Topic: Fast LED Library Red and Green swapped? (Read 263 times) previous topic - next topic
Markduino
Hello Everybody,
Anyone noticed that in the fast LED library the Red and Green are swapped?
Like that:
Code: [Select]
leds[i] = CRGB::Red; // is green
and
Code: [Select]
leds[i] = CRGB::Green; // is red
Mark
Grumpy_Mike
Quote
It is your LED strip, some have them swapped. Just compensate by defining the correct mode in the code.
Markduino
Does this mean there are two kind of WS2812B ?
What I should change in this small minimal example?
Code: [Select]
#include "FastLED.h"
#define NUM_LEDS 5
#define DATA_PIN 10
// Define the array of leds
CRGB leds[NUM_LEDS];
  FastLED.addLeds<WS2812B, DATA_PIN, RGB>(leds, NUM_LEDS);
  leds[0] = CRGB::Red; // shows green
  leds[1] = CRGB::Green; // shows red
  leds[2] = CRGB::Blue;
  FastLED.show();
  leds[0] = CRGB::Black;
  leds[1] = CRGB::Black;
  leds[2] = CRGB::Black;
  FastLED.show();
Grumpy_Mike
Quote
Yes. I have found the surface mount LEDs are RGB where as the individual packages, with wire ends are GRB.
Quote
Change CRGB to CGRB and RGB>to GRB and if that doesn't work then read the documentation for the library.
Markduino
Hello Mike,
thank you. I have found it. Only the line in the setup method needs to be changed.
Here is the code:
Code: [Select]
#define NUM_LEDS 5
#define DATA_PIN 10
  FastLED.addLeds<WS2812B, DATA_PIN, GRB>(leds, NUM_LEDS); // for GRB LEDs
  //FastLED.addLeds<WS2812B, DATA_PIN, RGB>(leds, NUM_LEDS); // for RGB LEDs
  FastLED.show();
  FastLED.show();
I have used only WS2812B SMD LEDs.
Mark
