Dear all, after some tests done, I have generated this graph (attached). It is not linear but almost, but the problem is that I need to work in a very accurate way, so how can i program the arduino for such a graph? tnx
The aim is this:
I have a gas cylinder (on my loadcell and opamp), the gas cylinder when full weighs 19kgs.
Now when i open the gas cylinder, gas gets out of the cylinder and enters a cars a/c
Therefore i need the arduino to notice when for example 400grams have escaped the cylinder gas. That is why i plotted the graph.
First, you should put the data in Excel, make the graph, then add a linear aproximation. That way, you can find out where exactly is the graph not linear. Use one or two decimal places for the aproximation as the Arduino won't like it too much if you use more than three.
Once you find the interval where the line is linear, get the equation and program it. Then the part that will most likely not be linear are the ends. Ok, imagine that 4 intervals in the beginning are not linear. You can make a linear aproximation inside the interval...
in pseudo code:
value = readADC(0);
if (value == 0 ||value < 0.12)
final_val = Linearize (value, 0, 0.12);
else{
if (value >=0.12 || value < 0.38)
final_val = Linearize (value, 0.12, 0.38);
Yes. All in Excel. It's not SAS, but I have it handy. I've done a bit of fiddling with your data and I have a couple of observations.
(1) I think your last data point [4.620,19035] is bogus
(2) I think that the underlying volts/gram relationship is linear to well within the accuracy of the measurements you've made, and
(3) I think that the source of the errors is A/D sampling error, specifically in the imperfect values in the A/D's resistance ladder.
The orange sawtooth series is the difference between the linear regression and the actual gram values. I bet you a buck, that the saw tooths correlate with the switching of specific bits of the A/D value and that would be an indication of error in the resistor ladder network used by the A/D sampler.
The error curve does not have any simple shape that would indicate a correctable non-linearity in the volt/gram function.
Hehe tnx gardner for the info :). But I have not used an A/D converter. That is still to be used....
I am using a load cell; giving output voltage for the weigh on it.
The instruments used is an oscilloscope (Voltage peak+) and a very good power supply. Even the weights 1kg are exactly 1kg since I made a spent some time putting exactly 1kg of sand.
And yes i think that the last point is bogus...
Ill hook up the equipment again and take other readings but I think it is quite a good almost linear graph.
Another question is this, when you wrote : ** grams = 17.299 volts^2 + 4068.3 volts - 488.45** How did you work that out??
With excel I managed to get this summary:
SUMMARY OUTPUT
Regression Statistics
Multiple R 0.999765814
R Square 0.999531683
Adjusted R Square 0.999505665
Standard Error 0.031847119
Observations 20
ANOVA
df SS MS F Significance F
Regression 1 38.9645237 38.9645237 38417.49623 2.01014E-31
Residual 18 0.018256302 0.001014239
Total 19 38.98278
Coefficients Standard Error t Stat P-value Lower 95% Upper 95% Lower 95.0% Upper 95.0%
Intercept 0.122532035 0.01375446 8.908531055 5.12634E-08 0.093634987 0.151429083 0.093634987 0.151429083
X Variable 1 0.000241939 1.23436E-06 196.0038169 2.01014E-31 0.000239346 0.000244533 0.000239346 0.000244533
Meaning that it is quite a good almost linear graph, but still I need to be accurate in this since I am refilling a cars a/c tank.
There's a "display equation" property on the trendline in Excel. Also a "display R-squared". This is simply the quadratic that Excel fit. Incidentally, that was with the last point included, and when I chuck that one out the curve it fits is different.
I would look to errors in these weights then. Do you have a bucket with 10 Kg, one with 5, etc? The error chart looks like a difference in the weight of the 10 Kg bucket vs the 5 Kg + 3 Kg + 2 Kg. At the points where you swap the small weights out for the one large one is where you get these sawtooths. It really does look like quantization noise of some type, and quantization of your physical weights could be a factor. The mean error is something like 50 grams. Are your weights accurate to that precision for sure? What instrument did you use to measure them?
Clicking on my excel graph - treadline gives me this equation and not the one you gave me (which i think is better, since this is for the linear equation) y = 0.0002x + 0.1225
What I did was I got 20kgs of sand, and put 1kg, 1kg, 1kg ..... into seperated plastic bags, so I have 20 plastic bags each 1kg. and exactly 1kg since I used a good electronic weighing scale to measure them.
The error could be since the base on which placing these plastic bags wasnt that good. Look at the photos attached you will understand by what I mean I think
What is your recommandation?? Do I use the linear equation in my code??
both can be implemented by the Arduino.
A is the better one, but the difference is small
B will be twice as fast as it need 3 FP operations while A needs 6 FP operations,
Question: Can you quantify the consequences for using A over B or vice versa? Or how bad is it?
Can you please explain were you are getting these functions:
A: grams = 17.299 volts^2 + 4068.3 volts - 488.45
B: grams = 4129.4 volts - 495.53 ???
My excel graph only displays my linear function as y = 0.0002x + 0.1225
Hmm i dont know exactly what will happen, what Im doing is refilling a cars a/c. Normally it wouldn't matter if there is a +/- 20grams difference in the amount refilled....
These were mentioned in previous posts. I did not check the data, but the point I wanted to make was if the data is so linear why not use it as if it was linear. Unless the consequences of the simplification is not acceptable.
think your formula is quite OK by the way.
+/- 20 grams:
There is globally a delta of 0.25 Volt per 1000 gram => that means that a 0.01Volt (measurement accuracy) step stands for 40 grams!
