Topic: Some difficulty with LED's (Read 575 times) previous topic - next topic
mineblocks47
Hey guys! I have just bought 20M of some cheap ebay LED's. It cost about £30 and I thought was worth it. I havent tried them yet, but I was wondering. Are there two different names for these LED's; ( both RGB )
AND
The top image is where each LED is stuck to Red, Next one Green, Next Blue. I was aiming for each 1 led has 3 in it, so each single LED can be green+blue, or just red, or all, Instead of 3 at a time coming on to force me to use aluminium channel.
The bottom image is the one I wanted. Each LED could be individual and had 3 actual colours in it, to make a smooth blend. I havent actually tried them yet, but from my reel, I can see that you may only cut the led per 3 LED's, So,
O = LED
| = Place to cut
- = LED strip
--|-O-O-O-|-- ( Each O stuck to one colour, Red, Green, Blue )
That in a continuous pattern, for 5M per my 4 roles. please give me a seperate name to define these differences, I dont want to make this mistake again.
(The ones I aimed for, using the same key;)
--|-O-|-- ( One LED has 3 in one, red, green, blue, to prevent a pattern ish ugly thing. )
Sorry if this is in the wrong place, it seemed like the best place
Please help me, Because it also may help some other people in the future!
P.S. Can anyone recommend me some cheap 45* angled aluminium channel?
Qdeathstar
Hi.
can you provide a link to what you purchased or a high resolution image of the strips you actually bought?
A creaking creeping shadow
stiff against the freezing fog
glares at a tickless watch.
Time has failed him -- all things shall pass.
mineblocks47
Hi.
Here you go. Please note, these are the condition they came in. Just wondering if they are the ones I want. Pretty sure they are. They are 5050 not 3528 and on all videos I see the 5050 is what I want and 3528 is the one I dont want.
Grumpy_Mike
You can't get those patterns in the first post with the strip in the second post. Those LEDs are a simple 12V strip and all LEDs will light up the same colour.
Qdeathstar
Yep, I don't think they are worth the trouble to get working with a micro controller. If you want them to work you'll need three transistors, some resistors, etc.
You need to get some APA102s and the fastled library, then you can do what you want to do.
Grumpy_Mike
Quote
Now you know why they were that cheap.
Qdeathstar
roughly 50.USD sounds really expensive from dum strips. I can get 5 meters of apa102 fro about the same price with two day shipping...
https://www.amazon.com/Yaqing-Lighting-Individually-Addressable-Waterproof/dp/B01I3NXZ2U/ref=sr_1_3?ie=UTF8&qid=1510533005&sr=8-3&keywords=apa102
Qdeathstar
