Topic: Can't get string from Serial Monitor! Please Help! (Read 678 times) previous topic - next topic
stoianvictor618
  Hello guys!
My name is Victor, I am a c/c++ programmer (just hobbyist for the moment), and I'm new to Arduino.
First I want to say that I have a deep respect and gratitude,for all the people that brought their contribution to Arduino,with function libraries,different codes,or just gave an advice on the forum.
You are great,and I thank you very much, cause you made from Arduino such an amazing machine!
 Please,I need some help.I want to make Arduino act as web server with possibility to set network parameters from Serial Monitor (IP,MAC,Gateway,etc).When I try to read the Serial Monitor's buffer,nothing happens.Please see the code below.
 Another issue is that: the Ethernet/WiFiServer object is initialized with MAC adress composed of 6 byte,but in the sketch examples,is composed of 6 hex values,bigger in size than byte type.
  If I want to take MAC from Serial Monitor and store it to EEPROM, should I convert it somehow to hex after read it back from EEPROM,in order ot start server? Thank you very much for help,have a great day!
groundFungus
PaulS
Code: [Select]
  while(Serial.available()==0){;}
  char ch;
  int i=0;
  while(Serial.available()>0)
      ch=Serial.read();
      buffer[i++]=ch;
As soon as there is at least one byte to read, start reading them all. How many do you suppose will have arrived when the first while loop ends? Any answer other than ONE is wrong.
Quote
Rubbish. Post the code that you think does this.
stoianvictor618
 Thank you very,very much groundFungus! That was very useful !
 You're right PaulS, I've asked the wrong question !
 So, in this  statement:  "byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED};"  how can an array of bytes
 hold these hex values? And more important,if I got from Serial Monitor a string like:
 "0xDE:0xAD:0xBE:0xEF:0xFE:0xED" and I've devided it in 6 substrings like: "0xDE", how do I store those
 values in EEPROM, in order to read them back and pass them to Ethernet.begin() ?
 Should I remove th "0x" part then split "DE" in 2 different bytes, and write them in EEPROM ?
wvmarle
A value like 0xDE is a single byte value, decimal value 222.
Try this:
Code: [Select]
byte number = (byte)strtol(hexstring, NULL, 0);
Where hexstring contains a single value.
Quality of answers is related to the quality of questions. Good questions will get good answers. Useless answers are a sign of a poor question.
stoianvictor618
Thanks a lot wvmarle!
I thought that the decimal value of an hex representation is concatenation of each
hex digit's decimal value, in my case, D=13, E=14,so the result is 1314 !
 The fact that are so many topics about "storing MAC address" is because,like me, newbies fail to
know/understand hex representation !
 Please,if you don't mind, can you tell me how does that work?
  P.S: I haven't used yet the code above, cause first I want to know exactly how hex representation
        works.Thank you!
wvmarle
Do read up on different based systems - binary, octal, decimal and hexagonal. It's very much the basis of computing.
Closely related is to understand binary and bit operations and how var >> 6 is equivalent to var/64 when working with integers.
