PINC4 // PC3 - pin A3
#define rightB PINC5 // PC2 - pin A2
Regards
Batista1987
#batista1987
Yes the shield uses pin 9 and 10 normall. But I had to use pin 9 and 10 for 20kHz pwm output, so I rerouted them to pin 7 and 8.
Here is a list of the pins I used:
pin 0 (PD0) = left motor logic A - output
pin 1 (PD1) = left motor logic B - output
pin 2 (PD2) = fist encoder input A - input
pin 3 (PD3) = fist encoder input B - input
pin 4 (PD4) = second encoder input A - input
pin 5 (PD5) = second encoder input B - input
pin 6 (PD6) = buffer (used to indicated when finished calibration) - output
pin 7 (PD7) = INT of USB Host Shield - input
pin 8 (PB0) = SS of USB Host Shield - output
pin 9 (PB1) = left motor pwm (OC1A) - output
pin 10 (PB2) = right motor pwm (OC1B) - output
pin 11 (PB3) = MOSI for USB Host Shield - output
pin 12 (PB4) = MISO for USB Host Shield - input
pin 13 (PB5) = SCK for USB Host Shield - output
pin 14 - A0 (PC0) = gyro y-axis - input
pin 15 - A1 (PC1) = accelerometer x-axis - input
pin 16 - A2 (PC2) = accelerometer y-axis - input
pin 17 - A3 (PC3) = accelerometer z-axis - input
pin 18 - A4 (PC4) = right motor logic A - output
pin 19 - A5 (PC5) = right motor logic B - output
As you can see the reason why I the analog pin for the motor is because I had used all other pins - remember that an analog pin can also be used as a general I/O.
You could actually save two pin, as your IMU uses I2C while mine is analog. If I had to order a new one, I would also go for a digital IMU to save more pins.
There is no difference in the below:
to
You have only edited the comment NOT the pins definition. The right approach would be:
#define rightA PINC3 // PC3 - pin A3
#define rightB PINC2 // PC2 - pin A2
Regards
Lauszus
I'm trying to test the code of how to calculate the arctang that aparcere here http://dspguru.com/dsp/tricks/fixed-point-atan2-with-self-normalization and is used in this project, I'm testing with a calculator but I can not give a result not even like ... can someone please show me some input values ??and assume something that should out ..
GYROSCOPE DRIFT...???
Hi guys! I finally got my robot balancing... Far from perfectly but it stands up pretty well... Thanks to all for your help!
Just a query about the dreaded Gyroscope Drift!
Is it still an issue with modern gyroscopes?
I've mapped the output of the rate pin from my IMU on the serial monitor of the arduino program for over a 30 minute duration and I have failed to see any meaningful drift... The signal is noisy alright but there is no indication of a drifting from the set point while motionless!?
The IMU that I am using is a 3dof from Sparkfun and is now retired "IMU Combo Board - 3 Degrees of Freedom - ADXL203/ADXRS613"
the link is: IMU Combo Board - 3 Degrees of Freedom - ADXL203/ADXRS613 - SEN-09127 - SparkFun Electronics
Any thoughts on this...?
#aasanchez
It's already supported by the Arduino IDE, just type atan2(y,x). See http://www.arduino.cc/en/Math/H
#rob4white
Yes drift is still a issue in a modern gyroscope. You will see it, if you rotate the gyroscope. I don't think it will drift when motionless - or at least not very much!
I decided in the next 2 day i gonna make mi balancing bot (have a little vacations)
This is my part list...
Arduino Duemilanove http://arduino.cc/es/Main/arduinoBoardDuemilanove
Motors: http://www.robotshop.com/world/solutions-cubed-ezr-5.html (They do not have encoder, I think this caused me problems in the PID)
Sensor SparkFun IMU Fusion Board - ADXL345 & IMU3000 - SEN-10252 - SparkFun Electronics (This is i2c sensor)
Battery: Polymer Lithium Ion Battery - 1500mAh 11.1v - PRT-10470 - SparkFun Electronics
Motor Drive: http://www.sparkfun.com/products/9670
Now i test this.. Prevas Parekring
At the final they say:
You should read “2,10?
I read:
0,10
0,9
0,9
0,9
0,10
0,9
0,8
0,9
0,10
0,9
0,9
0,10
0,9
0,8
0,9
0,10
0,9
I read 0 always in the first number... i wait put more code to see this change...
My code..
#define ON pinMode(11, OUTPUT);digitalWrite(11, HIGH);
// Variables de Tiempo
int STD_LOOP_TIME = 9;
int lastLoopTime = STD_LOOP_TIME;
int lastLoopUsefulTime = STD_LOOP_TIME;
unsigned long loopStartTime = 0;
void serialOut_timing() {
static int skip=0;
if(skip++==5) { // display every 500 ms (at 100 Hz)
skip = 0;
Serial.print(lastLoopUsefulTime);
Serial.print(",");
Serial.println(lastLoopTime);
void setup(){
ON;
void loop(){
serialOut_timing();
// *********************** loop timing control **************************
lastLoopUsefulTime = millis()-loopStartTime;
if(lastLoopUsefulTime<STD_LOOP_TIME) delay(STD_LOOP_TIME-lastLoopUsefulTime);
lastLoopTime = millis() - loopStartTime;
loopStartTime = millis();
#aasanchez
It's because it take less than 0.5ms, so it will round down to 0ms. Try to use micros() (http://arduino.cc/en/Reference/Micros) instead as I did: BalancingRobotArduino/BalancingRobotArduino.ino at master · TKJElectronics/BalancingRobotArduino · GitHub
It will give you better resolution and thereby more accurate timing.
