Topic: Turning Target Trouble (Read 304 times) previous topic - next topic
xpx
I'm trying to make a homemade turning targets and having a problem programming the servos to turn at the same time
 I'm hoping to have a button to press to face the targets and a button to press for the targets to turn away for 7 seconds and the face for 10 seconds and then turn away and stop the sequence.
Can someone help (I'm pulling my hair out)
Coding Badly
Please do not hijack.  Thread split.
Delta_G
You tried to do something and it doesn't work.  You want someone to help you fix it so it does work.  So you come to ask them.  Why in the world would you not include the thing you want to fix?  How can we help you fix your code without.....    your code.
|| | ||| | || | ||  ~Woodstock
Please do not PM with technical questions or comments.  Keep Arduino stuff out on the boards where it belongs.
TomGeorge
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Thanks.. Tom.. :)
Everything runs on smoke, let the smoke out, it stops running....
lasrberglund
I have made a RF turning-target some while ago. PM me if you want the sketch.
xpx
Hi
Im very new to Arduinos and I'm willing to learn the coding , I have 5 servos and I'm needing them to stay forward for 3sec and turn away for 7sec and face forward for 10/20/150secs can you point me in the right direction please
Kind regards
jremington
#6
Oct 18, 2017, 06:30 pm Last Edit: Oct 18, 2017, 06:31 pm by jremington
You will need a 5 to 6V power supply capable of providing at least one Ampere per moving servo (5 Amps if all can move at once). Connect all the grounds together.
There are plenty of servo tutorials on the web. However, don't try to power any motor or servo from the Arduino 5V output -- that can destroy the Arduino.
dustin02rsx
Do you want to be able to move them independently as well as move them all simultaneously?
