Topic: How to get Array Position State with digitalRead ? (Read 577 times) previous topic - next topic
drxm
Nov 15, 2017, 05:05 am Last Edit: Nov 15, 2017, 05:41 am by drxm Reason: updated information
Hi, this is my first post so if this belongs to another section please move (and sorry)
I'm trying to read a dip switch state to change a variable, and use that variable into a switch.
Problem is, I don't understand how to get the State value from the dip switch pin. I believe it to have something to do with the dip switch pins being into an Array.
I had already read the docs about digitalRead and searched info about dip switch, but almost anyone use arrays or seems harder to understand (for me, I'm a student and this is my 3rd time with Arduino)
Hope you can help me or give me some guidance, thanks =)
Edit: I found out the dip switch needs to be powered and that's why all pins are LOW, but i don't know how to exactly do that.
This is my code:
Code: [Select]
int dipPins[] = {2, 3, 4, 5}; //dip switch pins
int led[] = {6, 7, 8, 9, 10, 11, 12, 13}; //led pins
int var = 0; //switch variable
  //declares input pins for dip switch
  for(int i = 0; i < 4; i++){
    pinMode(dipPins[i], INPUT);
    //if dip switch state == HIGH assign array position to var??
    //here is my problem
    if(digitalRead(dipPins[i]) == HIGH){
      var = i + 1;
  //declare led pins
  for(int i = 0; i < 8; i++){
    pinMode(led[i], OUTPUT);
//all in here is tested ok, it just turns leds on in diferent patterns
  switch(var){
    case 1:
      digitalWrite(led[0], HIGH);
      digitalWrite(led[0], LOW);
    case 2:
      for(int j = 0; j < 4; j++){
        digitalWrite(led[j], HIGH);
        digitalWrite(led[j], LOW);
    case 3:
      for(int j = 3; j >= 0; j--){
    case 4:
      for(int j = 0; j < 6; j++){
        digitalWrite(led[j + 2], HIGH);
        digitalWrite(led[j + 2], LOW);
    default:
Arduino: Elegoo Uno R3
OS: Manjaro xfce
6v6gt
If the goal is to read the settings of the dip switches into an array, you have to define an array:
bool dipSwitch[ 4 ] ;
Then later load the array (could be more compact and could be inverted):
 if(digitalRead(dipPins[ i ] ) == LOW){
     dipSwitch[ i ] = LOW ;
  else {
    dipSwitch[ i ] = HIGH;
Important also to know is how the dip switches are wired and what you are going to do with pull up or pull down resistors.
drxm
Yes i just realized i need to send power to the dip switch.. Can you send me some basic tutorial for doing that? I'm searching but many people do really complicated projects I don't understand
jremington
Quote
power to the dip switch. Can you send me some basic tutorial
The dip switch is just like a button, for which there are many tutorials, and one or more examples in the Arduino IDE. Google "Arduino read button".
You will need a pullup or pulldown resistor (the pullup can be internal to the Arduino).
6v6gt
Here is such a tutorial :
https://learn.sparkfun.com/tutorials/pull-up-resistors/what-is-a-pull-up-resistor
drxm
Wow thank you so much! I followed the link and read the info related and now i have it working! Almost..
When the loop starts it gets into the for loop and change the "var" variable, but when the loop restarts seems to not enter into the loop to reverify the dip switch states.
This is my code now:
Code: [Select]
// global variables
int dipPins[] = {2, 3, 4, 5}; //pines dip switch
int led[] = {6, 7, 8, 9, 10, 11, 12, 13}; //pines leds
int var = 0;
  //dip switch pins
  //led pins
  //here is the loop I'm using to verify the dip switch state
  //but seems to run just the first time the void loop runs
    if(digitalRead(dipPins[i]) == 0){
      var = i + 1;
  //everything's fine from here
  switch(var){
    case 1:
    case 2:
    case 3:
    case 4:
    default:
Delta_G
Throw a serial print inside that for loop to prove to yourself that it is running or not.
|| | ||| | || | ||  ~Woodstock
Please do not PM with technical questions or comments.  Keep Arduino stuff out on the boards where it belongs.
6v6gt
You should move the code set "var" to setup(). It should not be in the loop().
Delta_G
What if he wants to read the dips every time through?
|| | ||| | || | ||  ~Woodstock
6v6gt
Ah yes. That could indeed be the case. I had assumed the dip switches were for  "configuration", not something for "runtime".
Anyway, he'll also have a problem that the last iteration of the for loop determines var. It looks like he is attempting to count the number of set switches, irrespective of their position, to determine the value of var.
I guess then it should be something like this:
Code: [Select]
  var = 1 ;
      var++;
Delta_G
I was guessing he was only interested in the state of the last switch. I'd dip0 and dip1 are both on then I think he just wants to know about dip1.
|| | ||| | || | ||  ~Woodstock
DangerToMyself
Karma to the OP for using code tags in his first post. That's a rarity.
drxm
Yes, I want to check the dip switch state at runtime every time =)
Well I have 4 cases for the dip switch. I want to check through the four pins to verify which one is open to change the switch var accordingly.
Thanks! I had read the "How to use.." topic =p
6v6gt
Quote
For a choice of 4 values of var , you need only 2 dip switches. 4 dip switches actually gives you 16 cases:
Code: [Select]
0000
0001
0010
0011
0100
etc.
What value should var have if none of the dip switches is set ?
drxm
In my protoboard I have selected option 1, but serial monitor displays the four options as "1" like:
2 - 4 - 1
3 - 4 - 1
4 - 4 - 1
5 - 4 - 1
The switch is entering case: 4. I believe the state is not changing the "var" variable, the for is just looping until the end and "var" gets equal 4.
Code: [Select]
      var = i + 1;
    Serial.print(dipPins[i]);
    Serial.print(" - ");
    Serial.print(var);
    Serial.println(digitalRead(dipPins[i]));
I tried with the following if-else if statement and isn't working too. It catch the "var" the first time, but later didn't recognize the dip switch change at runtime.
Code: [Select]
if(digitalRead(dipPins[0]) == 0){
    var = 1;
  else if(digitalRead(dipPins[1]) == 0){
    var = 2;
  else if(digitalRead(dipPins[2]) == 0){
    var = 3;
  else if(digitalRead(dipPins[3]) == 0){
    var = 4;
For a choice of 4 values of var , you need only 2 dip switches. 4 dip switches actually gives you 16 cases..
I thought to received HIGH/LOW or 0/1 only. In which case yes, i can use only 2. I'll change that at the end! Thanks!
