Topic: DHT22 Webserver (Read 10531 times) previous topic - next topic
DancesWithWords
#15
Nov 28, 2014, 05:43 pm Last Edit: Nov 28, 2014, 05:51 pm by DancesWithWords
Thanks for making that work. I appreciate all the help I've received from the Arduino forums support team.   ;D
So I'm going to make this my next job to review this code so I full understand your changes and how this all works.  Not much good to me if I don't put the work in to learn something from this.
Working temperature server; faintfuzzies.ca:8080
DancesWithWords
DancesWithWords
Well I spoke too soon.  If you let faintfuzzies.ca:8080  run a couple of minutes it starts misbehaving.  Take a look and let me know what you think.  I've tested it on Chrome and Firefox the rests are the same.  The first few iterations are fine then things go wonky. Finally this webserver just freezes up and requires a reboot.
DWW
robtillaart
The code now compiles so it is syntactically correct.
Apparently the semantics and behaviour is still not right.
It looks to me as if the Arduino does not wait for a new connection but just spits snippets of data.
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
robtillaart
Can you try this simplified loop?
Code: [Select]
  // listen for incoming clients
  if (client)
    Serial.println("new client");
    // send a standard http response header
    client.print(headerHTML);
    // now send the stuff we want
    client.print(TimeElapsed()); // your old code here
    // do some more stuff
    sendTempToNetwork(client);
    sendAnalogToNetwork(client);
    // were done sending so now send the footer to close the page
    client.println(footerHTML);
    // give the web browser time to receive the data
    delay(10);
    // close the connection:
    client.stop();
    Serial.println("client disconnected");
  delay(2000);
Rob Tillaart
DancesWithWords
That breaks a few things:
working2_4DHT.ino: In function 'void loop()':
working2_4DHT.ino:122:5: error: break statement not within loop or switch
working2_4DHT.ino: At global scope:
working2_4DHT.ino:132:1: error: expected declaration before '}' token
robtillaart
remove the line with break. (I cannot test the code only compile it, sorry :)
Rob Tillaart
DancesWithWords
Code is uploaded and live: faintfuzzies.ca:8080
DancesWithWords
#22
Nov 28, 2014, 07:48 pm Last Edit: Nov 28, 2014, 07:52 pm by DancesWithWords
Still having issues, there was an improvement it lasted 28 minutes before crapping out.  This is the junk I get just before it crashes.
>analog input 0 is 300<br />
analog input 1 is 340<br />
analog input 2 is 316<br />
analog input 3 is 300<br />
analog input 4 is 286<br />
analog input 5 is 297<br />
</html>
t 3 is 303<br />
analog input 4 is 284<br />
analog input 5 is 294<br />
</html>
E HHTTP/1.1 200 OK
Content-Type: text/html
Connection: close
Refresh: 5
<!DOCTYPE HTML><Title>Office Enviroment Server</Title><html><h1>00:28:38</h1>Humidity=23%<BR/>Temperature=24 C<BR/>HTTP/1.1 200 OK
Connection: close
RefreHTTP/1.1 200 OK
Connection: close
Refresh: 5
<!DOCTYPE HTML><Title>Office Enviroment Server</Title><html><h1>00:28:48</h1>Humidity=23%<BR/>Temperature=24 C<BR/>Dewpoint=2 C<BR/><BR/>analog input 0 is 298<br />
HTTP/1.1 200 OK
Connection: close
Refresh: 5
<!DOCTYPE HTML><Title>Office Enviroment Server</Title><html>288<br />
</html>
fresh: 5
<!DOCTYPE HTML><Title>Office Enviroment Server</Title><html><h1>00:28:25</h1>Humidity=23%<BR/>Temperature=24 C<BR/>Dewpoint=2 C<BR/><BR/>analog input 0 is 299<br />
analog input 1 is 339<br />
analog input 2 is 315<br />
analog input 3 is 303<br />
analog input 4 is 287<br />
</html>
><html><h1>00:28:06</h1>Humidity=23%<BR/>Temperature=24 C<BR/>Dewpoint=2 C<BR/><BR/>analog input 0 is 305<br />
analog input 1 is 343<br />
analog input 3 is 301<br />
analog input 4 is 283<br />
analog input 5 is 296<br />
</html>
analog input 2 is 317<br />
analog input 3 is 299<br />
anaHTTP/1.1 200 OK
Connection: close
Refresh: 5
robtillaart
do you still have myClient.write(" ");  in your code?
Rob Tillaart
robtillaart
#24
Nov 28, 2014, 08:31 pm Last Edit: Nov 28, 2014, 08:34 pm by robtillaart
- http://www.w3schools.com/tags/tag_br.asp -
Differences Between HTML and XHTML
In HTML, the <br> tag has no end tag.
In XHTML, the <br> tag must be properly closed, like this: <br />.
  myClient.print("<BR/>"); usesnospaceintag
Rob Tillaart
robtillaart
compacter code sometimes helps
Code: [Select]
void sendTempToNetwork(EthernetClient myClient)
  myClient.print("Humidity=");
  myClient.print(dht.readHumidity(), 0);
  myClient.print("%<BR />Temperature=");
  myClient.print(dht.readTemperature(), 0);
  myClient.print(" C<BR/>Dewpoint=");
  myClient.print(dewPoint(dht.readTemperature(), dht.readHumidity() ), 0);
  myClient.println(" C<BR /><BR />"); // <<<<< note the println ...
