hi
I want read end write a SD card with serial communication, arduino use SPI only, see file attachment
this is the sketch
#include <SoftwareSerial.h>
SoftwareSerial mySerial(5,4);// pin 5 RX pin 4 TX
#include <String.h>
Serial.begin(9600); // set the data rate for the Serial port
mySerial.begin(9600); // set the data rate for the SoftwareSerial port
delay(50);
Serial.println("Goodnight moon!");
mySerial.print("baud 9600 \r\n");
delay(50);
if (mySerial.available())
Serial.println(mySerial.read());
mySerial.println("mode /m");
delay(50);
while (mySerial.available())
mySerial.println("init");
delay(50);
while(mySerial.available())
mySerial.print("fcreate test.txt\r\n");
delay(50);
while(true){}
and this is the output
Goodnight moon!
62
77
111
100
101
58
32
77
67
85
40
115
105
109
112
108
101
32
109
101
115
115
97
103
101
41
13
10
79
79
test.txt file is created but the output not match output datasheet
stefano
SD_UserManual.pdf (799 KB)
