Hello,
I am using a GPS module (SKylab SKM53) with Arduino UNO to get location data. This is the code I use to read gps data
This Sketch will run with the SkyNav SKM53 GPS
RXD Arduino Pin 3
TXD Arduino Pin 2
RST Leave Open
NC Leave Open
GND Ground
VCC +5
Make sure you download and save to your Arduino/Libraries folder TinyGPS.h
and NewSoftSerial.h files.
#include <TinyGPS.h>
#include <SoftwareSerial.h>
unsigned long fix_age;
SoftwareSerial GPS(2,3);
TinyGPS gps;
void gpsdump(TinyGPS &gps);
bool feedgps();
void getGPS();
long lat, lon;
float LAT, LON;
void setup(){
GPS.begin(9600);
void loop(){
long lat, lon;
unsigned long fix_age, time, date, speed, course;
unsigned long chars;
unsigned short sentences, failed_checksum;
// retrieves +/- lat/long in 100000ths of a degree
gps.get_position(&lat, &lon, &fix_age);
getGPS();
Serial.print("Latitude : ");
Serial.print(LAT/100000,7);
Serial.print(" :: Longitude : ");
Serial.println(LON/100000,7);
void getGPS(){
bool newdata = false;
unsigned long start = millis();
// Every 1 seconds we print an update
while (millis() - start < 1000)
if (feedgps ()){
newdata = true;
if (newdata)
gpsdump(gps);
bool feedgps(){
while (GPS.available())
if (gps.encode(GPS.read()))
return true;
return 0;
//byte month, day, hour, minute, second, hundredths;
gps.get_position(&lat, &lon);
LAT = lat;
LON = lon;
feedgps(); // If we don't feed the gps during this long routine, we may drop characters and get checksum errors
Unfortunately, the gps.encode() function never returns true even though the module is sending proper NMEA data like this:
$GPGGA,002349.038,8960.0000,N,00000.0000,E,0,0,,137.0,M,13.0,M,,44
$GPGSA,A,1,,,,,,,,,,,,,,,1E
$GPGSV,1,1,0079
$GPRMC,002349.038,V,8960.0000,N,00000.0000,E,0.00,0.00,060180,,,N79
As a result, the lattitude and longitude displayed is always ZERO. Please help...