Regards
Lauszus
sensors aquisition smoothing and zeroing
First i have a i2c sensor SparkFun IMU Fusion Board - ADXL345 & IMU3000 - SEN-10252 - SparkFun Electronics ... This sensor is different in the values ??that can deliver
If i connect and plot they value, I get something like this.
Lectura IMU3000 #tesiandoando (This is All values)
The gyros value... range(-32768,32768); (16 bits resolutions)
The acc range(-512,512); (10bits resolution)
because these values ??are not in quids using the map function are taken to the range from 0 to 1023
temp = buffer[2] << 8 | buffer[3];
readIMU[0] = map(temp,-32768,32768,0,1023); // GYR_Y in Quids
temp = buffer[7] << 8 | buffer[6];
readIMU[1] = map(temp,-512,512,0,1023); // ACC_X in Quids
temp = buffer[11] << 8 | buffer[10];
readIMU[2] = map(temp,-512,512,0,1023); // ACC_Z in Quids*/
Values (Aprox)
506 - GYR_Y
500 - ACC_X
751 - ACC_Z
After Zeroing
I cant stablish for my sensor the Acc_Z zero value... like 102...
My sensor is a 4 mg/LSB scale factor.
the device is in 10-bit mode.
And the g range +-2g
Datasheet (http://www.sparkfun.com/datasheets/Sensors/Accelerometer/ADXL345.pdf, page 17)
See backward.png and Backward.png....
#include <math.h>
#include <Wire.h>
#define GYRO 0x68 // gyro I2C address
#define REG_GYRO_X 0x1D // IMU-3000 Register address for GYRO_XOUT_H
#define ACCEL 0x53 // Accel I2c Address
#define ADXL345_POWER_CTL 0x2D
int sensorValue[3] = {0, 0, 0};
int sensorZero[3] = {0, 0, 0};
// Sensors Module ---------------------------------------------------------------------
byte buffer[12]; // Array para almacenar los valdores del I2C
int GYR_Y;
int ACC_Z;
int ACC_X;
int readIMU[3] = {0,0,0};
unsigned long samplesIMU[3] = {0,0,0};
int i;
#define STD_LOOP_TIME 10000
unsigned long lastLoopTime = STD_LOOP_TIME;
unsigned long lastLoopUsefulTime = STD_LOOP_TIME;
int gyro_x;
int gyro_y;
int gyro_z;
int accel_x;
int accel_y;
int accel_z;
void writeTo(int device, byte address, byte val) {
Wire.beginTransmission(device); // Comienza la transmision
Wire.write(address); // Envia la direccion
Wire.write(val); // Envia el valor
Wire.endTransmission(); // Finaliza la transmision
void configIMU(){
Wire.begin();
// Set Gyro settings
// Sample Rate 1kHz, Filter Bandwidth 42Hz, Gyro Range 500 d/s
writeTo(GYRO, 0x16, 0x0B);
//set accel register data address
writeTo(GYRO, 0x18, 0x32);
// set accel i2c slave address
writeTo(GYRO, 0x14, ACCEL);
// Set passthrough mode to Accel so we can turn it on
writeTo(GYRO, 0x3D, 0x08);
// set accel power control to 'measure'
writeTo(ACCEL, ADXL345_POWER_CTL, 8);
//cancel pass through to accel, gyro will now read accel for us
writeTo(GYRO, 0x3D, 0x28);
void readSensor(){
long temp;
// First set the register start address for X on Gyro
Wire.beginTransmission(GYRO);
Wire.write(REG_GYRO_X); //Register Address GYRO_XOUT_H
// New read the 12 data bytes
Wire.requestFrom(GYRO,12); // Read 12 bytes
i = 0;
while(Wire.available())
buffer[i] = Wire.read();
i++;
void calibrateSensors() { // Set zero sensor values
int samples = 50;
for(int n=0; n<3; n++) {
samplesIMU[n] = 0;
for(int i=0; i<samples; i++){
readSensor();
samplesIMU[0] += readIMU[0];
samplesIMU[1] += readIMU[1];
samplesIMU[2] += readIMU[2];
sensorZero[n] = samplesIMU[n]/samples;
void updateSensors() { // data acquisition
int samples = 5;
samplesIMU[n] = 0;
readSensor();
sensorValue[n] = samplesIMU[n]/samples - sensorZero[n];
Zeros Values
void serialOut_zero() {
Serial.print("GIRO_Y");
Serial.print(sensorZero[0]);
Serial.print("\t ACC_X:");
Serial.print(sensorZero[1]);
Serial.print("\t ACC_Z:");
Serial.println(sensorZero[2]);
This Function show values directly form IMU3000
void serialOut_value() {
Serial.print(readIMU[0]);
Serial.print(",");
Serial.print(readIMU[1]);
Serial.print(",");
Serial.println(readIMU[2]);
The correct value, for use..
