Do you get the same problem when using the Arduino Serial Monitor, or only with VB?
It sounds like the Arduino is resetting, and a common cause of that is someone trying to power a motor from the Arduino board. Motors generally draw too much current and should have their own power supply.
Does the program seem to work properly if you disconnect the motor?
If the problem exists with both the Serial Monitor and VB then you should sort out the problem with the Serial monitor before you introduce the complication of VB.
Motor works OK all day long without VB. There is no one else using the same com port but me.
After loading VB, the motor responses one time and no more. I have to close both VB and Arduino sketches, then unplug USB
After that, I plug USB back, load VB and Arduino sketch. It works for one time and stops.
I think my VB program is the culprit.
Thanks for looking into it.
Hi Robin2,
Found the problem. I did not reset my variable "count" in Sketch.
So after the first run, the variable is out of range. That is why the Sketch stops
Thanks for all your help.
//You need space for the null terminator, since you want 3 characters you need an extra to the null terminator 3+1
#define STR 4
char buffer[STR];
void setup(){
void loop(){
if (Serial.available() <0) { //Ok if you dont have nothing print like crazy ...
Serial.print("Empty");
if (Serial.available() >=3) {//It will need 3 bytes to run, this way you insure it's safe to read the 3 bytes in a while loop
//Serial comunication are very slow, if you try to read the 3 bytes when you detect the first one you will not get the next because the second one hasn't arrived yet
int i = 0;
while (i <= 2) {
Serial.print(i);
buffer[i++] = Serial.read();//Use i and then increment it after
buffer[3] = '\0';//In order to print it below like a string you need to terminate the char array with a 0
Serial.print("OK I received");
Serial.println(buffer); //Here you should get the string correctly
Obvios this is presuming you are just sending 3 characters from the VB
Did you look at the Python program I gave a link to earlier. Your VB program will have to work in a similar way.
First upload our sketch to the Arduino and leave the Arduino connected to the PC.
Then start your VB program ensuring that it uses the correct Com port.
When the VB program opens the Com port it will cause the Arduino to reset - which takes a little time.
The VB program must wait until the Arduino has completed resetting before it tries to communicate with the Arduino.
A good way to do that is to have the Arduino send a short message at the end of setup() and make the VB program wait until it receives that message before doing anything else.
The reason is very simple.You can't open serial port at VB and simultaneously on arduino IDE!
Serial port becomes busy after gets opened.For you could see the result of sending the "ABC" from VB, just put a textbox in VB a make arduino code to send it back to you and fill the textbox with incoming data from the Serial.Like an eco you send ABC to arduino, arduino reads it and send it back to you showing on the VB textbox.
If this is more trouble for you to do then simply try to highlight onboard LED placed on pin 13 when the incoming string matches.
Some thing like this will work:
#define STR 4
char buffer[STR];
void setup(){
pinMode(13,OUTPUT);
digitalWrite(13,LOW);
void loop(){
int i = 0;
while (i <= 2) {
Serial.print(i);
if (strcmp(buffer, "ABC") == 0 ){//If the string match turn LED on about 2 seconds and turn it off again
digitalWrite(13,HIGH);//
delay(2000);
HugoPT:
This true, but doesn't seem to be the OPs problem is he has accurately stated his process in Reply #17
There is no difficulty (on my Linux netbook) having the Arduino IDE open and able to upload sketches while at the same time running a JRuby or Python program that communicates with the Arduino. Of course I must complete the upload (or close the Arduino Serial Monitor) before trying to use the JRuby program, and vice versa.
As I have tried to show in Reply #18 I think the OP needs to reorganize the order in which things happen.
Gentlemen,
From your responses, I have learned a lot,. It means that I should be patient
Will try again.
Thank you all for taking time to looking into it.
Have a nice day.
Public Class Form1
Dim stringtosend As String
Private MySerialPort As New SerialPort("COM4", 9600, Parity.None, 8, StopBits.One)
Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs)Handles MyBase.Load
MySerialPort.Handshake = Handshake.None
MySerialPort.Encoding = System.Text.Encoding.Default
End Sub
Private Sub Button1_Click(sender As System.Object, e As System.EventArgs) Handles Button1.Click
Dim TextSend As String = "ABC;"
MySerialPort.Open()
MySerialPort.WriteTimeout = 2000
MySerialPort.Write(TextSend)
MySerialPort.Close()
TextBox1.Text = "Sending: " + TextSend
End Sub
End Class
SKETCH:
String Str;
void setup(){
pinMode(13, OUTPUT);
digitalWrite(12, LOW);
void loop(){
//blink LED while buffer is empty
if (Serial.available() <= 0) {
digitalWrite(13,LOW); }
Serial.println("Buffer is Empty");
delay(2000);
// read text string until ";" is found
if (Serial.available() > 0) {
Str = Serial.readStringUntil(';');
delay(10000);
Serial.println(Str);
My problem is:
Sketch works as intended with Sketch serial monitor
LED is on during receiving text string from VB.NET
However, nothing shown on Sketch serial monitor.
Hello PaulS,
When VB and Sketch tested with sending a character as in LED_On/OFF program. There is no problem there.
However, sending a text string is a problem.
Thanks
quangdo1700:
Hello PaulS,
Thanks
What has this to do with Reply #15 or Reply #18?
As far as I can see you have already been given all the information needed to resolve the issue.
