Buenas noches.
Estuve mirando un tutorial sobre los modulo de tiempo real
El que tengo es un ds3231sn
Yo copie un codigo que estava en github con sus respetivas librerias pero me aparece un error como este
C:\Users\Tahiry\Desktop\rtc\rtc.ino: In function 'void setup()':
C:\Users\Tahiry\Desktop\rtc\rtc.ino:26:36: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
parse_cmd("T305702221112017",16);
C:\Users\Tahiry\Desktop\rtc\rtc.ino: In function 'void loop()':
C:\Users\Tahiry\Desktop\rtc\rtc.ino:41:24: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
parse_cmd("C",1);
C:\Users\Tahiry\Desktop\rtc\rtc.ino: In function 'void parse_cmd(char*, int)':
rtc:136: error: cannot convert 'boolean* {aka bool*}' to 'const uint8_t* {aka const unsigned char*}' for argument '5' to 'void DS3231_set_a1(uint8_t, uint8_t, uint8_t, uint8_t, const uint8_t*)'
DS3231_set_a1(time[0], time[1], time[2], time[3], flags);
rtc:146: error: cannot convert 'boolean* {aka bool*}' to 'const uint8_t* {aka const unsigned char*}' for argument '4' to 'void DS3231_set_a2(uint8_t, uint8_t, uint8_t, const uint8_t*)'
DS3231_set_a2(time[0], time[1], time[2], flags);
Se encontraron múltiples librerías para "ds3231.h"
Usado: C:\Users\Tahiry\Documents\Arduino\libraries\ds3231-master
No usado: C:\Program Files\Arduino\libraries\rtc
exit status 1
el codigo que uso es este
#include <Wire.h>
#include "ds3231.h"
#include "rtc_ds3231.h"
#include <LiquidCrystal.h>
LiquidCrystal lcd(8,9,4,5,6,7);
#define BUFF_MAX 128
uint8_t time[8];
char recv[BUFF_MAX];
unsigned int recv_size = 0;
unsigned long prev, interval = 1000;
Wire.begin();
DS3231_init(DS3231_INTCN);
memset(recv, 0, BUFF_MAX);
Serial.println("GET time");
lcd.begin(16, 2);
lcd.clear();
Serial.println("Setting time");
char in;
char tempF[6];
float temperature;
char buff[BUFF_MAX];
unsigned long now = millis();
struct ts t;
// show time once in a while
if ((now - prev > interval) && (Serial.available() <= 0)) {
DS3231_get(&t); //Get time
parse_cmd("C",1);
temperature = DS3231_get_treg(); //Get temperature
dtostrf(temperature, 5, 1, tempF);
lcd.clear();
lcd.setCursor(1,0);
lcd.print(t.mday);
printMonth(t.mon);
lcd.print(t.year);
lcd.setCursor(0,1); //Go to second line of the LCD Screen
lcd.print(t.hour);
lcd.print(":");
if(t.min<10)
lcd.print("0");
lcd.print(t.min);
lcd.print(":");
if(t.sec<10)
lcd.print("0");
lcd.print(t.sec);
lcd.print(' ');
lcd.print(tempF);
lcd.print((char)223);
lcd.print("C ");
prev = now;
if (Serial.available() > 0) {
in = Serial.read();
if ((in == 10 || in == 13) && (recv_size > 0)) {
parse_cmd(recv, recv_size);
recv_size = 0;
recv[0] = 0;
} else if (in < 48 || in > 122) {; // ignore ~[0-9A-Za-z]
} else if (recv_size > BUFF_MAX - 2) { // drop lines that are too long
// drop
recv_size = 0;
recv[0] = 0;
} else if (recv_size < BUFF_MAX - 2) {
recv[recv_size] = in;
recv[recv_size + 1] = 0;