void serialOut_read() {
Serial.print(sensorValue[0]);
Serial.print(",");
Serial.print(sensorValue[1]);
Serial.print(",");
Serial.println(sensorValue[2]);
static int skip=0;
skip = 0;
Serial.print(",");
void setup(){
configIMU();
calibrateSensors();
ON;
void loop(){
updateSensors();
serialOut_read();
lastLoopUsefulTime = micros()-loopStartTime;
if(lastLoopUsefulTime<STD_LOOP_TIME) delayMicroseconds(STD_LOOP_TIME-lastLoopUsefulTime);
lastLoopTime = micros() - loopStartTime;
loopStartTime = micros();
@Lauszus Why do u use Acc_Y?
#Lauszus, thanks for your reply I would to use every 1850 impulse of encoder, so my questions are:
1)How can i use the second encoder with other pin? because the first encoder are connected to a pin2 and pin3, that are the pins that i use with the interupt 0, and 1 respectively
2)using 1850 pulses per revolution, the speed of calculation in each period according to you would be slowed down with so many interruptions? In other words, can in a sampling step to have the time to read the speed, perform the calculations to obtain the PWM value to send the signal to the motor? thanks
@aasanchez
I use the y-axis because it's how my IMU is orientated. If I rotated my IMU 90 degrees, I would have to use the x-axis.
@batista1987
You have to use an AVR with more external interrupts than the ATmega328. For instance the ATmega2560 have 6 external interrupt - see http://arduino.cc/it/Reference/AttachInterrupt
I'm not sure, but I can't see any reason to get that amount of resolution and it might slow your microprocessor down. You might have to experiment and try it out.
Regards
Lauszus
Hi lauszus,
i've changed this code
#define rightPWM PINB2 // PB2 - pin 10 (OC1B)
to
#define rightA PIND4 // PD4 - pin 4
#define rightB PIND5 // PD5 - pin 5
and this
#define leftA PIND0 // PD0 - pin 0
#define leftB PIND1 // PD1 - pin 1
#define leftPWM PINB1 // PB1 - pin 9 (OC1A)
to
#define leftA PINB0 // PB0 - pin 8
#define leftB PINB3 // PB3 - pin 11
So now how can i modify this code?
/* Left motor */
#define leftPort PORTD
#define leftPortDirection DDRD
#define leftPwmPortDirection DDRB
and this
/* Right motor */
#define rightPort PORTC
#define rightPortDirection DDRC
#define rightPwmPortDirection DDRB
@batista1987
Here is how it should look:
/* Left motor */
#define leftPort PORTB
#define leftPortDirection DDRB
and this
/* Right motor */
#define rightPort PORTD
#define rightPortDirection DDRD
Just to make sure, you are not using the USB Host Shield, right?
Regards
Lauszus
@Lauszus, thanks
Yes I don't use USB host shield. Now i would make only a self balancing without external controller
Hi guys when i try to read the angular (rad/s) speed of my pololu Dc motor (19:1) in the output value there are many noise
float getSpeed() {
static long countRightAnt = 0;
lin_speed =(countRight - countRightAnt)*2*pi/(16*2*19)*1000/STD_LOOP_TIME
countRightAnt = countRight;
return lin_speed;
//encoder ( attachInterrupt(1, rencoder, CHANGE);)
void rencoder() { // pulse and direction, direct port reading to save cycles
if (PIND & 0b00000001) countRight--; // if(digitalRead(encodPinB1)==HIGH) count++ (on DI #2)
else countRight++;
As regards to you my function are true?
this is my output with a costant duty cicle
http://dl.dropbox.com/u/15269862/out.txt
You can't do like that if you attach a interrupt on CHANGE, change it to either FALLING or RISING.
If you need the full resolution (interrupt on CHANGE), you have to check the state of the pin that caused the interrupt. See the following line in my NXT Shield library: NXTShield/NXTShield.cpp at master · TKJElectronics/NXTShield · GitHub on how to do so.
Regards
Lauszus
Hi Lauszus
i've used your code, so
void setup(){
attachInterrupt(1,readEncoder,CHANGE);
float getSpeed() {
static long countRightAnt = 0;// last count
//lin_speed =(countRight - countRightAnt)*2*pi/(16*2*19)*1000/STD_LOOP_TIME
lin_speed =(countRight - countRightAnt)*2.5835;//for ST_LOOP_TIME= 4
return lin_speed;
void readEncoder(){
if((bool)(PIND & _BV(3)) == (bool)(PIND & _BV(6))) //my pin encoder are 3 and 6
countRight--;
but the outout is this
http://dl.dropbox.com/u/15269862/out_1.txt
The following code is wrong:
void readEncoder(){
countRight--;
It should be:
void readEncoder(){
countRight++;
countRight--;
