Hi friends.
I'm trying to build a client-sever arduino that, from remote pc, turn on a led and when is pressed a button on it, send a post to another arduino server, wich recieve the post and turn on a led.
Have you an idea or code to do it? I red many posts in wich are explained a lot of server-client cases, but I never found a server client wich send post to another arduino: can you help me please?
Let me sure I understand. You want one arduino to be both a client and a server, and you have another arduino that you want to be a server. So, the PC as a client sends to the first arduino which turns on a light, then that arduino sends to the second one that also turns on a light.
If I got that correct, you can certainly do it. You'll have to combine the server and client examples in the playground on one of the arduinos which is a little confusing, but I've done it a few times successfully. The the second arduino is just the client example, or you can duplicate the first arduino and just not use the client code until later when you expand the system.
Below is some combined server and client code you can experiment with. Bottom isa n example of a client POST.
//zoomkat 12-08-11, combined client and server
//simple button GET with iframe code
//for use with IDE 1.0
//open serial monitor and send an g to test client and
//see what the arduino client/server receives
//web page buttons make pin 5 high/low
//use the \ slash to escape the " in the html
//address will look like http://192.168.1.102:84 when submited
//for use with W5100 based ethernet shields
//note that the below bug fix may be required
// http://code.google.com/p/arduino/issues/detail?id=605
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
IPAddress ip(192,168,1,102); // ip in lan
IPAddress gateway(192,168,1,1); // internet access via router
IPAddress subnet(255,255,255,0); //subnet mask
//IPAddress myserver(208,104,2,86); // zoomkat web page
EthernetServer server(84); //server port
EthernetClient client;
String readString;
char serverName[] = "web.comporium.net"; // zoomkat's test web page server
void setup(){
pinMode(5, OUTPUT); //pin 5 selected to control
Ethernet.begin(mac,ip,gateway,gateway,subnet);
server.begin();
Serial.println("server/client 1.0 test 12/08/11"); // keep track of what is loaded
Serial.println("Send an g in serial monitor to test client"); // what to do to test client
/*if (Ethernet.begin(mac) == 0) {
Serial.println("Failed to configure Ethernet using DHCP");
// no point in carrying on, so do nothing forevermore:
while(true);
void loop(){
// check for serial input
if (Serial.available() > 0)
byte inChar;
inChar = Serial.read();
if(inChar == 'g')
sendGET(); // call sendGET function
if (client) {
while (client.connected()) {
if (client.available()) {
char c = client.read();
//read char by char HTTP request
if (readString.length() < 100) {
//store characters to string
readString += c;
//Serial.print(c);
//if HTTP request has ended
if (c == '\n') {
Serial.println(readString); //print to serial monitor for debuging
//now output HTML data header
if(readString.indexOf('?') >=0) { //don't send new page
client.println("HTTP/1.1 204 Zoomkat");
client.println();
client.println();
else {
client.println("HTTP/1.1 200 OK"); //send new page
client.println();
client.println("<HTML>");
client.println("<HEAD>");
client.println("<TITLE>Arduino GET test page</TITLE>");
client.println("</HEAD>");
client.println("<BODY>");
client.println("<H1>Zoomkat's simple Arduino 1.0 button</H1>");
client.println("<a href=\"/?on\" target=\"inlineframe\">ON</a>");
client.println("<a href=\"/?off\" target=\"inlineframe\">OFF</a>");
//client.println("<IFRAME name=inlineframe src=\"res://D:/WINDOWS/dnserror.htm\" width=1 height=1\">");
client.println("<IFRAME name=inlineframe style=\"display:none\" >");
client.println("</IFRAME>");
client.println("</BODY>");
client.println("</HTML>");
delay(1);
//stopping client
client.stop();
///////////////////// control arduino pin
if(readString.indexOf("on") >0)//checks for on
digitalWrite(5, HIGH); // set pin 5 high
Serial.println("Led On");
if(readString.indexOf("off") >0)//checks for off
digitalWrite(5, LOW); // set pin 5 low
Serial.println("Led Off");
//clearing string for next read
readString="";
void sendGET() //client function to send/receive GET request data.
