Topic: RGB led fade (Read 421 times) previous topic - next topic
Roger2808
Hello everyone,
I have a question about RGB LEDs.
Can I make an RGB LED fade without changing the colour?
For example, I have the RED=200, BLUE= 170  and GREEN=40 in 0 to 255 values.
Can I make the LED fade without chaging these colours?
Thanks.
AWOL
#1
Nov 10, 2017, 09:59 am Last Edit: Nov 10, 2017, 01:32 pm by AWOL
Try a different colour space, like HSV.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
Roger2808
Roger2808
But if I want to treat the data from an app that sends rgb values to the arduino. Then I don't know how to treat the rgb values to hsv on the app.
An when the arduino reads the values, what do I have to do? Note that I've done some code for the rgb model, but know nothing about the hsv one.
Code: [Select]
#include <softwareserial.h>
#include <wire.h>//Include libraries: SoftwareSerial & Wire
SoftwareSerial BT(0,1); //Define PIN11 & PIN12 as RX and TX pins
//RGB LED Pins
int PIN_RED = 3;
int PIN_GREEN = 5;
int PIN_BLUE = 6;
//RED LED at Pin 13
int RED_LED = 13;
String RGB = ""; //store RGB code from BT
String RGB_Previous = "255.255.255)"; //preserve previous RGB color for LED switch on/off, default White
String ON = "ON"; //Check if ON command is received
String OFF = "OFF"; //Check if OFF command is received
boolean RGB_Completed = false;
  Serial.begin(9600); //Arduino serial port baud rateļ¼š9600
  BT.begin(9600);//My HC-05 module default baud rate is 9600
  RGB.reserve(30);
  pinMode(RED_LED, OUTPUT);
  //Set pin13 as output for LED,
  // this LED is on Arduino mini pro, not the RGB LED
  //Read each character from Serial Port(Bluetooth)
  while(BT.available()){
    char ReadChar = (char)BT.read();
    // Right parentheses ) indicates complet of the string
    if(ReadChar == ')'){
      RGB_Completed = true;
    }else{
       RGB += ReadChar;
  //When a command code is received completely with ')' ending character
  if(RGB_Completed){
   //Print out debug info at Serial output window
      Serial.print("RGB:");
      Serial.print(RGB);
      Serial.print("     PreRGB:");
      Serial.println(RGB_Previous);
      if(RGB==ON){
          digitalWrite(13,HIGH);
          RGB = RGB_Previous; //We only receive 'ON', so get previous RGB color back to turn LED on
          Light_RGB_LED();
      }else if(RGB==OFF){
          digitalWrite(13,LOW);
          RGB = "0.0.0)"; //Send OFF string to turn light off
          Light_RGB_LED();
      }else{
          //Turn the color according the color code from Bluetooth Serial Port
          Light_RGB_LED();
          RGB_Previous = RGB;
      //Reset RGB String
      RGB = "";
  } //end if of check if RGB completed
} // end of loop
void Light_RGB_LED(){
  int SP1 = RGB.indexOf('.');
  int SP2 = RGB.indexOf('.', SP1+1);
  int SP3 = RGB.indexOf('.', SP2+1);
  String R = RGB.substring(0, SP1);
  String G = RGB.substring(SP1+1, SP2);
  String B = RGB.substring(SP2+1, SP3);
  Serial.print("R=");
  Serial.println( constrain(R.toInt(),0,255));
  Serial.print("G=");
  Serial.println(constrain(G.toInt(),0,255));
  Serial.print("B=");
  Serial.println( constrain(B.toInt(),0,255));
  //Light up the LED with color code
//Because these RGB LED are common anode (Common positive)
//So we need to take 255 to minus R,G,B value to get correct RGB color code
  analogWrite(PIN_RED,  (255-R.toInt()));
  analogWrite(PIN_GREEN, (255-G.toInt()));
  analogWrite(PIN_BLUE,  (255-B.toInt()));
Grumpy_Mike
Convert from RGB to HSV. Then reduce the V parameter then convert back from HSV to RGB and write that to the LED.
PaulRB
#6
Nov 10, 2017, 04:47 pm Last Edit: Nov 10, 2017, 04:52 pm by PaulRB
A simpler way to dim an RGB value is to multiply the red, green and blue component values by the same percentage. For example
Red: 240 * 50% = 120
Blue: 170 * 50% = 85
Green: 40* 50% = 20
When the dimming reaches the lowest levels, the colour may change, but there is nothing that can easily be done about this, because the Arduino's PWM control is normally only 8 bit.
Red: 240 * 5% = 12
Blue: 170 * 5% = 8 <-- ideally this would be 8.5 to maintain the same colour
Green: 40* 5% = 2
PS.
Code: [Select]
  Serial.print("R=");
  Serial.print("G=");
  Serial.print("B=");
The above may appear to limit the r, g & b values to the range 0 to 255. But in reality it does nothing...
