Topic: Measuring High Voltages with a low voltage meter (Read 668 times) previous topic - next topic
Wawa
So the 6kV Fluke probe is using a voltage divider.
Thanks for posting that.
My very old Heathkit ~30kV probe only has one long ~1Gigaohm resistor inside.
The probe in post#23 also mentions an input impedance of 1000M.
So both are relying on the (10Megohm) input impedance of the DMM.
Leo..
TomGeorge
#31
May 21, 2018, 04:34 am Last Edit: May 21, 2018, 04:34 am by TomGeorge
I noticed that the 40kV didn't have its circuit diag, so here it is;
It shows two resistors.
Tom.. :)
Everything runs on smoke, let the smoke out, it stops running....
allanhurst
Electrostatic meters have been around for years, and take no current.
Allan
JohnRob
#33
May 21, 2018, 10:24 pm Last Edit: May 21, 2018, 10:30 pm by JohnRob
Quote
If the resistors have equal resistance the voltage will be divided equally.   That's Ohm's Law...  The voltage is proportional to the resistance...  That's how a voltage divider works.   (And that assumes no arcing.   ) [
This is absolutely true.
I apologize, I was remis in omitting my reasoning.:(
The OP seems to be new working with high voltage.  When building the divider, if the resistors are wired close together or some get contamination on the surface,  things could (not will) go bad.  Contamination could be finger grease solder rosin etc.   But in the end it is my opinion and how I would do it.
Please do not PM me with thread based messages.  If your thoughts are worth responding,  the group should benefit from your insight.
ChrisTenone
When dealing with HV, you are always your own last arbiter. Cause a mistake could be fatal, or at least hurt a lot. That's why I am such a fan of the Vandegraaff and Tesla devices. As HV goes, they are both pretty benign.
ps, a full on shock from either IS painful, but usually NOT fatal. OP: What are you using as a power supply? Is it a transformer? Be real careful with those!
.sig
gwareloth
He's 15 years old, so bound to be.
From one of his other threads:
I am fairly new to arduino at age 15.