recv_size += 1;
void parse_cmd(char *cmd, int cmdsize)
uint8_t i;
uint8_t reg_val;
struct ts t;
//snprintf(buff, BUFF_MAX, "cmd was '%s' %d\n", cmd, cmdsize);
//Serial.print(buff);
// TssmmhhWDDMMYYYY aka set time
if (cmd[0] == 84 && cmdsize == 16) {
//T355720619112011
t.sec = inp2toi(cmd, 1);
t.min = inp2toi(cmd, 3);
t.hour = inp2toi(cmd, 5);
t.wday = inp2toi(cmd, 7);
t.mday = inp2toi(cmd, 8);
t.mon = inp2toi(cmd, 10);
t.year = inp2toi(cmd, 12) * 100 + inp2toi(cmd, 14);
DS3231_set(t);
Serial.println("OK");
} else if (cmd[0] == 49 && cmdsize == 1) { // "1" get alarm 1
DS3231_get_a1(&buff[0], 59);
Serial.println(buff);
} else if (cmd[0] == 50 && cmdsize == 1) { // "2" get alarm 1
DS3231_get_a2(&buff[0], 59);
} else if (cmd[0] == 51 && cmdsize == 1) { // "3" get aging register
Serial.print("aging reg is ");
Serial.println(DS3231_get_aging(), DEC);
} else if (cmd[0] == 65 && cmdsize == 9) { // "A" set alarm 1
DS3231_set_creg(DS3231_INTCN | DS3231_A1IE);
//ASSMMHHDD
for (i = 0; i < 4; i++) {
time[i] = (cmd[2 * i + 1] - 48) * 10 + cmd[2 * i + 2] - 48; // ss, mm, hh, dd
boolean flags[5] = { 0, 0, 0, 0, 0 };
} else if (cmd[0] == 66 && cmdsize == 7) { // "B" Set Alarm 2
DS3231_set_creg(DS3231_INTCN | DS3231_A2IE);
//BMMHHDD
time[i] = (cmd[2 * i + 1] - 48) * 10 + cmd[2 * i + 2] - 48; // mm, hh, dd
boolean flags[5] = { 0, 0, 0, 0 };
} else if (cmd[0] == 67 && cmdsize == 1) { // "C" - get temperature register
Serial.print("temperature reg is ");
Serial.println(DS3231_get_treg(), DEC);
} else if (cmd[0] == 68 && cmdsize == 1) { // "D" - reset status register alarm flags
reg_val = DS3231_get_sreg();
reg_val &= B11111100;
DS3231_set_sreg(reg_val);
} else if (cmd[0] == 70 && cmdsize == 1) { // "F" - custom fct
reg_val = DS3231_get_addr(0x5);
Serial.print("orig ");
Serial.print(reg_val,DEC);
Serial.print("month is ");
Serial.println(bcdtodec(reg_val & 0x1F),DEC);
} else if (cmd[0] == 71 && cmdsize == 1) { // "G" - set aging status register
DS3231_set_aging(0);
} else if (cmd[0] == 83 && cmdsize == 1) { // "S" - get status register
Serial.print("status reg is ");
Serial.println(DS3231_get_sreg(), DEC);
Serial.print("unknown command prefix ");
Serial.println(cmd[0]);
Serial.println(cmd[0], DEC);
void printMonth(int month)
switch(month)
case 1: lcd.print(" January ");break;
case 2: lcd.print(" February ");break;
case 3: lcd.print(" March ");break;
case 4: lcd.print(" April ");break;
case 5: lcd.print(" May ");break;
case 6: lcd.print(" June ");break;
case 7: lcd.print(" July ");break;
case 8: lcd.print(" August ");break;
case 9: lcd.print(" September ");break;
case 10: lcd.print(" October ");break;
case 11: lcd.print(" November ");break;
case 12: lcd.print(" December ");break;
default: lcd.print(" Error ");break;
me podrian orientar como puedo solucionar ese error?
estuve mirando el error pero sospecho que la libreria no funciona
