Hello,
this is my first arduino project, and I'm very happy with the result. This circuit allows me to take high speed pictures, like this
I made a video explaining how I took this picture and put it onto Youtube.
This is the code for the arduino.
High speed photography with an arduino
//analog pins
#define SOUNDIN A0
#define SENSITIVITYPIN A1
#define DELAYPIN A2
//constants
#define SHORTCOMMAND 0
#define LONGCOMMAND 1
#define COMMANDSEPARATOR 10Â //border between short and long commands
#define LIGHT 0
#define SOUND 1
//digital pins
#define FOCUSPIN 2
#define TRIGGERPIN 3
#define FLASHPIN 4
#define LIGHTPIN 5
#define LIGHTSOUNDTOGGLE 6
#define STARTSWITCH 7
#define LEDPIN 9
#define BEEPPIN 10
 pinMode(FOCUSPIN, OUTPUT);
 pinMode(TRIGGERPIN, OUTPUT);
 pinMode(FLASHPIN, OUTPUT);
 pinMode(LIGHTPIN, OUTPUT);
 pinMode(LIGHTSOUNDTOGGLE, INPUT);
 pinMode(STARTSWITCH, INPUT);
 pinMode(LEDPIN, OUTPUT);
 pinMode(BEEPPIN, OUTPUT);
 ledOn();
 turnLightOn();
This is the logic of the device
1. Wait for the start switch to be pressed
2. Wait for voice command. Short command triggers lights outs. Long command cancels the whole procedure
3. Wait for voice command. Short command opens shutter. Long command cancels the whole procedure
4. Check what to do. This is either
 a. Wait for sound. Any sound triggers flash
 b. Wait for pass in light port. Any movement triggers flash
5. Close shutter
6. Turn on light
Â
Â
 if(start()) // 1. Wait for the start switch to be pressed
  int command;
  command = detectCommand(0);
 Â
  if (command == SHORTCOMMAND) // 2. Wait for voice command. Short command triggers lights outs.
   rogerBeep();
   turnLightOff();
  Â
   if (command == SHORTCOMMAND) // 3. Wait for voice command. Short command opens shutter.
    rogerBeep();
    ledOff();
    openShutter();
   Â
    int delayTime = readDelay();
    delay(200);
   Â
    if (lightOrSound() == SOUND) //4. Check what to do
     detectSound(0);
     delay(delayTime);
     flash();
     // to be implemented
   Â
    // 5. & 6. Close shutter, turn light on
    closeShutter();
    ledOn();
    turnLightOn();
   Â
   else // 3. Wait for voice command. Long command cancels the whole procedure
    cancelBeep();
    turnLightOn();
  Â
  Â
  else // 2. Wait for voice command. Long command cancels the whole procedure
   cancelBeep();
 Â
void rogerBeep()
 digitalWrite(BEEPPIN, HIGH);
 delay(200);
 digitalWrite(BEEPPIN, LOW);
void cancelBeep()
 for (int i = 0; i<3; i++)
  delay(200);
  delay(200);
int lightOrSound()
 if (digitalRead(LIGHTSOUNDTOGGLE)) return SOUND;
 else return LIGHT;
void flash()
 digitalWrite(FLASHPIN, HIGH);
 delay(200);
 digitalWrite(FLASHPIN, LOW);
void turnLightOn()
 digitalWrite(LIGHTPIN, HIGH);
void turnLightOff()
 digitalWrite(LIGHTPIN, LOW);
int readSensitivity()
 int sensitivity = 0;
 sensitivity = analogRead(SENSITIVITYPIN);
 return map(sensitivity, 0, 1023, 540, 650);
int readDelay()
 int delaytime = 0;
 delaytime = analogRead(DELAYPIN);
 return map(delaytime, 0, 1023, 0, 250);
boolean start()
 while (digitalRead(STARTSWITCH));
 return true;
void ledOn()
 digitalWrite(LEDPIN, HIGH);
void ledOff()
 digitalWrite(LEDPIN, LOW);
int detectCommand(int compensation)
 int count = 0;
 int countSilence = 0;
 int treshHold = readSensitivity();
 while (true)
  int sensorValue = analogRead(SOUNDIN);
  sensorValue = sensorValue + compensation;
  if (sensorValue < 512) sensorValue = 1024 - sensorValue;
  if (sensorValue > treshHold)
   count++;
   countSilence = 0;
   //Check if this is the end of the command
   countSilence++;
   if (count > 0 && countSilence > 10)
    if (count < COMMANDSEPARATOR) return SHORTCOMMAND;
    else return LONGCOMMAND;
  Â
 Â
  delay(5);
void detectSound(int compensation)
Â
 while (true)
  if (sensorValue > treshHold) return;
void openShutter()
 digitalWrite(FOCUSPIN, HIGH);
 digitalWrite(TRIGGERPIN, HIGH);
void closeShutter()
 digitalWrite(FOCUSPIN, LOW);
 digitalWrite(TRIGGERPIN, LOW);
This is definitely not my last arduino project! Love it.
Greetings
Cedric
