Topic: receivind unit8 data in array by arduino (Read 542 times) previous topic - next topic
samarhefina
May 18, 2017, 12:31 pm Last Edit: May 18, 2017, 08:50 pm by samarhefina
i am trying to send unit8 data from matlab to arduino and check the values of the comming data the problem is the data is received one at a time in arduino and whenever i try to store it i fail so any help on how to store unit8data in array using arduino.
 here is the matlab code
Code: [Select]
clc
delete(instrfindall);
s = serial('COM7','BaudRate',9600);
fopen(s);
txdata = ['4';'2';'2';'2';'9'];
%Convert to decimal format
txdata_dec = hex2dec(txdata);
%Write using the UINT8 data format
fwrite(s,txdata_dec,'uint8');
y = fread(s,4, 'uint8')
here is arduino code
Code: [Select]
unsigned char buffe[5];
 if(Serial.available()) {
   for (int i=0;i<5;i++)
   int s = Serial.read();
   buffe[i]=s;
   Serial.print(s,HEX);
   if(i==5)
      Serial.print(buffe[i],HEX);
Budvar10
#1
May 18, 2017, 02:08 pm Last Edit: May 18, 2017, 02:09 pm by Budvar10
The buffe is a pointer to array of bytes. You should definitely use
Code: [Select]
buffe[i] = (unsigned char)s;
and also
Code: [Select]
BTW: Please edit your post and use code tags for the code to be readable (left most button above edit window).
Arduino clone with ATmega1284P   http://forum.arduino.cc/index.php?topic=277260.0
PaulS
Code: [Select]
What IS the value in txtdata_dec? It looks to me like the value is 0x42229. I can't imagine how you think that will fit in a uint8.
Code: [Select]
If there is one or more bytes to read, it is NOT proper to read 5 bytes.
samarhefina
hello Budvar10,
it givees me the same result the problem is i need to check every byte received and whenever i do so it doesnot respond
Code: [Select]
if (( buffe[1] ==1 ) && ( buffe[1] ==1 ) &&   (buffe[2] ==2)&&  (buffe[2] ==2))
 Serial.print("abb");
but if i check on only one  byte it works i dont know what is the problem
Code: [Select]
if (( buffe[1] ==1 ))
samarhefina
hello PaulS,
i removed the unit_8 and the received data is 42229 and i am receiving every number as int the problem i need to store these values in an array which represent data packet and check every number in it however i cant do so when ever i check single number it works fine but when i check first and second number it doesnot work and i dont know what is wrong.
Robin2
Code: [Select]
If your data starts off as text wouldn't it be simpler all round just to send it as text.
See the examples in Serial Input Basics - simple reliable ways to receive data. There is also a parse example to illustrate how to extract numbers from the received text.
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