if (client.connect(serverName, 80)) {
Serial.println("connected");
client.println("GET /~shb/arduino.txt HTTP/1.0");
client.println();
else {
Serial.println("connection failed");
Serial.println();
while(client.connected() && !client.available()) delay(1); //waits for data
while (client.connected() || client.available()) { //connected or data available
Serial.print(c);
Serial.println();
Serial.println("disconnecting.");
Serial.println("==================");
Serial.println();
client.stop();
post
client.println("POST hxxp://yourdomain.com/SMSSite/XMLInterface/Postxml.aspx HTTP/1.0");
// add a header indicating you have content-data to send. If you set this too low, the server won't see it. If it is too high, the server may wait, or report an error.
client.print("content-length: ");
client.println(strlen(big_string));
// tell the server you are done with the header.
client.println();
// send the posted data.
client.print(big_string);
@draythomp
Thanks for answer.
I must be more clear:
I have two arduino on my private network, one must have a webserver where, with my pc I call html page and turn on and off a led on it.
On this arduino (number 1), must be on a button: when pressed, it will send a post to the other arduino (number 2, different address), wich is always waiting post of the first arduino. When post will be arrived, it will turn on a led on arduino 2.
I hope to be clear.
@zoomkat
Very good code; I've tried to use it but it doesn't turn led on arduino 2.
First part of the code has token by your old post wich four led-button and data read on your web page by client.
void sendGET() //client function to send and receive GET data from external server.
buttonStateOld=buttonState;
// check if the pushbutton is pressed.
// if it is, the buttonState is HIGH:
if (buttonState != buttonStateOld) {
if (buttonState == HIGH){
client.connect(serverName, 80);//connette il client
Serial.println("connesso"); //stampa su seriale;
client.println("POST /led=1");//invia il comando "accendi
led";
client.println();
client.stop();}
{if (buttonState != buttonStateOld)
{if (buttonState == LOW){
client.println("POST /led=0");//invia il comando "spegni led";
client.println();
client.stop();
delay (50);//end delay before loop starts again
client.println();
else {
Serial.println();
Serial.print(c);
Serial.println();
Serial.println();
client.stop();
I tested the code I posted, and using the web page served by the arduino, I can make pin 5 on the arduino high and low. Also sending a g to the arduino from the serial monitor resulted in a return from my web server. If you can not get the code (modified for yor router, etc.) to work, then there is not much else I can do for your project. Sorry.
I have modified your code for my ip address and it work very well:
but I don't know how I can modify it to send a post ,from client, to another server.
With your code I can read all what in server is, but I don't know to use your post metod in previews message:
could you explain where I could put "post" instead of get request? Thanks, fafidio
Not sure why you want to use POST instead of GET, but for a GET request you probably could modify the same code for arduino # 1 to make get request to arduino #2 to operate the LEDs.
Below is some quick test code for arduino #1 you should be able to change to connect to arduino #2. This is still setup to connect to my web server for testing. note this code ip address end is 103 instead of 102 to keep the ip address different. The final idea is to send an o from the serial monitor to have arduino #1 send an "on" GET request to arduino #2 to turn its LED on. Send f to do the same to turn the LED off. As is, a g, o, or f sent from the serial monitor will all download the same text from my web server for testing.
