hi there
i have tried to make a code for my arduino what has 4 LED's the first one turns on waits 15mins turns back off and a delay for 1 second and so on then returns to the start. but seem to be getting error messages when uploading i am still a newbe to this so i expect someone will look at this and laugh and tell me i did a stupid mistake.
any help will be grateful thanks
// Example 01: Lighting Timer
#define A_light 13 // Light A on pin 13
#define B_light 12 // Light B on pin 12
#define C_light 11 // Light C on pin 11
#define D_light 10 // Light D on pin 10
pinMode(A_light, output)
pinMode(B_light, output) //seting the digital
pinMode(C_light, output) //pin's as output
pinMode(D_light, output)
void loop ()
digitalwrite(A light, HIGH); //turn A light on
delay(900000); // wait for 15 mins
digitalwrite(A light, LOW); // turn A light off
delay(1000); // turn all off for 1 second
digitalwrite(B light, HIGH); //turn B light on
delay(900000); //waint for 15mins
digitalwrite(B light, LOW); //turn B ligt off
digitalwrite(C light, HIGH); // turn C light on
delay(900000); // turn all off for 1 second
digitalwrite(C light, LOW); // turn C light off
delay(1000); //turn all off for 1 second
digitalwrite(D light, HIGH); // turn D light on
delay(900000); // D light off
digitalwrite(D light, LOW); // turn D light off
digital(1000); //turn all off for 1 second
Use the compiler and my comments above to help you make corrections.
This compiles.
pinMode(A_light, OUTPUT);
void loop ()
digitalWrite(A_light, HIGH); //turn A light on
delay(900000UL); // wait for 15 mins
digitalWrite(A_light, LOW); // turn A light off
delay(1000UL); // turn all off for 1 second
hi there i got it working thanks for the help i only scanned over what you said in the first place after slowing down a bit i saw what you were getting at
this is the current code
pinMode(B_light, OUTPUT); //Setting the digital
pinMode(C_light, OUTPUT); // pin's as output
pinMode(D_light, OUTPUT);
void loop ()
digitalWrite(B_light, HIGH); //turn B light on
digitalWrite(B_light, LOW); //turn B ligt off
digitalWrite(C_light, HIGH); // turn C light on
digitalWrite(C_light, LOW); // turn C light off
digitalWrite(D_light, HIGH); // turn D light on
digitalWrite(D_light, LOW); // turn D light off
but now i would like to add a switch to alter the 15minute delay time so when buttons not pushed there will be a 15 minute delay between them all and when the button is pressed there will be a 30 min gap between them all i have started to adjust code as far as i am able to any help would be appreciated
#define button 7 // Button on pin 7
pinMode(button, INPUT); //setting as an input
void loop ()
i know this will not work but am i barking up the right tree
void loop ()
val = digitalRead(button); //read input value and store it
if (val == HIGH) {
delay(900000); // delay for 30 mins if button is HIGH
First implement Awol's advice: replace all 900000 with 900000UL The compiler will try to interpret it as a 16 bit integer constant otherwise, which won't fit and will give you odd results.
Then - what isn't working?
Also, for the test phase, you might consider using 90000UL instead - it's still large enough to need the UL, but you can run through the program without dying of boredom.
hi there again
i have made a few adjustments and added an extra 4 switches to turn off any one of the 4 lights but letting the sequence carry on i can upload this code to my controller but i cant seem to get any of the four switches to work dont know if any one notices any faults in this if so please tell me
thanks
// Example 02: Lighting Timer 26/10/2011
#define time_button 7 // Button on pin 7
#define A_light_button 1// Light A button
#define B_light_button 2// Light B button
#define C_light_button 3// Light C button
#define D_light_button 4// Light D button
int timebutton = 0;
int buttonA = 0;
int buttonB = 0; // val will be used to store the
int buttonC = 0; // state of the input pin
int buttonD = 0;
pinMode(time_button, INPUT);
pinMode(A_light_button, INPUT);
pinMode(B_light_button, INPUT);
pinMode(C_light_button, INPUT); // Setting as an input
pinMode(D_light_button, INPUT);
void loop ()
timebutton = digitalRead(time_button); //read input value and store it
buttonA = digitalRead(A_light_button); //read input value and store it
buttonB = digitalRead(B_light_button); //read input value and store it
buttonC = digitalRead(C_light_button); //read input value and store it
buttonD = digitalRead(D_light_button); //read input value and store it
if (buttonA == HIGH); { // if button A is on do the following
digitalWrite(A_light, HIGH); } //turn A light on
delay(9000UL); // wait for 15 mins
if (timebutton == HIGH) {
delay(900000UL); // delay for an additional 15 mins if HIGH
if (buttonB == HIGH); { // if button B is on do the following
digitalWrite(B_light, HIGH); } //turn B light on
delay(9000UL); //waint for 15mins
if (buttonC == HIGH); { // if button C is on do the following
digitalWrite(C_light, HIGH); } // turn C light on
delay(9000UL); // waint for 15 mins
if (buttonD == HIGH); { // if button D is on do the following
digitalWrite(D_light, HIGH); } // turn D light on
int timebutton = 0;
int buttonA = 0;
int buttonD = 0;
void loop ()
