I am trying to work on serial communication in MAC OS. I already did this same coding part using java
netbeans in Windows 7. For serial communication used RXTX and JSSC libraries and it works out well. My
code actually displays the available com ports and the serial communication happens well. But when i
tried using the same code in MAC it does not display the com ports. When the arduino board is
connected using USB in MAC it gets connected and the said java code detects the com port and it works
well but the same arduino board when connected to Bluetooth does not work the code does not display
the arduino ports. Can you please explain me as what i should do to make the serial communication
happen in MAC using JAVA with the arduino board connected to Bluetooth ?