Rob Tillaart
DancesWithWords
Running with this code snippet right now.
DWW
DancesWithWords
FYI
This is the code I'm currently running.
Code: [Select]
#include <SPI.h>
#include <Wire.h>
#include <Ethernet.h>
//#include <UIPEthernet.h>
#include <DHT.h>
#include <stdio.h>
#define DHTTYPE DHT22
#define DHTPIN 2
DHT dht(DHTPIN, DHT22);
float combined_temp_C;
float combined_temp_F;  //create a new variable
byte TempHi;              // Variable hold data high byte
byte TempLo;              // Variable hold data low byte
boolean P_N;              // Bit flag for Positive and Negative
boolean P_N112;
boolean P_N212;
unsigned int Decimal;     // Variable hold decimal value
char * strTempC = NULL;
char * strTempF = NULL;
byte mac[] = {
  0x90, 0xA2, 0xDA, 0x00, 0x4E, 0x10 };  // MAC address 84.85.88.16.0.36
byte ip[]  = {
  192, 168, 1, 20 };                     // ip-address, please change to fit your network
byte mydns[] = {
  192, 168, 1, 1 };
byte gateway[] = {
  192, 168, 1, 1 };
byte subnet[] = {
  255,255,255,0 };
EthernetServer server(8080);
static char output[300] = "";
char headerHTML[] = "HTTP/1.1 200 OK\r\n"
"Content-Type: text/html\r\n"
"Connection: close\r\n"
"Refresh: 5\r\n"
"\r\n"
"<!DOCTYPE HTML>"
"<Title>Office Environmental Server</Title>"
"<html>";
char footerHTML[] = "</html>" ;
  //ethernet
  Ethernet.begin(mac, ip);
  server.begin();
  Serial.print("server is at ");
  Serial.println(Ethernet.localIP());
char * TimeElapsed()
{ // Was Home Page
  long t = millis() / 1000;
  word h = t / 3600;
  byte m = (t / 60) % 60;
  byte s = t % 60;
  sprintf(output, "<h1>%d%d:%d%d:%d%d</h1>" , h/10, h%10, m/10, m%10, s/10, s%10);
  return output;
void sendAnalogToNetwork(EthernetClient myClient)
  // output the value of each analog input pin for good measure
  for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
    int sensorReading = analogRead(analogChannel);
    myClient.print("analog input ");
    myClient.print(analogChannel);
    myClient.print(" is ");
    myClient.print(sensorReading);
    myClient.println("<br />");
 * Main Loop
  if (client)
    delay(10);
    client.stop();
  delay(2000);
void Cal_Temp()
  if (TempHi&0x80)     // If bit7 of the TempHi is HIGH then the temperature is negative
    P_N = 0;
  else       // Else the temperature is positive
  P_N = 1;
  TempHi = TempHi & 0x7F;   // Remove sign
  TempLo = TempLo & 0xF0;   // Filter out last nibble
  TempLo = TempLo >>4; // Shift right 4 times
  Decimal = TempLo;
  Decimal = Decimal * 625;  // Each bit = 0.0625 degree C
  combined_temp_C= TempHi + TempLo*.0625;
  combined_temp_F = combined_temp_C*1.8+32;
  sprintf(strTempC, "%f", combined_temp_C);
  sprintf(strTempF, "%f", combined_temp_F);
////Celsius to Kelvin conversion
//double Kelvin(double celsius)
//        return celsius + 273.15;
// dewPoint function NOAA
// reference: http://wahiduddin.net/calc/density_algorithms.htm
double dewPoint(double celsius, double humidity)
  double A0= 373.15/(273.15 + celsius);
  double SUM = -7.90298 * (A0-1);
  SUM += 5.02808 * log10(A0);
  SUM += -1.3816e-7 * (pow(10, (11.344*(1-1/A0)))-1) ;
  SUM += 8.1328e-3 * (pow(10,(-3.49149*(A0-1)))-1) ;
  SUM += log10(1013.246);
  double VP = pow(10, SUM-3) * humidity;
  double T = log(VP/0.61078);   // temp var
  return (241.88 * T) / (17.558-T);
// delta max = 0.6544 wrt dewPoint()
// 5x faster than dewPoint()
// reference: http://en.wikipedia.org/wiki/Dew_point
double dewPointFast(double celsius, double humidity)
  double a = 17.271;
  double b = 237.7;
  double temp = (a * celsius) / (b + celsius) + log(humidity/100);
  double Td = (b * temp) / (a - temp);
  return Td;
robtillaart
What kind of ethernet do you have?
standard ethernet shield?
it looks like if <ethernetshield> is getting the data too fast, buffer overruns or so.  Can't explain it yet.
Rob Tillaart
DancesWithWords
Using a Ardiuno Ethernet Shield w/ MicroSD slot Rev. 3
