Topic: selecting numbers with a potmeter (Read 773 times) previous topic - next topic
hankr99
hello y'all, im doing a project on my own and im trying to make a safe . You have to select 4 numbers ranging from 0-25 . I want to use a potmeter and when u turn the knob it goes through the range of numbers and then confirm the numbers with a button , can anyone help me in the right direction?
thanks in advance
PaulS
Quote
The right direction would obviously be to use analogRead() to read the potentiometer value and digitalRead() to read the switch states. Of course, this approach presupposes that you know how to connect the switch and potentiometer to the Arduino.
wvmarle
Unless this is a paid job, you better ask a mod to move this to the Project Guidance forum.
Quality of answers is related to the quality of questions. Good questions will get good answers. Useless answers are a sign of a poor question.
hankr99
yea i already got that the serial monitor gives me the numbers from 0-25 but with the selecting part im still lost
wvmarle
So what do you have (post code) and where does it go wrong?
hankr99
int pMin = 14;
int pMax = 948;
int x = 0;
x = analogRead(A0);
  Serial.print(x);
  x = map(x, pMin, pMax, 0, 24);
  Serial.print("\t");
  Serial.println(x);   delay(100);
this shows in the serial monitor numbers between 0-25 now i have to write a code that i can select 4 numbers with 4 presses on a button but i have no idea where to start , these 4 numbers work like a password , so when the 4 numbers are correct a green light lights up and if u choose 4 wrong numbers a redlight shows up
wvmarle
Create an array, then upon reading a button press you take an analogRead() and place the number in the array.
Code: [Select]
byte selectedNumber[4];
byte counter = 0;
  if (digitalRead(BUTTON_PIN) == LOW) {
    int x = analogRead(A0);
    selectedNumber[counter] = map(x, pMin, pMax, 0, 24);
    counter++;
    delay(100); // for button bounce
  if (counter >= 4) {
    do_check_code();
