I am taking a microcontrollers course in college, and I have broken a bit of wire off in my 5V jack on my Uno while doing some homework. Anyone have any tips on how to get this wire out?
Photo?
eli123ky:
Needle nosed tweezers or, failing that, a needle and patience.
I have fixed it by chipping away a tiny bit of the header (i think it's called) around the 5V jack with nail clippers! I found a link where someone had used solder somehow. I didn't cause any damage.
Next time try a sharp needle.
just to get the terms right, i don't think that's called a "jack" - that would be the DC jack where you plug in the round end from a power adaptor.
what you have a problem with is the "5V pin" and that's an output, have a look at this page;
Definitely not a jack!! Its a female header. If you don't own some non-magnetic
very fine-nosed tweezers you probably ought to, often useful.
The 5V female header can be an input or an output.
When used as an input, a diode should be added from 5V (anode) to Vin (cathode) to avoid reverse biasing the 5V regulator and killing it.
CrossRoads:
but that would not really be required under normal circumstances, right ?
the Arduino documentation itself states it's an output.
i guess it's just an alternative if the other, more usual, choices of power supply are not available - perhaps broken or physically disabled ?
What's normal? Normal for me is power from a 5V wallwart, using the header. I rarely run from 9V or 12V.
