So I am building a larger network of Arduino Uno's / Network Shields. About 20 of them will constantly query a server I have (about every 1.5 seconds).
The server simply will output a small amount of data. either "0:" or "1:m:s" (where m = Minutes | s = seconds) and it will parse that data for minutes and seconds.
I can get the arduino to connect to the server and pull the data once during the loop with this code.
#include <SPI.h>
#include <Ethernet.h>
byte ip[] = { 192,168,0,177 };
byte server[] = { 192,168,0,98};
Client client(server, 80);
// start the Ethernet connection:
Ethernet.begin(mac, ip);
// start the serial library:
Serial.println("t:");
// give the Ethernet shield a second to initialize:
client.println("GET /client.php");
client.println();
char c = client.read();
Serial.print(c);
So they are not pulling a lot of data, but the issue is it only runs once, I need it to loop. keep querying that server over and over
I see a couple of problems initially. You need to do some checking to see if you got the connection, wait for the connection, wait for the response, etc. Take a look at the various tutorials out there and start from there. The code at Ethernet - Arduino Reference should be enough to get you started. The idea is to get a single working connection, then start looping on it.
You may have several problems. Sounds like you may have overlapping request to the server.The w5100 based ethernet shield is only setup for four connections, and your code apparently has nothing to close the current connection when the data is received. Below is some simple client test code for reference.
//zoomkat 11-13-10
//simple ethernet client test code
//for use with IDE 0021 and W5100 ethernet shield
//modify the arduino lan ip address as needed
//open serial monitor to see what the arduino receives
//push the shield reset button to run client again
#include <SPI.h>
byte ip[] = { 192, 168, 1, 102 }; // Arduino IP address
byte server[] = { 208, 104, 2, 86 }; // zoomkat's web site
Serial.println("starting simple arduino client test");
Serial.println();
Serial.println("connecting...");
if (client.connect()) {
Serial.println("connected");
client.println("GET /~shb/arduino.txt HTTP/1.0");
client.println();
Serial.println("connection failed");
if (client.available()) {
Serial.print(c);
if (!client.connected()) {
Serial.println();
Serial.println("disconnecting.");
Serial.println("==================================");
Serial.println("");
client.stop();
for(;;); //stops loop for a single get request.
draythomp:
The problem with that solution is that you still don't know how to do it.
While this is true, I learned PHP by my self looking at other peoples code. I understand basic parts of C however the way he did it, using arrays It would of taken me a while to figure that out.
I think this overall project that we are working on, with 20+ Connected Arduino's will be pretty cool.
