Topic: Anyone here with Lin bus arduino implementation experience? (Read 668 times) previous topic - next topic
PlankSpank
I want to control some Lin enabled devices and would like to start a dialog with anyone that has worked with the protocol. I have the addresses so there isn't a need to beat my head against that issue.
I'm a little lost in the library's I found on github, so I'm looking for some clarification on implementation or suggestions on better starting ground. Google searches have been a bust as well.
I'm not asking for someone to do all the legwork, but putting the feelers out to see if there are people here with some experience solving Lin bus arduino control. I'm trying to level up!
I'll be getting deeper into this in the next week and will have more specific questions to help clarify my knowledge gaps.
Plank
6v6gt
I had to lookup LIN to find out that it is a cheaper alternative to the CAN bus.
https://en.m.wikipedia.org/wiki/Local_Interconnect_Network
What devices are you connecting (links) ?
PlankSpank
Lin controlled led's.
https://www.digikey.com/reference-designs/en/lighting/color-mixing-led-controllers/873
Have Mega 2560 and skpang.co.uk linbus breakout board, Rev B.
Currently trying to use Andrew Stone's library and example, but it's slow going getting a working implementation.
This is the example:
Code: [Select]
 Copyright 2011 G. Andrew Stone
All rights reserved.
Redistribution and use in source and binary forms, with or without
modification, are permitted provided that the following conditions are met:
    * Redistributions of source code must retain the above copyright
      notice, this list of conditions and the following disclaimer.
    * Neither the name of the copyright holder nor the
      names of its contributors may be used to endorse or promote products
      derived from this software without specific prior written permission.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND
ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
DISCLAIMED. IN NO EVENT SHALL <COPYRIGHT HOLDER> BE LIABLE FOR ANY
DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
(INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
(INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/* This example code uses 2 different LIN LEDs of unknown type (acquired as
   samples).  You will have to modify this code to work with whatever LIN
   devices you have.
   TODO: make a Arduino LIN slave so the code works without modification.
#include "Arduino.h"
#include "lin.h"
Lin lin;
#ifndef SIM
#define simprt p
#undef assert  // I don't want to assert in embedded code
#define assert
#else
#define simprt printf
#include <stdarg.h>
#include <assert.h>
#endif
#ifdef LIGHTUINO
// Printf-style to the USB
void p(char *fmt, ... )
        char tmp[128]; // resulting string limited to 128 chars
        va_list args;
        va_start (args, fmt );
        vsnprintf(tmp, 128, fmt, args);
        va_end (args);
        Usb.print(tmp);
#else  // We can't use the serial on a normal Arduino because it is being used by LIN
#endif
void setAllFadeTime(uint8_t fadeTime)
  uint8_t linCmd2[] = { 0x1f, fadeTime };
  lin.send(0x2e, linCmd2,2,1);
void setAllToColor(uint8_t red, uint8_t grn, uint8_t blu)
  uint8_t linCmd[] = { blu,grn,red,0xf1 };
  lin.send(0x2f,linCmd,4,1);
  uint8_t linCmd2[] = { 0x1f, 0xe0 };
void setColor2(uint32_t addr, uint8_t red, uint8_t green, uint8_t blue, uint8_t brightness,uint8_t whtLed=0)
  uint8_t linCmd[] = { (uint8_t)(addr),(uint8_t)(addr>>8),(uint8_t)(addr>>16),0b00000000 | ((addr>>24)&3),((brightness<<1) | (whtLed&1)),red ,green , blue };
  lin.send(0x01,linCmd,8);
void setAllToColor2(uint8_t red, uint8_t blue, uint8_t green, uint8_t brightness)
  //unsigned char linCmd[] = { 0xFF,0xFF,0xFF,0b00100111,((brightness<<1) | 0x00),red ,green , blue };
  //lin.send(0x01,linCmd,8);
  for (int i=0;i<10;i++)
    setColor2(0x0fffffff, red,blue,green,brightness);
void setup(void)
  lin.begin(19200);
  //Usb.begin();
void SimpleFrameInjection()
  if (1)
      uint8_t buf[8];
      uint8_t recvOk = lin.recv(32,buf,8,1);  // Should fail since nobody is at 0
      if (recvOk==0) simprt("receive timeout succeeded. ret = %d\n",recvOk);
