Topic: Wall of Shame  (Read 38285 times) previous topic - next topic
ChrisTenone
Looks like you hosed it down with Raid, Allan. That bug's dead, dead, deadski!
Quote
ps could someone explain how to post a picture directly, not as an attachment....?
Once you attach it, put the link to the attached picture between [img] tags, like this:
Alternatively, post the picture on another site, and use the [img][/img] tags to show it.
Wubba lubba dub dub!
travis_farmer
Off-Topic (sorry), but absolutely a work of shame.
for those that can read drum sheet music, my tempo wanders like a drunkard. I would post the midi file, but it isn't listed as an allowed type.
I was just playing around with some recording software, and i finally got it to record from the MIDI interface. Now all i have to do is actually learn drums.
~Travis
My GitHub: https://github.com/travisfarmer?tab=repositories
My website is where i organize my thoughts and ideas. feel free to visit it (http://tjfserver.ddns.net/).
Arduino Talk Radio: http://travisfarmer.caster.fm/ (if i am on-air)
allanhurst
Thanks for the pic post info - I'll use it.
Actually it works?!  - it's a 1-transistor preamp driven by the ripple of an alternator driving a digital input on a pro mini.  Anything above 100mV p-p in gives a rail-rail output.
The frequency is obtained using pulseIn and used to drive a sin/cos meter with lookup tables and analog.out.
Now installed (well, a tidied up version) on my daughter's boat as a revcounter.
regards
Allan
larryd
I fear you don't need to descend into Fritzing to apply for the wall of shame.
With trepidation I submit my humble entry
grovel
Allan
See:
http://forum.arduino.cc/index.php?topic=364156.0
Time to get out the hot glue and hide it from humanity ;)
No technical PMs.
The last thing you did is where you should start looking.
allanhurst
#139
Jan 01, 2017, 05:42 pm Last Edit: Jan 01, 2017, 06:06 pm by allanhurst
To add to my shame - and try the picture posting trick - I enclose a 140MHz saw-based IF filtering/matching section from a 30GHz tranceiver......
The saw manufacturers ( sawtech, now triQuint) give you matching networks, but they may not be optimal for your layout .  No VNA is going to help - it's way off a power match. So you just have to change components and measure.
After a dozen times or so , it gets a bit messy.......
Allan.
Didn't work... what did I do wrong?
tried again ...Gotcha! - what a cumbersome procedure....
A
MAS3
#140
Jan 02, 2017, 12:36 am Last Edit: Jan 02, 2017, 12:38 am by MAS3
Quote from: allanhurst
Nice.
I like the antenna.
Someone already did (click !), and also told you why you need to do it this way.
Sorry, didn't see there was a next page.
Have a look at "blink without delay".
Did you connect the grounds ?
Je kunt hier ook in het Nederlands terecht: http://arduino.cc/forum/index.php/board,77.0.html
TomGeorge
#141
Feb 08, 2017, 02:59 am Last Edit: Feb 08, 2017, 03:00 am by TomGeorge
Ahh yes....
12V SLA charger for a garden sprayer.
Yes someone did plug a 240Vac IEC into the 12Vdc socket on the sprayer.
Fuse in sprayer went bang.
Replaced fuse, everything works.
Tom.... :)
Everything runs on smoke, let the smoke out, it stops running....
MorganS
#142
Feb 09, 2017, 06:09 am Last Edit: Feb 09, 2017, 06:10 am by MorganS
The stuff soldered on top of the Mini looks normal. Not even any dry joints.
"The problem is in the code you didn't post."
Jiggy-Ninja
#143
Feb 24, 2017, 06:30 am Last Edit: Feb 24, 2017, 06:31 am by Jiggy-Ninja
I know. Other than the grime it's a completely respectable point-to-point construction. It doesn't deserve having its own father ashamed of it.
Hackaday: https://hackaday.io/MarkRD
Advanced C++ Techniques: https://forum.arduino.cc/index.php?topic=493075.0
allanhurst
I've done prettier.  Sometimes
Allan.
TomGeorge
Cover it in hot melt glue......
allanhurst
Some years ago I was working on a 1.9GHz mobile phone, and finally figured out a problem ( ie my mistake) .  Bodged up a test solution with a stonehenge type mid-air construction of 0402's. Under the microscope it looked b*y awful. But it worked.
Gave the lab technician another 6 to do - and she did - with the unaided eye! And under the microscope they were works of art. And of course they worked perfectly
Good technicians are wonderful!
Allan
Henry_Best
Don't know if this qualifies for the wall of shame, but I installed Win 10 on a rebuilt computer and was clearing out some unnecessary files when I came across this:
WPNPRMRY.tmp  size:  -1 byte.
Does deleting it take up more space on the hard drive than keeping it?
If I copy it enough times will I get an extra terabyte of space on the 500Gb HDD?   :o
Coding Badly
What reported that size?  Explorer?
Henry_Best
Wisecare 365. It's usually pretty accurate and clears a load of crud from the hard drive.
