I'm trying to use the DS3234 library with an Arduino Due
http://playground.arduino.cc/Main/DS3234SoftwareLibrary
But every time I try to upload the example online:
#include <DS3234.h>
RTC.configure(4,5,6,7);
Serial.println(String("Current date/time: ")+RTC.readDateTime());
delay(2000);
I get this error:
In file included from C:\Program Files (x86)\Arduino\hardware\arduino\sam\system/CMSIS/Device/ATMEL/sam3xa/include/sam3xa.h:44:0,
from C:\Program Files (x86)\Arduino\hardware\arduino\sam\system/CMSIS/Device/ATMEL/sam3.h:59,
from C:\Program Files (x86)\Arduino\hardware\arduino\sam\system/CMSIS/Device/ATMEL/sam.h:198,
from C:\Program Files (x86)\Arduino\hardware\arduino\sam\system/libsam/chip.h:25,
from C:\Program Files (x86)\Arduino\hardware\arduino\sam\cores\arduino/Arduino.h:42,
from C:\Users\alsipj\Documents\Arduino\libraries\DS3234/DS3234.h:1,
from sketch_dec11a.ino:1:
C:\Program Files (x86)\Arduino\hardware\arduino\sam\system/CMSIS/Device/ATMEL/sam3xa/include/sam3x8e.h:502:29: error: expected ')' before '*' token
#define RTC ((Rtc *)0x400E1A60U) /**< \brief (RTC ) Base Address */
C:\Users\alsipj\Documents\Arduino\libraries\DS3234/DS3234.h:29:15: note: in expansion of macro 'RTC'
extern DS3234 RTC;
extern DS3234 RTC;
sketch_dec11a.ino: In function 'void setup()':
sketch_dec11a.ino:7:7: error: request for member 'configure' in '1074666080u', which is of pointer type 'Rtc*' (maybe you meant to use '->' ?)
sketch_dec11a.ino: In function 'void loop()':
sketch_dec11a.ino:15:51: error: request for member 'readDateTime' in '1074666080u', which is of pointer type 'Rtc*' (maybe you meant to use '->' ?)
Error compiling.
I'm trying to use an Arduino Due. Is the library incompatible or is something else going on?
Thanks,
