ok, i think for ease of programming, since im so new and all, i will go with the first configuration. I tried modifieing some of your example code, since i have a 12x24 matrix (12 RGBs) so really 36x24
// code for an 36 x 24 array (12 RGB LEDs, 24 columns) as an example
// not all code parts shown, just the highlights
// set up an array for the cathode drives
byte cathodeslower[ ] = {0x01, 0x02, 0x04, 0x08, 0x10, 0x20, 0x40, 0x80, 0,0,0,0,0,0,0,0}; // walking 1 for lower 8 NPNs
byte cathodesmid[ ] = {0,0,0,0, 0x01, 0x02, 0x04, 0x08, 0x10, 0x20, 0x40, 0x80, 0,0,0,0}; //walking for mid 8 NPNs ????????
byte cathodeshigher[ ] = {0,0,0,0,0,0,0,0,0x01, 0x02, 0x04, 0x08, 0x10, 0x20, 0x40, 0x80}; // walking 1 for upper 8 NPNs
byte anodes1 [12]; // array to hold 1st 3rd of RGB info, like red?
byte anodes2 [12]; // array to hold 2nd 3rd of RGB info, like blue?
byte anodes3 [12]; // array to hold 3rd 3rd of RGB info, like green?
byte columncount;
byte oe = 12;
unsigned long updateTime = 0;
void setup(){
pinMode (oe/, OUTPUT);
digitalWrite (oe/, HIGH);
SPI.begin;
void loop(){
// set up for blink without delay operation
if (millis() >=updateTime){
// yes, set up for next update
updateTime = updateTime +2; // update a column every 2 milliseconds, 16 columns at ~24 Hz rate
digitalWrite (oe, HIGH); // turn off display
SPI.transfer (anodes1[columncount]); // update anodes
SPI.transfer (anodes2[columncount]); // update anodes
SPI.transfer (anodes3[columncount]); // update anodes
SPI.transfer (cathodeslower[columncount]); // turn on a cathode
SPI.transfer (cathodesupper[columncount]); // turn on a cathode
digitalWrite (oe, LOW); / turn display back on
columncount = columncount + 1; // update for next column
if (columncount == 24){columncount = 0;} // reset if reach the end
} //end display refresh
// now the fun part, for you!
// read buttons, or whatever processing you plan to do for patterns, etc.,
// and update anodes1, anodes2, anode3 as needed
} // end void loop
I really dont know about that cathodemid section, mostly guessing when i wrote that. But i did manage to do my research on hex, so at least that is understandable now. Still a little fuzzy on arrays.
