As you may of seen I have started a OMSI dashboard.
My problem at the moment is I cannot even get a server to sweep.
I wire up the servo correctly and it just makes a little vibratey noise and
nothing happens.
Please help,
Steve
nothing happens.
Please help,
Steve
nothing happens.
C'mon Steve.... you'll have to do better than that 8)
Circuit.... code....
I dont get you????.
I think it may be my servo, I have checked the whole system, The whole code,
Nothing seems to work.
Is it me being dumb and not working something out?
Well nobody can tell unless you post the code and the circuit.....
// Sweep
// by BARRAGAN http://barraganstudio.com
// This example code is in the public domain.
#include <Servo.h>
Servo myservo; // create servo object to control a servo
// a maximum of eight servo objects can be created
int pos = 0; // variable to store the servo position
myservo.attach(9); // attaches the servo on pin 9 to the servo object
for(pos = 0; pos < 180; pos += 1) // goes from 0 degrees to 180 degrees
{ // in steps of 1 degree
myservo.write(pos); // tell servo to go to position in variable 'pos'
delay(15); // waits 15ms for the servo to reach the position
for(pos = 180; pos>=1; pos-=1) // goes from 180 degrees to 0 degrees
Ok, well assuming it is actually connected correctly 8), it might be that your servo is unable to get enough current through the Arduino.
I'd hook the servo up to its own power, not through the Arduino, like in my Fritzing pic below. Check the servo maker's details though, to check what voltage it needs.
