Hello again, yet another thing I am working on is RFID for my door and am using the current code. However while it does run, it is very buggy when adding and removing cards for some reason, can anyone see an easy fix to remove the button sections and just manually add my RFID code 244A2B7 directly to the code?
#include <EEPROM.h>
volatile unsigned long tagID = 32;
//32 = bitwise 100000 - Set an initial mask to keep all tags 4 bytes long. WG26 (bits) plus another 6 = 32 bits or 4 bytes.
volatile unsigned long tmptagID;
volatile unsigned long lastBitArrivalTime;
volatile int bitCount = 0;
int buttonState = 0;
int rec_chips = 0;
int MAX_CARDS = 10;
byte CardBytes[4];
int MatchedTag = -1;
void ISRone(void)
lastBitArrivalTime = millis();
bitCount++;
tagID <<= 1;
tagID |= 1;
void ISRzero(void)
bitCount++;
tagID <<= 1;
// Arduino connections:
pinMode(2, INPUT); // Data0
pinMode(3, INPUT); // Data1
pinMode(4, OUTPUT); // Beep
pinMode(5, OUTPUT); // Green LED
pinMode(6, INPUT); // Programming switch
pinMode(13, OUTPUT); // To Transistor for lock output
digitalWrite(4,HIGH);// Turns off beep
digitalWrite(5,HIGH);// Turns off green led
digitalWrite(6,HIGH);// Enable Pullup on switch
digitalWrite(13,LOW); // Make sure the door is locked by default
Serial.begin(57600); // Serial Start
delay(1000); //Give the reader some time to settle so we don't fire interrupts yet.
buttonState = digitalRead(6);
if(buttonState == LOW){
//If the button is held on power up, clear the EEPROM
for(int i = 0; i < 40; i++){
EEPROM.write(i, 0xFF);
Serial.println("All recorded Chips Erased!");
// --- Data0 / Green Wire ----------------------------
digitalWrite(2, HIGH); // Enable pull-up resistor
attachInterrupt(0, ISRzero, FALLING);
// --- Data1 / White Wire ----------------------------
digitalWrite(3, HIGH); // Enable pull-up resistor
attachInterrupt(1, ISRone, FALLING);
tagID = 32;
bitCount = 0;
if(bitCount > 0 && millis() - lastBitArrivalTime > 250)
//convert the 32 bits into 4 byte arrays
CardBytes[0] = lowByte(tagID);
CardBytes[1] = highByte(tagID);
tmptagID = tagID >> 16;
CardBytes[2] = lowByte(tmptagID);
CardBytes[3] = highByte(tmptagID);
//Programming mode
WriteChip();
else {
//Normal mode
rec_chips = 0;
Serial.print(CardBytes[0],HEX);
Serial.print(CardBytes[1],HEX);
Serial.print(CardBytes[2],HEX);
Serial.println(CardBytes[3],HEX);
MatchedTag = Checkchip(CardBytes);
if (MatchedTag != -1){
Serial.print("Matched Tag: ");
Serial.print(MatchedTag);
Serial.println(" Access Granted");
delay (200);
digitalWrite(4,LOW);// Turns on beep
delay (500);
delay (200);
delay (500);
digitalWrite(5,LOW); // Turns on green led
digitalWrite(13,HIGH); // Unlock the door
delay (5000);
digitalWrite(5,HIGH); // Turns off green led
digitalWrite(13,LOW); // Lock the door again
else {
Serial.println("Access denied");
delay (5000);
tagID = 32;
bitCount = 0;
void WriteChip(){
if (rec_chips < MAX_CARDS){
Serial.print("Added Tag : ");
for(int i = 0; i < 4; i++){
EEPROM.write(4*rec_chips + i, CardBytes[i]);
Serial.print(CardBytes[i],HEX);
//give some feedback that the card was added by beeping weird.
delay(200);
delay(20);
delay(20);
delay(20);
delay(20);
delay(20);
Serial.println("");
++rec_chips;
int Checkchip(byte TagData[]){
int count = 0;
byte tmpByte[4];
while (count < 10){
tmpByte[i] = EEPROM.read(4*count + i);
// Serial.print(tmpByte[i], HEX);
// Serial.print(" - ");
// Serial.println(TagData[i], HEX);
if (tmpByte[0] == TagData[0] && tmpByte[1] == TagData[1] && tmpByte[2] == TagData[2] && tmpByte[3] == TagData[3])
// We matched all 4 bytes of data to one in EEPROM
//Serial.print("Matched tag ");
//Serial.println(count);
return count;
//Serial.print("Did not match tag : ");
count++;
// If we got here, no tags matched - Access denied!
//Serial.println("No match found");
return -1;