//zoomkat 3-05-13, combined client and server
//address will look like http://192.168.1.103:84 when submited
#include <SPI.h>
IPAddress ip(192,168,1,103); // arduino #1 ip address
//IPAddress myserver(192,168,1,102); // arduino #2 ip address
String readString;
//char serverName[] = "web.comporium.net"; // zoomkat's test web page server
byte inChar;
void setup(){
server.begin();
Serial.println("Send an g, o, or f, in serial monitor to test client"); // what to do to test client
void loop(){
//byte inChar;
if(inChar == 'g' || inChar == 'o' || inChar == 'f')
if (client) {
readString += c;
//Serial.print(c);
if (c == '\n') {
client.println();
client.println();
else {
client.println();
delay(1);
//stopping client
client.stop();
readString="";
//if (client.connect(myserver, 84)) { //arduino #2 on port 84
if (client.connect(myserver, 80)) {
if(inChar == 'g') client.println("GET /~shb/arduino.txt HTTP/1.0");
if(inChar == 'o') client.println("GET /~shb/arduino.txt HTTP/1.0");
if(inChar == 'f') client.println("GET /~shb/arduino.txt HTTP/1.0");
//GET request to arduino #2
//if(inChar == 'o') client.println("GET /?on HTTP/1.0"); //LED on
//if(inChar == 'f') client.println("GET /?off HTTP/1.0"); //LED off
client.println();
else {
Serial.println();
Serial.print(c);
Serial.println();
Serial.println();
client.stop();
Zoomkat, you are a great person! Thanks a lot, I have modified your code to press button on arduino 1 and when pressed it turns on a led on arduino2. It makes a GET only when it is pressed. So, if I open webserver on arduino 1, I can turn on a led on it. If I open webserver on arduino 2 I can check led status. Perfect, it's what I wanted. Now I will work to send sms with google calendar when button on arduino 1 is pressed.....then I will post code: someone could need it!
Is "calendar" the only methode to send sms without gms shield?
@Zoomkat
I was trying your code, though I changed it to use the WiFi shield, and I cannot seem to get it working. It never goes into the "listening for request" stage and sometimes the sendGet method is activated when I post to the Arduino.
//web page buttons make pin 4 high/low
#include <SPI.h>
#include <WiFi.h>
IPAddress myserver(192,168,0,103); // zoomkat web page
WiFiServer server(80);
int status = WL_IDLE_STATUS;
void setup(){
if (WiFi.status() == WL_NO_SHIELD) {
Serial.println("WiFi shield not present");
while(true);
while ( status != WL_CONNECTED) {
Serial.print("Attempting to connect to SSID: ");
status = WiFi.begin("name", "pass");
delay(10000);
server.begin();
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.print(rssi);
Serial.println(" dBm");
void loop(){
delay(100);
WiFiClient responseClient = server.available();
if (responseClient) {
while (responseClient.connected()) {
if (responseClient.available()) {
char c = responseClient.read();
Serial.print(c);
if (c == '\n') {
responseClient.println("HTTP/1.1 200 OK"); //send new page
responseClient.println("Content-Type: text/html");
responseClient.println();
responseClient.println("Just some content");
delay(1);
//stopping client
responseClient.stop();
Serial.println("Finished");
void sendGET() //client function to send/receie GET request data.
WiFiClient flaskClient;
if (flaskClient.connect(myserver, 9090)) {
flaskClient.println("GET /arduino/status/1/ HTTP/1.1");
flaskClient.println();
else {
Serial.println();
while(flaskClient.connected() && !flaskClient.available()) delay(1); //waits for data
while (flaskClient.connected() || flaskClient.available()) { //connected or data available
char c = flaskClient.read();
Serial.print(c);
Serial.println();
flaskClient.stop();
Did anyone have the same problem? Or maybe see what I am doing wrong?
The Wifi shield may have a bit of trouble dealing with multiple sockets. I am not sure it has the capability. I tried to assist another user with the FTP client code, and that person had the same problem with the Wifi shield. It would not open a second socket/connection while the first was still open.
I get similar problems between 2 Arduinos with Redfly Wifi Shields (Watterott), which I want to communicate directly, without computer.
I described that on a recent post: Wlan-Wifi communication beetween 2 Arduinos+Redfly Arduino Forum
(thank you Zoomkat for your nice cooperation)