      else simprt("receive timeout test failed. ret = %d\n",recvOk);
  // Fade all LEDS to red
  for(int i=0;i<255;i+=10)
      setAllToColor(i,0,0);
      delay(60);
  // Pop between 2 colors
  for(int i=0;i<255;i+=30)
      setAllToColor(255,0,255);
      setAllToColor(0,255,0);
class LedFrame:public LinScheduleEntry
public:
  LedFrame(uint16_t repeat,uint8_t red, uint8_t grn, uint8_t blu);
  uint8_t  dontUse[3];  // the rest of the data
  uint16_t repeatMs;    // when to repeat
uint16_t LedRepeat(LinScheduleEntry* me)
  //Usb.print("led repeat\n");
  return ((LedFrame*) me)->repeatMs;
LedFrame::LedFrame(uint16_t rp,uint8_t red, uint8_t grn, uint8_t blu)
    flags    = Lin1Frame | LinWriteFrame;
    callback = LedRepeat;
    repeatMs = rp;
    addr    = 0x2f;
    data[0] = blu;
    data[1] = grn;
    data[2] = red;
    data[3] = 0xf1;
    len     = 4;
void led2Test(int addr, int delayAmt)
  //Usb.print("Test red\n");
  //setAllToColor2(100,1,1,100);
  setColor2(addr,100,0,0,100);
  delay(delayAmt);
  //Usb.print("Test green\n");
  setColor2(addr,0,100,0,100);
  delay(delayAmt);
  //Usb.print("Test blue\n");
  setAllToColor2(0,0,100,100);
  delay(delayAmt);
#if 0
  Usb.print("Fading\n");
  for (int i=10;i<=100;i+=10)
      delay(50);
      setAllToColor2(100,100,100,i);
      delay(50);
      setAllToColor2(100-i,100,100,100);
  for (int i=10;i<100;i+=10)
      delay(50);
      setAllToColor2(1,100-i,100,100);
      delay(50);
      setAllToColor2(1,1,100-i,100);
#endif
void led2RecvTest(uint8_t addr)
  uint8_t buf[8];
  setColor2((1<<(addr-1)),100,0,0,0x60);
  for (int i=0;i<8;i++) buf[i] = 0;
  delay(400);
  uint8_t recvOk = lin.recv(0x20 + addr-1,buf,6,1);  // The data is correct but the checksum byte is 0xFF -- may be a bug in the device
  p("received %d bytes. %2x %2x %2x %2x %2x %2x %2x %2x\n",recvOk, buf[0],buf[1],buf[2],buf[3], buf[4],buf[5],buf[6],buf[7]);
  setColor2((1<<(addr-1)),0,0x40,0,100);
  delay(300);
  delay(100);
  //setColor2((1<<(addr-1)),00,100,0,100);
  delay(200);
  recvOk = lin.recv(0x21 + addr-1,buf,6,1);  // Should fail
  //if (recvOk==0) simprt("receive timeout. ret = %d\n",recvOk);
  //else simprt("receive ok. ret = %d\n",recvOk);
void SchedulerTest(void)
  unsigned long int start = millis();
  LedFrame red(1500,0xff,0,0);
  LedFrame grn(1500,0,0xff,0);
  LedFrame blu(1500,0,0,0xff);
  lin.add(red,1); lin.add(grn,500); lin.add(blu,1000);
  while (millis() < start + 10000) // 10 second test
      lin.loop();
      delay(1);
  lin.clear();  // Better remove them before I drop out of this stack frame!
 void loop(void)
  uint8_t addr = 5;
  for (int delayAmt = 301; delayAmt>0;delayAmt-=100)
    led2Test((1<<(addr-1)),delayAmt);
  led2RecvTest(addr);
  setAllFadeTime(0xe0);
  setAllToColor(255,0,0);
  //Usb.print("Simple LIN frame test\n");
  SimpleFrameInjection();
  //Usb.print("Scheduler test\n");
  SchedulerTest();
As I understand it, Andrew used a different board for this code. That is probably the first issue I need to tackle. Make sure the MEGA is getting the right information and wiring is correct.
I have CS on the linbus board held high on a digital pin to wake up the bus. TXD/RXD on pins 0/1 respectively. 12VDC from external source for bus power, 5V and GND from Arduino.
I have to further investigate the Usb.print aspect of this code as well.
Would really like to find some start point for the MEGA that is known to be correctly functioning. It's a shame when companies produce a board and refer to other people's work for an example how to use their product. Sorry, ranting a bit.
Appreciate any insight from the community. It doesn't look like many have used the Arduino/linbus combination and shared results.
I am open to other platforms, but trying to steer away from Vehicle Spy and other computer solutions. I would like a standalone interface that can be expanded to control other linbus addressable components, servo motors in next on the list.
Plank
PlankSpank
https://forum.arduino.cc/index.php?topic=298071.30
This answered most of my questions for now.  Thanks to da beast for the posts and all the people that helped him get this running.
I'll follow up with a sketch once I have the digikey leds running.
