Control 3-way valves using an Arduino and KEITHLEY electromechanical relay
It's my first time to create a circuit with an Arduino microcontroller.
I try to control 3 3-way solenoid valves (GALTEK, 24 VDC, .50 AMPS, 12 Watts) in order to switch them accordingly to a certain time schedule or an instrument output. The application in which I will use it is air sampling.
Additionally, we own a KEITHLEY ERA-01 electromechanical 8-channel SPDT relay output accessory board and an Arduino ethernet.
There is any previous similar experience either in circuit diagram or the programming?
Thank you.
It should just be a simple sequence, simular to an LED shifter.
0001 led1 on, led2-4 off
0010 led2 on, led1 & 3,4 off
0100 led3 on, led 1,2, 4 off
1000 led4 on, led1-3 off
Right?
Exactly.
Ok, then you can simply use:
digitalWrite(relay1, HIGH); digitalWrite(relay2, LOW); digitalWrite(relay3, LOW);
digitalWrite(relay1, LOW); digitalWrite(relay2, HIGH); digitalWrite(relay3, LOW);
digitalWrite(relay1, LOW); digitalWrite(relay2, LOW); digitalWrite(relay3, HIGH);
OR, you can use port manipulation, but I dont it is need for this project.
Look at example Blink LED without delay, if you haven't already.
Does there need to be any particular sequence?
